Yes, i found a full discussion on this subject on https://answers.themler.io/questions/137877/i-can-not-find-the-documentation-for-column-shortcodes
But there is no answer there. At this moment there are several links in the Themler application and website that should lead to an article explaining the functionality of columns shortcodes. I don't want to give my users access to the themler application, but the should be able to use the shortcodes by typing them into the modules and articles.
SO please republish the article on your website
Another thing is that if you de-publish or remove articles please also remove links en and menu-items that lead to that article. I take it that are using a CMS, so this sort of things should be done automaticly
Yes, i found a full discussion on this subject on https://answers.themler.io/questions/137877/i-can-not-find-the-documentation-for-column-shortcodes But there is no answer there. At this moment there are several links in the Themler application and website that should lead to an article explaining the functionality of columns shortcodes. I don't want to give my users access to the themler application, but the should be able to use the shortcodes by typing them into the modules and articles. SO please republish the article on your website Another thing is that if you de-publish or remove articles please also remove links en and menu-items that lead to that article. I take it that are using a CMS, so this sort of things should be done automaticly
