I have themler installed on two sites, both Joomla/ VirtueMart.
Everything have always worked fine with themler, but now when I click edit template in Joomla backend, themler doesn’t start on either page, just loads a blank page then a pop up says “Retry?” if I click ok it pops up again, if I click cancel I get “Sorry, an error has occurred. Please clear your browser cache.”
I have tried everything on this list:
( https://answers.themler.io/articles/65488/troubleshooting-read-first )
Disable CMS plugins/modules/components
Disable antivirus, firewall.
Disable browser extensions/add-ons.
HTTP/HTTPS. – both backend and front end is HTTPS
Check folder permissions.
I have also tried this :
( https://answers.themler.io/articles/65513/themler-themes-issues-joomla-virtuemart )
Akeeba Admin Tools – off
JHtml::_ ( 'behavior.modal' ); // for SqueezeBox
But it still doesn’t work...
Even if I install a new blank themler template, or export a new zip template from Themler desktop version, and installs in in joomla… it is still the same…
I really need some help because I have to make changes to the sites.
I Really appreciate all help I can get.
Thomas
I have themler installed on two sites, both Joomla/ VirtueMart. Everything have always worked fine with themler, but now when I click edit template in Joomla backend, themler doesn’t start on either page, just loads a blank page then a pop up says “Retry?” if I click ok it pops up again, if I click cancel I get “Sorry, an error has occurred. Please clear your browser cache.” **I have tried everything on this list:** ( https://answers.themler.io/articles/65488/troubleshooting-read-first ) Disable CMS plugins/modules/components Disable antivirus, firewall. Disable browser extensions/add-ons. HTTP/HTTPS. – both backend and front end is HTTPS Check folder permissions. **I have also tried this :** ( https://answers.themler.io/articles/65513/themler-themes-issues-joomla-virtuemart ) Akeeba Admin Tools – off JHtml::_ ( 'behavior.modal' ); // for SqueezeBox But it still doesn’t work... Even if I install a new blank themler template, or export a new zip template from Themler desktop version, and installs in in joomla… it is still the same… I really need some help because I have to make changes to the sites. **I Really appreciate all help I can get.** Thank you Thomas
