after the latest update of Windows 10 I can only start Themler once. After I close the application on a restart I get :
"Wscript.exe application error
The application was unable to start correctly (Ox0000001).
Click OK to close the application."
Could you please attach the log file from the Start >> Themler >> Themler Diagnostics Tool.
INFO:Check free disk space...
INFO:Check Services...
INFO:Check Files...
INFO:Check HTTP Server...
INFO:Check url for C:\PROGRA~3\Themler\hd_data\themler_1252980600
INFO: Check is url available: http://localhost:12080/themler_1252980600/startup
INFO: Check is url available: http://localhost:12080/themler_1252980600/wordpress
INFO: Check is url available: http://localhost:12080/themler_1252980600/joomla
INFO:Check INI Files...
INFO:No errors!
======== Content of file C:\Program Files (x86)\Themler\bin_logs\bat_exec.log ========
Installing ThemlerMySql
1:Service successfully installed.
Starting ThemlerMySql
The ThemlerMySql service is starting...
The ThemlerMySql service was started successfully.
Checking ThemlerMySql
information_schema
Done
ERROR 1049 (42000) at line 1: Unknown database 'wordpressdb'
ERROR 1049 (42000) at line 1: Unknown database 'magentodb'
ERROR 1049 (42000) at line 1: Unknown database 'prestashopdb'
ERROR 1049 (42000) at line 1: Unknown database 'woocommercedb'
The 'ThemlerApache' service is successfully installed.
Starting ThemlerApache
The ThemlerApache service is starting.
The ThemlerApache service was started successfully.
Done
======== End of file C:\Program Files (x86)\Themler\bin_logs\bat_exec.log ========
======== Content of file C:\ProgramData\Themler\logs\Themler_vbs.log ========
Self path = C:\PROGRA~2\Themler\Themler.vbs
Bin dir = C:\PROGRA~2\Themler\bin\
Startup.bat path = C:\PROGRA~2\Themler\bin\startup.bat
Flag isInstallation = True
Program Files 86 folder = C:\Program Files (x86)
Application Data folder = C:\ProgramData
Local Data folder = C:\Users\Paul\AppData\Local
Command to run startup.bat = %SystemRoot%\System32\cmd.exe /c ""C:\PROGRA~2\Themler\bin\startup.bat" _1252980600"
Install CMS...
Set current folder as startup ( C:\ProgramData\Themler\hd_data\themler_1252980600\startup )...
OK
Install HTML...
OK
Install Wordpress...
OK
Install Joomla...
OK
======== End of file C:\ProgramData\Themler\logs\Themler_vbs.log ========
======== Content of file C:\Users\Paul\AppData\Local\Themler\Themler_vbs.log ========
Flag isInstallation = False
Chrome finded at C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
======== End of file C:\Users\Paul\AppData\Local\Themler\Themler_vbs.log ========
======== Content of file C:\ProgramData\Themler\logs\apache\error.log ========
[Fri Aug 07 11:08:12.885243 2015] [mpm_winnt:notice] [pid 4556:tid 940] AH00455: Apache/2.4.12 (Win32) PHP/5.4.42 configured -- resuming normal operations
[Fri Aug 07 11:08:12.885243 2015] [mpm_winnt:notice] [pid 4556:tid 940] AH00456: Server built: Mar 19 2015 18:23:40
[Fri Aug 07 11:08:12.885243 2015] [mpm_winnt:notice] [pid 4556:tid 940] AH80000: Distributed by: The Apache Haus
[Fri Aug 07 11:08:12.885243 2015] [mpm_winnt:notice] [pid 4556:tid 940] AH80001: Compiled with: Visual Studio 2008
[Fri Aug 07 11:08:12.885243 2015] [core:notice] [pid 4556:tid 940] AH00094: Command line: 'C:\PROGRA~2\Themler\bin\apache\bin\hthemlerd.exe -d C:/Program Files (x86)/Themler/bin/apache'
[Fri Aug 07 11:08:12.892446 2015] [mpm_winnt:notice] [pid 4556:tid 940] AH00418: Parent: Created child process 5640
[Fri Aug 07 11:08:13.354029 2015] [mpm_winnt:notice] [pid 5640:tid 548] AH00354: Child: Starting 64 worker threads.
