Edit CSS in Joomla
N.K.
N.K. posted this 24 May 2019
Hallo,
why cant i edit or add css code in Joomla thats realy annoying to edit other extensions and modules.
(Joomla/Extensions/Templates/ Templates/"MyTemplate"/CSS/Template.css)
The only way i can add code right now is by putting it via Themler and export it with the Template but after that i cant edit that code again. And to always Export-> Install to change code is annoying tbh.
Is there a way that changes in Template.css really affect the template (in Joomla)?
Do i miss something?
Thanks.
Hallo, why cant i edit or add css code in Joomla thats realy annoying to edit other extensions and modules. (Joomla/Extensions/Templates/ Templates/"MyTemplate"/CSS/Template.css) The only way i can add code right now is by putting it via Themler and export it with the Template but after that i cant edit that code again. And to always Export-> Install to change code is annoying tbh. Is there a way that changes in Template.css really affect the template (in Joomla)? Do i miss something? Thanks.
20 Comments
Support Team posted this 24 May 2019
Hello Nico,
There is no restriction from Themler side to edit template.css directly in Joomla admin panel.
Check if your user has enough permissions, or the folder with templates allows editing.
Hello Nico, There is no restriction from Themler side to edit template.css directly in Joomla admin panel. Check if your user has enough permissions, or the folder with templates allows editing. Gina Themler Support
N.K.
Hello Gina,
if i change template.css (with permission - super user or via ftp) nothing changes. Which file should I change? Even if I delete everything nothing changes.
Thanks.
Nico
Hello Gina, if i change template.css (with permission - super user or via ftp) nothing changes. Which file should I change? Even if I delete everything nothing changes. Thanks. Nico
Vitaliy WD
Is Solution
Vitaliy WD posted this 24 May 2019
Hello Gina,
Thanks.
Nico
Try template.min.css
But the best way is to add custom css at Themler backend, then Save&Publish it.
> Hello Gina, > if i change template.css (with permission - super user or via ftp) nothing changes. Which file should I change? Even if I delete everything nothing changes. > > Thanks. > Nico Try `template.min.css` But the best way is to add custom css at Themler backend, then Save&Publish it.
Support Team posted this 25 May 2019
If the changes are still in template.css after you save the file, but they are not reflected on the site, it may be due to cache. Sometimes that site gets heavily cached by the browser you use or Joomla in general (clear cache in admin panel).
If the changes are still in template.css after you save the file, but they are not reflected on the site, it may be due to cache. Sometimes that site gets heavily cached by the browser you use or Joomla in general (clear cache in admin panel). Gina Themler Support
irisbitter83
irisbitter83 posted this 08 July 2024
Please accept my sincere gratitude for providing such a wonderful essay. On your website, I was able to locate the information that I need. geometry dash
Please accept my sincere gratitude for providing such a wonderful essay. On your website, I was able to locate the information that I need. [geometry dash][1] [1]: https://geometry-dashonline.io
foodlenyt88
foodlenyt88 posted this 16 November 2024
Great blog. Reading your articles was fun. This book was fun for me run 3. I've bookmarked it and want to read more. Continue your great work!
Great blog. Reading your articles was fun. This book was fun for me [run 3][1]. I've bookmarked it and want to read more. Continue your great work! [1]: https://runaway3d.io
jahowil360
jahowil360 posted this 14 February 2025
Try adding custom CSS via the Joomla Template Manager (Extensions > Templates > Styles > [Your Template] > Custom Code) or use a child theme to prevent the need for repeated exports. Ensure that caching is disabled to see changes immediately.
CapCut Pro Apk
Try adding custom CSS via the Joomla Template Manager (Extensions > Templates > Styles > [Your Template] > Custom Code) or use a child theme to prevent the need for repeated exports. Ensure that caching is disabled to see changes immediately. [CapCut Pro Apk ][1] [1]: http://capcutmodapks.org
bitlifemodapk3
bitlifemodapk3 posted this 17 February 2025
Download Minecraft APK (MOD, Immortality) - is an Android game that takes minecraft apk download v1.17.200 free players into a world of endless creativity and adventure. It’s a place where there are no limits
Download Minecraft APK (MOD, Immortality) - is an Android game that takes [minecraft apk download v1.17.200 free][1] players into a world of endless creativity and adventure. It’s a place where there are no limits [1]: https://minecraftapk12.com/
bitlifemodapk3
YouTube ReVanced APK is the ultimate ad-free YouTube mod.tiktok revanced apk Get background play, download capabilities, returned dislikes, SponsorBlock, and more.
