I've created the new Theme for wordpress on tomorrow.
When I'm loading Themler and choosing the wordpress, then I see the Themler logo and then - nothing, clear and white page, nothing happens.
Rebooting the PC doesn't affect. Only debug starts.
Last lines in report:
Tue, 29 Jan 2019 19:51:20 +0000: run CMS (wordpress), error = 0, themeName = Untitled
======== End of file C:\ProgramData\Themler\hd_data\themler_1748610238\startup_logs\cms.log ========
ERROR:Unable to find file C:\Users\Tsar\AppData\Roaming..\Local\Themler\ChromeData\chrome_debug.log
I've tried to find this folder, but the way finishes at C:\Users\Tsar\AppData\Roaming\ there is no such folders like higher.
What should I do? I need to finish the project in a short time!
I've created the new Theme for wordpress on tomorrow. When I'm loading Themler and choosing the wordpress, then I see the Themler logo and then - nothing, clear and white page, nothing happens. Rebooting the PC doesn't affect. Only debug starts. Last lines in report: Tue, 29 Jan 2019 19:51:20 +0000: run CMS (wordpress), error = 0, themeName = Untitled ======== End of file C:\ProgramData\Themler\hd_data\themler_1748610238\startup\_logs\cms.log ======== ERROR:Unable to find file C:\Users\Tsar\AppData\Roaming\..\Local\Themler\ChromeData\chrome_debug.log I've tried to find this folder, but the way finishes at C:\Users\Tsar\AppData\Roaming\ there is no such folders like higher. What should I do? I need to finish the project in a short time!Last edited 29 January 2019 by 1123maxi
