Creating Themler template in Artisteer
support51
support51 posted this 07 August 2015
I found it best to open and theme in Artisteer, then inlarge the sheet size to 100 % and check alignment of header and text, then save as an themler template with the same name and content.
If not, when you open and even update the template all alignments are off!
Also found that I'm unable to import and HTML created template zip from Artisteer to Themler, while in the HTML Mode, Works great In word press more.
Now I'm not complaining, just a heads up for you investigate and or advise user of these work arounds for now!
I have done a few already and they look great in the live preview,!
Using the latest version of both!
Windows Pro.
Note if they try to import the HTML created zip, the themler it will lock up! So it is advise to import the zip, in the Word Press mode, and then they can save or export as desire from the Themler! :)
testing is what I do! :)
Dave
I found it best to open and theme in Artisteer, then inlarge the sheet size to 100 % and check alignment of header and text, then save as an themler template with the same name and content. If not, when you open and even update the template all alignments are off! Also found that I'm unable to import and HTML created template zip from Artisteer to Themler, while in the HTML Mode, Works great In word press more. Now I'm not complaining, just a heads up for you investigate and or advise user of these work arounds for now! I have done a few already and they look great in the live preview,! Using the latest version of both! Windows Pro. **Note** if they try to import the HTML created zip, the themler it will lock up! So it is advise to import the zip, in the Word Press mode, and then they can save or export as desire from the Themler! :) testing is what I do! :) regards, Dave
Support Team posted this 11 August 2015
Hello David,
1. Do you mean that alignment is broken in Artisteer or Themler theme? I haven't encountered such issues neither with Artisteer nor with Themler. Could you please provide a sample theme which demonstrate this problem?
  1. the HTML site created with Artisteer and Themler have different structure and you cannot import HTML template created with Artisteer into Themler.
    The latest version of Artisteer allows exporting Artisteer template into Themler WordPress theme and Themler Joomla theme.
    You may download it from
    http://files4.artisteer.com/Artisteer.4.3.0.60858.exe
http://answers.themler.com/articles/19107/new-themler-desktop-installation-v1-0-59-is-available
Hello David, 1. Do you mean that alignment is broken in Artisteer or Themler theme? I haven't encountered such issues neither with Artisteer nor with Themler. Could you please provide a sample theme which demonstrate this problem? 2. the HTML site created with Artisteer and Themler have different structure and you cannot import HTML template created with Artisteer into Themler. The latest version of Artisteer allows exporting Artisteer template into Themler WordPress theme and Themler Joomla theme. You may download it from http://files4.artisteer.com/Artisteer.4.3.0.60858.exe http://answers.themler.com/articles/19107/new-themler-desktop-installation-v1-0-59-is-available