YouTube ReVanced APK is the ultimate ad-free YouTube mod.[tiktok revanced apk][1] Get background play, download capabilities, returned dislikes, SponsorBlock, and more. [1]: https://revanced.su/
muzikkon.info
muzikkon.info posted this 26 June 2025
Totally get your frustration—editing Joomla templates shouldn't feel harder than tuning Celtic harps!
Totally get your frustration—editing Joomla templates shouldn't feel harder than tuning [Celtic harps][1]! [1]: https://www.muzikkon.com/pages/harps
eja.ge.r.m
eja.ge.r.m posted this 01 August 2025
Hallo! It sounds like you're facing a common Joomla frustration when trying to directly edit CSS files like template.css. Here are a few things to check and try to make your edits stick jjjt login — just like how smooth updates are essential in apps like jjjt game apk:
Hallo! It sounds like you're facing a common Joomla frustration when trying to directly edit CSS files like template.css. Here are a few things to check and try to make your edits stick [jjjt login][1] — just like how smooth updates are essential in apps like jjjt game apk: [1]: https://apkluck.com/jjjt-game/
buddarandco
buddarandco posted this 07 September 2025
Mantenerte informado sobre tu vehículo es fácil con RUNT Por Placa. Ingresa la matrícula y accede a información actualizada del RUNT, incluyendo historial, datos técnicos y situación jurídica, todo desde la comodidad de tu dispositivo.
Mantenerte informado sobre tu vehículo es fácil con [RUNT Por Placa][1]. Ingresa la matrícula y accede a información actualizada del RUNT, incluyendo historial, datos técnicos y situación jurídica, todo desde la comodidad de tu dispositivo. [1]: https://runt-por-placa.org/
buddarandco
Disfruta de cientos de canales y películas en Magis TV, la mejor opción para ver contenido sin límites desde cualquier dispositivo.
Disfruta de cientos de canales y películas en [Magis TV][1], la mejor opción para ver contenido sin límites desde cualquier dispositivo. [1]: https://magistv-apps.com
N.K.
N.K. posted this 07 September 2025
Please close this Question. Since there is only Spam Reply's and i always get an email and cant delete the post....
> If the changes are still in template.css after you save the file, but they are not reflected on the site, it may be due to cache. Sometimes that site gets heavily cached by the browser you use or Joomla in general (clear cache in admin panel). > > Gina > Themler Support Please close this Question. Since there is only Spam Reply's and i always get an email and cant delete the post....
mezutozil1445
mezutozil1445 posted this 08 September 2025
Minecraft Apk is a fun game that lets players build, explore, and survive in a blocky world full of adventure. You can play with friends or alone to create amazing structures and craft tools for survival. This game offers endless creativity and exciting challenges for everyone to enjoy.
Minecraft Apk is a fun game that lets players build, explore, and survive in a blocky world full of adventure. You can [play][1] with friends or alone to create amazing structures and craft tools for survival. This game offers endless creativity and exciting challenges for everyone to enjoy. [1]: https://minecraftapkdl.com/
bicastudiosapp
bicastudiosapp posted this 08 September 2025
There’s something strange and beautiful about the Lost Life App. It’s like walking through a dream that slowly turns into a nightmare, and the storytelling is what keeps you going.
There’s something strange and beautiful about the **[Lost Life App][1]**. It’s like walking through a dream that slowly turns into a nightmare, and the storytelling is what keeps you going. [1]: https://lostlifegame.com/
milesles3978
milesles3978 posted this 03 November 2025
Minecraft Patched Pocket Edition APK offers players the full creative and survival experience on mobile, with all premium features unlocked. Build, explore, and survive in vast blocky worlds filled with adventure and endless possibilities. With the patched version, players enjoy smoother gameplay, custom skins, and exclusive content not found in the standard release.
