Hello, how do I display only the first page slider
Hello, how do I display only the first page sliderPut slider inside custom widget control, padding/margin to 0, and in backend make widget visible just on one page.
Write what CMS you use, you cannot get help with so few words.
I use wordpress, but to raise the template generated by Themleer, I have the slider control does not appear like a widget, where I could control in which page it can be shown.
Sorry if the text is half bad, I'm using the google translator, I am brasilieiro
I use wordpress, but to raise the template generated by Themleer, I have the slider control does not appear like a widget, where I could control in which page it can be shown. Sorry if the text is half bad, I'm using the google translator, I am brasilieiroYou have to insert widget control self and make it. Drag and drop slider inside this widget control.
Other solution is more difficult for a beginner. Use "Customize template" in Posts tab and Sidebars tab - Styling. Then your controls and sliders wil not be shared around.
Hi! How do I change the home page, without installing Themler plugin in Wordpress? I could not find the page to perform the change.
Hi! How do I change the home page, without installing Themler plugin in Wordpress? I could not find the page to perform the change.Hi Jose,
Do you mean that you want to edit Home template manually?
Please try to make changes to the themes/[theme_name]/templates/front_1.php file.
Hi Jose,
Please try to make changes to the <tt>themes/[theme_name]/templates/front_1.php</tt> file.Thank you,
No! necessary that the home page is available for editing in the wordpress admin (like when I export content with artisteer) but can not find the home page in any web Administration place.
> Hi Jose, > > Do you mean that you want to edit Home template manually? > Please try to make changes to the <tt>themes/[theme_name]/templates/front_1.php</tt> file. > > Thank you, > Olivia > No! necessary that the home page is available for editing in the wordpress admin (like when I export content with artisteer) but can not find the home page in any web Administration place.Hello Jose Maria,
1. it is not possible to export Themler theme to ARTX format. But the latest Artisteer version
http://files4.artisteer.com/Artisteer.4.3.0.60858.exe
includes export to Themler WP and Joomla themes.
2.as usually static page or latest post are output at the Home page of WP. You may check your settings under Settings >> Reading in WP admin back end.
If static page is used as home page you'll find it under Pages menu.
