provaznik
posted this
31 May 2019
I have problem with the Module block contact infos. I would like to have all lines in a one vertical line. When I look to the page code there is <ul>...</ul>. But I would like code <br>...</br> See the image). Can you help me?
Thank you, Daku.
Solved
Hi, I have problem with the Module block contact infos. I would like to have all lines in a one vertical line. When I look to the page code there is <ul>...</ul>. But I would like code <br>...</br> See the image). Can you help me? Thank you, Daku. SolvedLast edited 04 June 2019 by provaznik
