Hanging Indents on Lists
peter.james2
peter.james2 posted this 07 August 2015
How do I get hanging indents into unordered (and ordered) lists? The 2nd line of an li element starts right under the bullet image of the line above and it should start right under the start of the text.
Many thanks...Peter
How do I get hanging indents into unordered (and ordered) lists? The 2nd line of an li element starts right under the bullet image of the line above and it should start right under the start of the text. Many thanks...Peter
69 Comments
Support Team posted this 11 August 2015
Hello Peter,
please refer to the following posts
http://answers.themler.com/questions/3005/themler-lining-up-bullet-and-ordered-lists
http://answers.themler.com/questions/4688/themler-format-text-indent-text-in-bullets-and-numbers
They should be helpful
Hello Peter, please refer to the following posts http://answers.themler.com/questions/3005/themler-lining-up-bullet-and-ordered-lists http://answers.themler.com/questions/4688/themler-format-text-indent-text-in-bullets-and-numbers They should be helpful Regards, Aileen
joe71
joe71 posted this 14 August 2015
I am having the same issue whereby the second line of text lines up under the bullet and not the text above.
I have set the margin to "0" and it has no effect.
Your second link in this post 4688 is a dead link "Page Not Found"
Joe
I am having the same issue whereby the second line of text lines up under the bullet and not the text above. I have set the margin to "0" and it has no effect. Your second link in this post 4688 is a dead link "Page Not Found" Regards, Joe
Support Team posted this 17 August 2015
Hello Joe,
I've just checked and the second link is working.
Please try to open it once more and follow the suggestion provided there. If you cannot make it working please create a new private topic and provide access to your cCMS admin back end and note the page which demonstrates the issue.
Hello Joe, I've just checked and the second link is working. Please try to open it once more and follow the suggestion provided there. If you cannot make it working please create a new private topic and provide access to your cCMS admin back end and note the page which demonstrates the issue. regards, Aileen
peter.james
peter.james posted this 17 August 2015
I am getting 'Page Not Found' as well on the second link.
I still have not been able to get hanging indents working - see http://signjobs.london/a-career-in-the-sign-industry/.
What I want it to look like is this (i.e. hanging index is working in bullets on this forum)...
  • If I keep on typing it should wrap around so that the second line text starts directly below the point where the first line text starts and not below the bullet so it is working properly here even though it doesn't show properly in the post editor.
I have attached a clip from a Word document to show exactly how I want it (and how it works on Artisteer and others).
How do we make this work properly?
Many thanks...Peter
I am getting 'Page Not Found' as well on the second link. I still have not been able to get hanging indents working - see http://signjobs.london/a-career-in-the-sign-industry/. What I want it to look like is this (i.e. hanging index is working in bullets on this forum)... - If I keep on typing it should wrap around so that the second line text starts directly below the point where the first line text starts and not below the bullet so it is working properly here even though it doesn't show properly in the post editor. I have attached a clip from a Word document to show exactly how I want it (and how it works on Artisteer and others). How do we make this work properly? Many thanks...Peter
Support Team posted this 19 August 2015
Hello Peter,
please follow the article
http://answers.themler.com/articles/21538/bullet-list-layout
The other way is to edit the CSS code in style.css file
.bd-bulletlist li, .bd-tagstyles:not(.bd-custom-bulletlist):not(.shape-only) ul li {
    text-indent: -10px;
    margin-left: 10px;
Please note that the last option is not applicable if you will edit the theme in Themler in future.
Hello Peter, please follow the article http://answers.themler.com/articles/21538/bullet-list-layout The other way is to edit the CSS code in style.css file .bd-bulletlist li, .bd-tagstyles:not(.bd-custom-bulletlist):not(.shape-only) ul li { ... text-indent: -10px; margin-left: 10px; } Please note that the last option is not applicable if you will edit the theme in Themler in future. regards, Aileen
NFV
NFV posted this 20 August 2015
In my opinion the unit px is not good because if the font size will be change the indent seems wrong. I get the best results with a value of 1 and the unit em.
