Wordpress plugin installation failing
gseluja
gseluja posted this 01 January 2019
I'm getting the following error. Thanks for your help.
Installing Plugin from uploaded file: blank_themler_wordpress_theme.zip
Unpacking the package…
Installing the plugin…
The package could not be installed. No valid plugins were found.
Plugin installation failed.
Hello, I'm getting the following error. Thanks for your help. ---- Installing Plugin from uploaded file: blank_themler_wordpress_theme.zip Unpacking the package… Installing the plugin… The package could not be installed. No valid plugins were found. Plugin installation failed.
Support Team posted this 02 January 2019
Does it happen when you install a theme by uploading it?
Hello, Does it happen when you install a theme by uploading it? Gina Themler Support
gseluja
gseluja posted this 03 January 2019
Hi Gina,
Iit was my error: I was trying to install it as a plugin and not as theme! It's all working now. Thank you.
Best,
Gustavo
> Hello, > Does it happen when you install a theme by uploading it? > > Gina > Themler Support Hi Gina, Iit was my error: I was trying to install it as a plugin and not as theme! It's all working now. Thank you. Best, Gustavo
Support Team posted this 03 January 2019
Thank you for letting us know the result.
Thank you for letting us know the result. Gina Themler Support
