wordpress widgets not working
reha
reha posted this 08 January 2019
Since i update themler to last upgrade, widgets dont work in wordpress admin panel. cannot drag and open widgets.
Support Team posted this 08 January 2019
Hello Ahmet,
I have just re-tested latest Themler with Wordpress and widgets work fine on my end.
Could you please try disabling all plugins in wordpress and re-try?
Do you have WP 5?
Hello Ahmet, I have just re-tested latest Themler with Wordpress and widgets work fine on my end. Could you please try disabling all plugins in wordpress and re-try? Do you have WP 5? Gina Themler Support
reha
reha posted this 09 January 2019
i switched to another theme, worked widgets fine.
Only on themler theme active is not working.
i switched to another theme, worked widgets fine. Only on themler theme active is not working.
Support Team posted this 09 January 2019
What version of Wordpress do you have? Also - is there a corresponding widget area added to the Themler theme so that you can put widgets into it in Wordpress?
Hello, What version of Wordpress do you have? Also - is there a corresponding widget area added to the Themler theme so that you can put widgets into it in Wordpress? Sincerely, Nettie