And NEVER do it in the generated css file. Do it as described here: http://answers.themler.com/articles/21538/bullet-list-layout (with 1em instead 10px)
In my opinion the unit px is not good because if the font size will be change the indent seems wrong. I get the best results with a value of 1 and the unit em. And NEVER do it in the generated css file. Do it as described here: http://answers.themler.com/articles/21538/bullet-list-layout (with 1em instead 10px)
peter.james
peter.james posted this 20 August 2015
Thanks Support Team
I tried this yesterday and it worked fine although I had to put back the padding (removal recommended in another referenced post).
NFV's comment about using em instead of px is great advice - thanks!
My only comment is that it ought to come out of the box like this as that is how most people want ul mult-line li's to look like.
Anyway, an easy and effective fix - thanks!
Kind regards...Peter
Thanks Support Team I tried this yesterday and it worked fine although I had to put back the padding (removal recommended in another referenced post). NFV's comment about using em instead of px is great advice - thanks! My only comment is that it ought to come out of the box like this as that is how most people want ul mult-line li's to look like. Anyway, an easy and effective fix - thanks! Kind regards...Peter
chinahousehold
chinahousehold posted this 22 January 2026
https://biolinku.co/bothbest
https://glasp.co/bothbest
https://o4ezhzklmi55thxs.umso.co/
https://ieee-dataport.org/authors/bamboo-flooring
https://kingschat.online/user/bothbest
https://kingschat.online/post/Q0tpQjJ
https://kingschat.online/post/VldONk5
https://gitflic.ru/user/bothbest
https://amazingradio.com/profile/bothbest
https://portal.stem.edu.gr/en/profile/chinahousehold/
https://www.ekademia.com/@bambooflooring
https://twchess.lionfree.net/discuz/home.php?mod=space&uid=89012
http://infest.exe.in.th/board/home.php?mod=space&uid=55420
https://www.play56.net/home.php?mod=space&uid=5941666
https://teachingartists.com/members/bothbest/
https://artelis.pl/autor/profil/237162
https://getfoureyes.com/s/7Q4gD/
https://getfoureyes.com/s/aQagC/
https://mirrorliar.com/portfolios/bothbest
https://yoomark.com/content/bothbest-china-bamboo-flooring-supplier-2001
https://yoomark.com/node/1466426
https://yoomark.com/user/3781979
https://bbs.mychat.to/user.php?uid=1223138
https://www.datascienceportfol.io/chinahousehold
https://www.datascienceportfol.io/chinahousehold/projects/0
https://whatson.plus/bothbest
https://whatson.plus/posts/88778
https://whatson.plus/blogs/88779/Why-Dealers-Prefer-Strand-Woven-Bamboo-from-China-Top-Brands
http://forum.vodobox.com/profile.php?id=58210
https://joripress.com/profile/bothbest
https://forum.biblepay.org/index.php?action=profile;area=summary;u=38010
https://www.thefreeadforum.com/postclassifieds/for-sale/home-furniture-garden-supplies/classifieds_for_free/tiger-stranded-bamboo-flooring_i6291363/classifieds-for-free/los-angeles
https://www.rcmx.net/userinfo.php?uid=12726
https://www.designdekko.com/people/bothbest
https://www.kotplanet.be/nl/members/bothbest/profile/
https://docs.datananas.com/discuss/6970391c0d075a6d0783acfb
https://www.homepros411.com/blog/moisture-resistance-in-strand-woven-bamboo-what-you-should-know
https://utas.me/bothbest/the-most-successful-bamboo-flooring-projects-around-the-world-sjuzcmin/1
