I cannot run Themler for HTML5. It starts and will make updates and then it tells me there is a fault. It reloads again and again...
How can I fix it.
Themler for Joomla works fine
Best regards
Joerg
How can I fix it.
Best regards
Joerg
7. Download latest version of Themler for Windows from themler.io, install it and try to start with Themler for HTML5.
Hi Gina,
it worked. Thanks
It looks like that Themler is out of the nursery stadium. Good! I hope it is also stable. Old times it was different.
Best regards
Dirk
