Can you please give me the benefits of nicepage instead of themler. I make all my sites with joomla.
Can you please give me the benefits of nicepage instead of themler. I make all my sites with joomla.Hello Kris,
Many Themler users were requesting the simpler design tool and the content editor. We have implemented those requests. Nicepage is fast, intelligent and easy-to-use. It allows creating modern designs based on any source in minutes. You can use an existing website, social network account or even a folder with images to create a modern and unique page just in seconds.
We will be glad if you become Nicepage user in the future.
You can try it out in trial mode first.
But how does it integrate with Joomla? Can it be directly in the Joomla Article? If it's a separate part of the Joomla system it will not integrate with SEO.
A page builder must be able to use the core systems structure to some extent or it will not be a complete solution. Nice looking is a huge fail if it is not structurally correct. Open Graph, Structured Data, Search integration, etc.
But how does it integrate with Joomla? Can it be directly in the Joomla Article? If it's a separate part of the Joomla system it will not integrate with SEO. A page builder must be able to use the core systems structure to some extent or it will not be a complete solution. Nice looking is a huge fail if it is not structurally correct. Open Graph, Structured Data, Search integration, etc.Nicepage is a content builder for Joomla and can creates Joomla articles as any other builders do. Desktop version of Nicepage can create entire site and you can export it as Joomla theme including content. You can try it out in free mode. Please, feel free to contact Nicepage support for more details.
Can free mode save an article in Joomla?
Can free mode save an article in Joomla?So, I want to try this. I want to support you guys and move away from the page builder I am using now. The current one I use does integrate into the Joomla Article but I am not seeing a Nicepage option for this.
I need to create the page in the Nicepage area and then create a menu item for it?
Also the current page builder I use integrates with my Joomla editor so I can format the content. No such option here I can see.
So, I want to try this. I want to support you guys and move away from the page builder I am using now. The current one I use does integrate into the Joomla Article but I am not seeing a Nicepage option for this. I need to create the page in the Nicepage area and then create a menu item for it? Also the current page builder I use integrates with my Joomla editor so I can format the content. No such option here I can see.So I found that after I saved the Nicepage page it was in the Joomla Article area. What I am not sure I like is the massive inline css produced by adding 2 images and a text area.
9,992 lines of css in the source code for this simple layout? Yikes.
So I found that after I saved the Nicepage page it was in the Joomla Article area. What I am not sure I like is the massive inline css produced by adding 2 images and a text area. 9,992 lines of css in the source code for this simple layout? Yikes.And what about the early themler templates i made, can i still changes them or can i change them in nicepage aswell. Is there a "money refund period" because in the free version i can't test it with a joomla site ?
And what about the early themler templates i made, can i still changes them or can i change them in nicepage aswell. Is there a "money refund period" because in the free version i can't test it with a joomla site ?hello dave
hi dave what is the page builder you used to call? SpPage or quixx?
Yes in nicepage there are some line code, but in my test, most important seo factor are speed of pages, quality of contents and the links.
i easy do 99 and 100 in google pagespeed, and similar value in gtmetrix whit nicepage!!!
Nicepage it's fantastic, whit last build joomla_nicepage_plugin-1.0.214 work well whit themler
In some site i use nicepage whit themler, but think it's better to use one or other, for pagespeed and seo
So i continue use themler whit some site, and i use nicepage for clients who need to create pages iself, i give us a client licence of my nicepage ultimate
hello dave > So I found that after I saved the Nicepage page it was in the Joomla Article area. What I am not sure I like is the massive inline css produced by adding 2 images and a text area. > > 9,992 lines of css in the source code for this simple layout? Yikes. hi dave what is the page builder you used to call? SpPage or quixx? Yes in nicepage there are some line code, but in my test, most important seo factor are speed of pages, quality of contents and the links. i easy do 99 and 100 in google pagespeed, and similar value in gtmetrix whit nicepage!!! Nicepage it's fantastic, whit last build joomla_nicepage_plugin-1.0.214 work well whit themler In some site i use nicepage whit themler, but think it's better to use one or other, for pagespeed and seo So i continue use themler whit some site, and i use nicepage for clients who need to create pages iself, i give us a client licence of my nicepage ultimateLast edited 25 January 2019 by Giuma
Thanks for your input. 9K lines of CSS for a tiny layout like this is OK why?
This was supposed to work with Themler, not recreate the wheel.
Thanks for your input. 9K lines of CSS for a tiny layout like this is OK why? This was supposed to work with Themler, not recreate the wheel.hi dave what is the page builder you used to call? SpPage or quixx?
The only one I have used is SP Page Builder and the CSS outside of the global styles was fairly small. They are making it all a file based CSS option now.
I simply want to know they are not a visual only priority end game here.
> hi dave what is the page builder you used to call? SpPage or quixx? The only one I have used is SP Page Builder and the CSS outside of the global styles was fairly small. They are making it all a file based CSS option now. I simply want to know they are not a visual only priority end game here.WHIT NICEPAGE IN JOOMLA
AND JCH OPTIMIZE ENABLE, 99% IN https://gtmetrix.com AND https://developers.google.com/speed/pagespeed/insights/
IN 5 MINUTES
WHIT NICEPAGE IN JOOMLA AND JCH OPTIMIZE ENABLE, 99% IN https://gtmetrix.com AND https://developers.google.com/speed/pagespeed/insights/ IN 5 MINUTESLast edited 25 January 2019 by Giuma
All of my websites, all, are done around custom fields. In that aspect Nicepage is useless.
It is real CMS,. otherways you end learning just to make static websites.
Seems as Nicepage now has Code Control (Custom PHP control) in latest update. Would like to see a video how it works.
https://nicepage.com/blog/detail/19993/nicepage-update-dec-2018
i just repurchased themler;