https://jsfiddle.net/bothbest/Leyrm7d9/
https://www.hssolar.cn/news-42.html
https://www.thesims3.com/myBlog.html?persona=bamboo2026000&month=01&year=2026
https://zybuluo.com/bothbest/note/2647868
https://go.bubbl.us/ef9630/b929?/Bamboo-flooring-has-gained
https://plaza.rakuten.co.jp/hssolar/diary/202601210000/
https://biolinku.co/bothbest https://glasp.co/bothbest https://o4ezhzklmi55thxs.umso.co/ https://ieee-dataport.org/authors/bamboo-flooring https://kingschat.online/user/bothbest https://kingschat.online/post/Q0tpQjJ https://kingschat.online/post/VldONk5 https://gitflic.ru/user/bothbest https://amazingradio.com/profile/bothbest https://portal.stem.edu.gr/en/profile/chinahousehold/ https://www.ekademia.com/@bambooflooring https://twchess.lionfree.net/discuz/home.php?mod=space&uid=89012 http://infest.exe.in.th/board/home.php?mod=space&uid=55420 https://www.play56.net/home.php?mod=space&uid=5941666 https://teachingartists.com/members/bothbest/ https://artelis.pl/autor/profil/237162 https://getfoureyes.com/s/7Q4gD/ https://getfoureyes.com/s/aQagC/ https://mirrorliar.com/portfolios/bothbest https://yoomark.com/content/bothbest-china-bamboo-flooring-supplier-2001 https://yoomark.com/node/1466426 https://yoomark.com/user/3781979 https://bbs.mychat.to/user.php?uid=1223138 https://www.datascienceportfol.io/chinahousehold https://www.datascienceportfol.io/chinahousehold/projects/0 https://whatson.plus/bothbest https://whatson.plus/posts/88778 https://whatson.plus/blogs/88779/Why-Dealers-Prefer-Strand-Woven-Bamboo-from-China-Top-Brands http://forum.vodobox.com/profile.php?id=58210 https://joripress.com/profile/bothbest https://forum.biblepay.org/index.php?action=profile;area=summary;u=38010 https://www.thefreeadforum.com/postclassifieds/for-sale/home-furniture-garden-supplies/classifieds_for_free/tiger-stranded-bamboo-flooring_i6291363/classifieds-for-free/los-angeles https://www.rcmx.net/userinfo.php?uid=12726 https://www.designdekko.com/people/bothbest https://www.kotplanet.be/nl/members/bothbest/profile/ https://docs.datananas.com/discuss/6970391c0d075a6d0783acfb https://www.homepros411.com/blog/moisture-resistance-in-strand-woven-bamboo-what-you-should-know https://utas.me/bothbest/the-most-successful-bamboo-flooring-projects-around-the-world-sjuzcmin/1 https://jsfiddle.net/bothbest/Leyrm7d9/ https://www.hssolar.cn/news-42.html https://www.thesims3.com/myBlog.html?persona=bamboo2026000&month=01&year=2026 https://zybuluo.com/bothbest/note/2647868 https://go.bubbl.us/ef9630/b929?/Bamboo-flooring-has-gained https://plaza.rakuten.co.jp/hssolar/diary/202601210000/
salvimkelvot
salvimkelvot posted this 22 July 2026
You can create hanging indents in unordered and ordered lists by adjusting the CSS for the li element. A common approach is to add a left padding and then apply a negative text-indent, for example: li { padding-left: 1.5em; text-indent: -1.5em; }, which keeps wrapped lines aligned neatly under the beginning of the text instead of beneath the bullet or number. You may need to fine-tune the values depending on your font and list style, but this method works well in most cases. If you're organizing or validating content alongside your lists, a compare two lists tool can also be helpful for spotting differences between text entries efficiently.