[Minecraft Patched][1] Pocket Edition APK offers players the full creative and survival experience on mobile, with all premium features unlocked. Build, explore, and survive in vast blocky worlds filled with adventure and endless possibilities. With the patched version, players enjoy smoother gameplay, custom skins, and exclusive content not found in the standard release. [1]: https://apksminecraft.com/
Abbas Khan
Abbas Khan posted this 04 November 2025
Minecraft böylece küresel bir yaratıcılık zinciri oluşturur. Herkes bir parça ekler, herkes bir fikir sunar. Bu topluluk kültürü, oyunu canlı tutan en büyük güçtür. Çünkü Minecraft’ta hiçbir zaman son yoktur. Her yeni oyuncu yeni bir fikir getirir, her fikir yeni bir dünya doğurur. Minecraft APK, günümüzde sadece bir oyun olarak değil, bir yaşam biçimi olarak görülüyor. İnsanlar bu oyunu oynarken stres atıyor, düşüncelerini düzenliyor, yeni fikirler buluyor. Kimi doğada sade bir yaşam kuruyor, kimi geleceğin şehirlerini tasarlıyor.
https://minescraftapks.com.tr/
Minecraft böylece küresel bir yaratıcılık zinciri oluşturur. Herkes bir parça ekler, herkes bir fikir sunar. Bu topluluk kültürü, oyunu canlı tutan en büyük güçtür. Çünkü Minecraft’ta hiçbir zaman son yoktur. Her yeni oyuncu yeni bir fikir getirir, her fikir yeni bir dünya doğurur. Minecraft APK, günümüzde sadece bir oyun olarak değil, bir yaşam biçimi olarak görülüyor. İnsanlar bu oyunu oynarken stres atıyor, düşüncelerini düzenliyor, yeni fikirler buluyor. Kimi doğada sade bir yaşam kuruyor, kimi geleceğin şehirlerini tasarlıyor. **[https://minescraftapks.com.tr/][1]** [1]: https://minescraftapks.com.tr/
wk4084987
wk4084987 posted this 02 January 2026
تحميل هابي مود مهكر هو متجر أندرويد بديل لمتجر جوجل بلاي، يتيح الوصول إلى ملايين الألعاب والتطبيقات المدفوعة مجانًا. يوفر نسخًا معدلة من الألعاب، ميزات غير محدودة، وإصدارات متوافقة مع جميع الأجهزة. بواجهة بسيطة وسهلة الاستخدام، يمكن للمستخدمين تحميل الألعاب والتطبيقات، متابعة التنزيلات، وتبادل الروابط مع الأصدقاء لتجربة ترفيهية ممتعة بلا قيود.
[تحميل هابي مود مهكر][1] هو متجر أندرويد بديل لمتجر جوجل بلاي، يتيح الوصول إلى ملايين الألعاب والتطبيقات المدفوعة مجانًا. يوفر نسخًا معدلة من الألعاب، ميزات غير محدودة، وإصدارات متوافقة مع جميع الأجهزة. بواجهة بسيطة وسهلة الاستخدام، يمكن للمستخدمين تحميل الألعاب والتطبيقات، متابعة التنزيلات، وتبادل الروابط مع الأصدقاء لتجربة ترفيهية ممتعة بلا قيود. [1]: https://happymodsapk.net/
waseeem0ahmed01
waseeem0ahmed01 posted this 01 September 2026
That sounds frustrating—Joomla's file structure can be tricky for custom CSS. For a smoother editing experience, you might consider using an external CSS file or a child template. Also, if you ever need a break from coding, magisapk.tv offers great entertainment to unwind. Hope you find a solution soon! Thanks for sharing.
That sounds frustrating—Joomla's file structure can be tricky for custom CSS. For a smoother editing experience, you might consider using an external CSS file or a child template. Also, if you ever need a break from coding, [magisapk.tv][1] offers great entertainment to unwind. Hope you find a solution soon! Thanks for sharing. [1]: https://magisapk.tv/
