I've tested this on several templates.
When you try and save a design after having entered an email address in to a text area - the save fails and the design is 'restored'
This happens every-time.
Try with this @
instead of @. It is a bug anyway.
This issue was already fixed. Please make sure that you have installed all the updates in the application.
Latest updates applied problem persists.
Latest updates applied problem persists.P.S. Stagger Lee's Fix Doesn't work either.
P.S. Stagger Lee's Fix Doesn't work either.Hi,
Could you please once again, try to create a new template, apply updates, press the Save button, then insert the e-mail address and save again. If that does not help, please provide the step-by-step instruction on how you have inserted the e-mail and what exact e-mail.
a refresh and cache empty and it works fine.
a refresh and cache empty and it works fine.Hello
Ok. Please let us know if you have any other questions/issues.
This issue seems to have started again and no amount of saving and refreshing seems to fix it.
This issue seems to have started again and no amount of saving and refreshing seems to fix it.Hi,
Indeed, seems that issue has appeared in the different controls. Our developers are working to fix it.
I assume that it will be fixed in the next updates.