======== End of file C:\ProgramData\Themler\logs\apache\error.log ========
======== Content of file C:\ProgramData\Themler\logs\mysql\error.log ========
150807 11:07:53 [Note] Plugin 'FEDERATED' is disabled.
150807 11:07:53 InnoDB: The InnoDB memory heap is disabled
150807 11:07:53 InnoDB: Mutexes and rw_locks use Windows interlocked functions
150807 11:07:53 InnoDB: Compressed tables use zlib 1.2.3
150807 11:07:53 InnoDB: Initializing buffer pool, size = 256.0M
150807 11:07:53 InnoDB: Completed initialization of buffer pool
InnoDB: The first specified data file C:\PROGRA~3\Themler\db_data\ibdata1 did not exist:
InnoDB: a new database to be created!
150807 11:07:53 InnoDB: Setting file C:\PROGRA~3\Themler\db_data\ibdata1 size to 10 MB
InnoDB: Database physically writes the file full: wait...
150807 11:07:53 InnoDB: Log file C:\PROGRA~3\Themler\db_data\ib_logfile0 did not exist: new to be created
InnoDB: Setting log file C:\PROGRA~3\Themler\db_data\ib_logfile0 size to 256 MB
InnoDB: Progress in MB: 100 200
150807 11:07:56 InnoDB: Log file C:\PROGRA~3\Themler\db_data\ib_logfile1 did not exist: new to be created
InnoDB: Setting log file C:\PROGRA~3\Themler\db_data\ib_logfile1 size to 256 MB
InnoDB: Doublewrite buffer not found: creating new
InnoDB: Doublewrite buffer created
InnoDB: 127 rollback segment(s) active.
InnoDB: Creating foreign key constraint system tables
InnoDB: Foreign key constraint system tables created
150807 11:07:57 InnoDB: Waiting for the background threads to start
150807 11:07:58 InnoDB: 5.5.42 started; log sequence number 0
150807 11:07:58 [Note] Server hostname (bind-address): '0.0.0.0'; port: 12306
150807 11:07:58 [Note] - '0.0.0.0' resolves to '0.0.0.0';
150807 11:07:58 [Note] Server socket created on IP: '0.0.0.0'.
150807 11:07:58 [Note] Event Scheduler: Loaded 0 events
150807 11:07:58 [Note] C:\PROGRA~2\Themler\bin\mysql\bin\mythemlerd.exe: ready for connections.
Version: '5.5.42-log' socket: '' port: 12306 MySQL Community Server (GPL)
======== End of file C:\ProgramData\Themler\logs\mysql\error.log ========
SUCCESS!
Please copy content and send it to our support team!
Please try to open the following link in Chrome directly:
I ran CCleaner to fix this issue on Windows 10 and it worked.. it was something hung in the registry
I ran CCleaner to fix this issue on Windows 10 and it worked.. it was something hung in the registryHi,
Nice to hear, that it helped. If the problem persists, please try to run some basic script for testing purpose. Something like explained in the link below:
http://www.wikihow.com/Program-with-VBScript
CCleaner registry cleaner you mean.
I ran yesterday "reghunter" and since then the windows program works again.
So I can confirm it most likely is an issue where some item in the registry created the problem.
Sounds good, thanks for the feedback. Please let us know if you need our further help.
hi, i need support please, themler not running for my pc, win 8.1 single, error:
Please wait...Themler Diagnostics Log
Please create a new support topic at 'http://answers.themler.com' and attach this log to your ticket.
INFO:Version files finded:
INFO: C:\PROGRA~3\Themler\1.0.319.25.ver
ERROR:Apache service isn't started
INFO:Check Files...
INFO:Check url for C:\PROGRA~3\Themler\hd_data\themler_1058051700
INFO: Check is url available: http://localhost:12080/themler_1058051700/startup
ERROR:HTTP request to 'http://localhost:12080/themler_1058051700/startup' throw error:'No es posible conectar con el servidor remoto'
INFO:No errors!