You can create hanging indents in unordered and ordered lists by adjusting the CSS for the li element. A common approach is to add a left padding and then apply a negative text-indent, for example: li { padding-left: 1.5em; text-indent: -1.5em; }, which keeps wrapped lines aligned neatly under the beginning of the text instead of beneath the bullet or number. You may need to fine-tune the values depending on your font and list style, but this method works well in most cases. If you're organizing or validating content alongside your lists, a [compare two lists][1] tool can also be helpful for spotting differences between text entries efficiently. [1]: https://comparingtwolists.com/
povage2116
povage2116 posted this 07 September 2026
Hi mate, .This was an excellent page for such a complicated topic to talk about. I look forward to reading many more excellent posts like this one. Thanks win 79
Hi mate, .This was an excellent page for such a complicated topic to talk about. I look forward to reading many more excellent posts like this one. Thanks [win 79](https://win79vip.blog/)
xeniko8001
xeniko8001 posted this 08 September 2026
Someone essentially lend a hand to make critically articles I’d state. That is the first time I frequented your website page and so far? I amazed with the research you made to create this actual post extraordinary. Wonderful activity! m88vin.pics
Someone essentially lend a hand to make critically articles I’d state. That is the first time I frequented your website page and so far? I amazed with the research you made to create this actual post extraordinary. Wonderful activity! [url=https://m88vin.pics/]m88vin.pics[/url]
helelox259
helelox259 posted this 08 September 2026
Love to read it,Waiting For More new Update and I Already Read your Recent Post its Great Thanks. kubets.app
Love to read it,Waiting For More new Update and I Already Read your Recent Post its Great Thanks. [kubets.app](https://kubets.app/)
posis73412
posis73412 posted this 08 September 2026
hello!! Very interesting discussion glad that I came across such informative post. Keep up the good work friend. Glad to be part of your net community. hello88.business
hello!! Very interesting discussion glad that I came across such informative post. Keep up the good work friend. Glad to be part of your net community. [url=https://hello88.business/]hello88.business[/url]
povage2116
povage2116 posted this 10 September 2026
assisted living is nice if you got some people and a home that cares very much to its occupants.. IndoCair Login
assisted living is nice if you got some people and a home that cares very much to its occupants.. [IndoCair Login](https://indocairjp.com/indocair-login/)
gemico9251
gemico9251 posted this 10 September 2026
i really love a good read like, please keep us updated with info. link slot
i really love a good read like, please keep us updated with info. [link slot](https://purehealsphere.online/slot-gacor-featured-slots/)
satven7
satven7 posted this 10 September 2026
Professional Quantity Takeoff Services provide accurate material quantities and detailed cost breakdowns for construction projects.
They help contractors reduce waste, control budgets, and prepare competitive bids.
Accurate takeoffs save time and improve the overall profitability of construction projects.
Professional **[Quantity Takeoff Services][1]** provide accurate material quantities and detailed cost breakdowns for construction projects. They help contractors reduce waste, control budgets, and prepare competitive bids. Accurate takeoffs save time and improve the overall profitability of construction projects. [1]: https://fkelectricalestimatings.com/services/low-voltage-estimating/
tajogej112
tajogej112 posted this 13 September 2026
Immediately the website might irrefutably obtain famous one of the most associated with publishing customers, due to the persistent articles or just crucial evaluations. slot
Immediately the website might irrefutably obtain famous one of the most associated with publishing customers, due to the persistent articles or just crucial evaluations. [slot](https://www.slot.com/)
xeniko8001
xeniko8001 posted this 14 September 2026
Very great post. I simply stumbled upon your weblog and wanted to say that I’ve truly enjoyed surfing around your weblog posts. In any case I will be subscribing for your rss feed and I hope you write once more very soon! zippo99
Very great post. I simply stumbled upon your weblog and wanted to say that I’ve truly enjoyed surfing around your weblog posts. In any case I will be subscribing for your rss feed and I hope you write once more very soon! [url=https://www.bloominglovelyflowers.com/]zippo99[/url]
povage2116
povage2116 posted this 14 September 2026
That is the appropriate blog for anyone who wants to find out about this topic. You realize a lot its nearly arduous to argue with you (not that I really would need…HaHa). You definitely put a brand new spin on a subject thats been written about for years. Nice stuff, just nice! slot dana
That is the appropriate blog for anyone who wants to find out about this topic. You realize a lot its nearly arduous to argue with you (not that I really would need…HaHa). You definitely put a brand new spin on a subject thats been written about for years. Nice stuff, just nice! [slot dana](https://apk.slotdana.co.uk/)
xeniko8001
xeniko8001 posted this 15 September 2026
The the next occasion I read a blog, I really hope who’s doesnt disappoint me around this one. What i’m saying is, I know it was my substitute for read, but I actually thought youd have something fascinating to say. All I hear is often a few whining about something you could fix if you ever werent too busy searching for attention.dewa33 login
The the next occasion I read a blog, I really hope who’s doesnt disappoint me around this one. What i’m saying is, I know it was my substitute for read, but I actually thought youd have something fascinating to say. All I hear is often a few whining about something you could fix if you ever werent too busy searching for attention.[url=https://novodoba.org/]dewa33 login[/url]