Program files detected C:\Program Files (x86)
Must be on program files\themler\bin
El volumen de la unidad C es Windows
El n�mero de serie del volumen es: DE6A-7289
Directorio de C:\Program Files (x86)\Themler\bin
07/11/2016 12:12 a.m. <dir> .
07/11/2016 12:12 a.m. <dir> ..
07/11/2016 12:12 a.m. <dir> 7zip
07/11/2016 12:12 a.m. <dir> apache
07/11/2016 12:12 a.m. <dir> diagnostics
22/06/2016 06:18 a.m. 1,402 install-apache.bat
22/06/2016 06:18 a.m. 2,724 install-mysql.bat
07/11/2016 12:12 a.m. <dir> mysql
07/11/2016 12:12 a.m. <dir> php
22/06/2016 06:18 a.m. 1,730 uninstall-apache.bat
22/06/2016 06:18 a.m. 1,695 uninstall-mysql.bat
07/11/2016 12:12 a.m. <dir> _logs
4 archivos 7,551 bytes
8 dirs 834,442,612,736 bytes libres
creating logs just in case
Ya existe el subdirectorio o el archivo C
8 dirs 833,647,861,760 bytes libres
ERROR:Unable to find file C:\ProgramData\Themler\logs\Themler_vbs.log
ERROR:Unable to find file C:\Users\HP\AppData\Local\Themler\Themler_vbs.log
======== Content of file C:\ProgramData\Themler\logs\startup.php.log ========
Mon, 07 Nov 2016 06:17:45 +0000
run from browser =
suffix = _1058051700
themlerDataPath = C:/ProgramData/Themler
icPath = C:/ProgramData/Themler/hd_data/themler_1058051700
url = http://127.0.0.1:12080/themler_1058051700
versionFile not exists
UnZip successful, target directory exists
Replace common.php result is 3930
======== End of file C:\ProgramData\Themler\logs\startup.php.log ========
AH00558: hthemlerd.exe: Could not reliably determine the server's fully qualified domain name, using fe80::7d97:b3c9:d47a:7c9c. Set the 'ServerName' directive globally to suppress this message
[Mon Nov 07 00:17:42.606977 2016] [mpm_winnt:notice] [pid 6944:tid 892] AH00455: Apache/2.4.16 (Win32) PHP/5.4.42 configured -- resuming normal operations
[Mon Nov 07 00:17:42.606977 2016] [mpm_winnt:notice] [pid 6944:tid 892] AH00456: Server built: Jul 13 2015 10:37:15
[Mon Nov 07 00:17:42.606977 2016] [core:notice] [pid 6944:tid 892] AH00094: Command line: 'C:\Program Files (x86)\Themler\bin\apache\bin\hthemlerd.exe -d C:/Program Files (x86)/Themler/bin/apache'
[Mon Nov 07 00:17:42.606977 2016] [mpm_winnt:notice] [pid 6944:tid 892] AH00418: Parent: Created child process 6864
[Mon Nov 07 00:17:43.834480 2016] [mpm_winnt:notice] [pid 6864:tid 872] AH00354: Child: Starting 64 worker threads.
[Mon Nov 07 00:19:50.310996 2016] [mpm_winnt:notice] [pid 6944:tid 892] AH00422: Parent: Received shutdown signal -- Shutting down the server.
[Mon Nov 07 00:20:03.514758 2016] [mpm_winnt:notice] [pid 6864:tid 872] AH00364: Child: All worker threads have exited.
[Mon Nov 07 00:20:12.965355 2016] [mpm_winnt:notice] [pid 6944:tid 892] AH00430: Parent: Child process 6864 exited successfully.
[Mon Nov 07 00:21:23.692582 2016] [mpm_winnt:notice] [pid 2456:tid 916] AH00455: Apache/2.4.16 (Win32) PHP/5.4.42 configured -- resuming normal operations
[Mon Nov 07 00:21:23.708208 2016] [mpm_winnt:notice] [pid 2456:tid 916] AH00456: Server built: Jul 13 2015 10:37:15
[Mon Nov 07 00:21:23.708208 2016] [core:notice] [pid 2456:tid 916] AH00094: Command line: 'C:\Program Files (x86)\Themler\bin\apache\bin\hthemlerd.exe -d C:/Program Files (x86)/Themler/bin/apache'
[Mon Nov 07 00:21:23.739460 2016] [mpm_winnt:notice] [pid 2456:tid 916] AH00418: Parent: Created child process 3008
[Mon Nov 07 00:21:25.036398 2016] [mpm_winnt:notice] [pid 3008:tid 728] AH00354: Child: Starting 64 worker threads.
[Mon Nov 07 00:25:11.659749 2016] [mpm_winnt:notice] [pid 2456:tid 916] AH00428: Parent: child process 3008 exited with status 1 -- Restarting.
[Mon Nov 07 00:25:12.206647 2016] [mpm_winnt:notice] [pid 2456:tid 916] AH00455: Apache/2.4.16 (Win32) PHP/5.4.42 configured -- resuming normal operations
[Mon Nov 07 00:25:12.206647 2016] [mpm_winnt:notice] [pid 2456:tid 916] AH00456: Server built: Jul 13 2015 10:37:15
[Mon Nov 07 00:25:12.206647 2016] [core:notice] [pid 2456:tid 916] AH00094: Command line: 'C:\Program Files (x86)\Themler\bin\apache\bin\hthemlerd.exe -d C:/Program Files (x86)/Themler/bin/apache'
[Mon Nov 07 00:25:12.237899 2016] [mpm_winnt:notice] [pid 2456:tid 916] AH00418: Parent: Created child process 4192
[Mon Nov 07 00:25:14.503634 2016] [mpm_winnt:notice] [pid 4192:tid 876] AH00354: Child: Starting 64 worker threads.
[Mon Nov 07 00:25:19.941401 2016] [mpm_winnt:crit] [pid 4192:tid 876] AH02538: Child: Parent process exited abruptly. Child process is ending
[Mon Nov 07 00:25:19.941401 2016] [mpm_winnt:warn] [pid 4192:tid 848] (OS 995)La operaci�n de E/S se anul� por una salida de subproceso o por una solicitud de aplicaci�n. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Mon Nov 07 00:25:20.003904 2016] [mpm_winnt:warn] [pid 4192:tid 1452] (OS 995)La operaci�n de E/S se anul� por una salida de subproceso o por una solicitud de aplicaci�n. : AH00341: winnt_accept: Asynchronous AcceptEx failed.
[Mon Nov 07 00:25:22.050881 2016] [mpm_winnt:notice] [pid 4192:tid 876] AH00364: Child: All worker threads have exited.
======== Content of file C:\ProgramData\Themler\logs\apache\access.log ========
::1 - - [07/Nov/2016:00:18:08 -0600] "GET /themler_1058051700/startup HTTP/1.1" 301 258 0 mis
::1 - - [07/Nov/2016:00:18:08 -0600] "GET /themler_1058051700/startup/ HTTP/1.1" 200 30311 124670 mis
::1 - - [07/Nov/2016:00:19:12 -0600] "GET /themler_1058051700/startup HTTP/1.1" 301 258 0 mis
::1 - - [07/Nov/2016:00:19:12 -0600] "GET /themler_1058051700/startup/ HTTP/1.1" 200 30311 15627 mis
======== End of file C:\ProgramData\Themler\logs\apache\access.log ========
161107 0:13:27 [Note] Plugin 'FEDERATED' is disabled.
161107 0:13:31 InnoDB: The InnoDB memory heap is disabled
161107 0:13:31 InnoDB: Mutexes and rw_locks use Windows interlocked functions
161107 0:13:31 InnoDB: Compressed tables use zlib 1.2.3
161107 0:13:32 InnoDB: Initializing buffer pool, size = 256.0M
161107 0:13:32 InnoDB: Completed initialization of buffer pool
Have you tried the following suggestions?
