Editing Backward Links
TJ Novick
TJ Novick posted this 10 August 2015
Is there anyway to edit the backward links to reflect being designed by myself and not the default backward links?
26 Comments
Support Team posted this 10 August 2015
There is no option to edit the backward links now, but I'll add this option in our wish list. For now you can delete the existing control and add the row with the Text control to include your own text.
Hi, There is no option to edit the backward links now, but I'll add this option in our wish list. For now you can delete the existing control and add the row with the Text control to include your own text. Sincerely, Hella BillionDigital Team
Eric-P
Eric-P posted this 25 August 2015
Hello, this is for when the ability to edit the footer links.
Support Team posted this 26 August 2015
Hi Perez,
I can't provide you with any ETA for now.
It's not a high-priority future so it may take a while to implement it.
Ivan
Hi Perez, I can't provide you with any ETA for now. It's not a high-priority future so it may take a while to implement it. Thanks, Ivan
TexasBiz
TexasBiz posted this 18 September 2015
Silly not to have this area editable. Think it should be a high priority to make it easier for designers, the one that keep you in business:) The whole program is very slow to use and respond, making it user friendly might save it.
Support Team posted this 18 September 2015
We do not see much point in allowing to edit Backward Links content because you can add Text control with ANY text and links instead. By it's design the Backward Links control is the same as Text. So there is no difference.
Hi, We do not see much point in allowing to edit Backward Links content because you can add Text control with ANY text and links instead. By it's design the Backward Links control is the same as Text. So there is no difference. Thank you, Olivia
lesergei
lesergei posted this 18 September 2015
I do not see the point you can edit the bacllink, the only exception would be, once with my edit information, you can save it and use it as another template. And, writing my text, I think it is possible to use the new "section" function to save his own relationship and use it elsewhere.
Hello, I do not see the point you can edit the bacllink, the only exception would be, once with my edit information, you can save it and use it as another template. And, writing my text, I think it is possible to use the new "section" function to save his own relationship and use it elsewhere. Thank you
Stagger Lee posted this 18 September 2015
Good idea Lesergei, very good.
lesergei
Thanks Stagger Lee, i tried and it works very well.
JohnR
JohnR posted this 27 January 2016
Is Themler trying to get sites linking back to themler in an effort to save costs on marketing?
Support Team posted this 28 January 2016
That is normal practice that such links are added in the default template created by our designers. In any case it is very easy to remove that control with links and you can do it without any restrictions.
Hi, That is normal practice that such links are added in the default template created by our designers. In any case it is very easy to remove that control with links and you can do it without any restrictions. Sincerely, Hella
JohnR
JohnR posted this 28 January 2016
Hi Hella
I personally don't have an issue withe having the backlinks if one wants them there, but to say it's "easy" to remove I don't believe this is the case. It's very difficult and you have to go into the hard coding to do this, am I wrong?
John
Hi Hella I personally don't have an issue withe having the backlinks if one **wants** them there, but to say it's "easy" to remove I don't believe this is the case. It's very difficult and you have to go into the hard coding to do this, am I wrong? Regards John
Support Team posted this 29 January 2016
You can remove the Backward Links control from within the editor just by pressing Del button while the control is highlighted.
Hi, You can remove the Backward Links control from within the editor just by pressing Del button while the control is highlighted. Sincerely, Hella
stephen17
stephen17 posted this 21 June 2016
I selected the backward link panel in the editor, clicked delete, clicked publish and it's still there on my live site (Drupal 7) even after clearing caches. Now in the editor it still shows but can no longer be selected and its no longer showing as an element or in the outline. It appears to now be baked in and untouchable. Please advise how I can remove it.
> Hi, > > You can remove the Backward Links control from within the editor just by pressing Del button while the control is highlighted. > > Sincerely, > Hella I selected the backward link panel in the editor, clicked delete, clicked publish and it's still there on my live site (Drupal 7) even after clearing caches. Now in the editor it still shows but can no longer be selected and its no longer showing as an element or in the outline. It appears to now be baked in and untouchable. Please advise how I can remove it.
Bayern
Bayern posted this 21 June 2016
transitional solution
create a new project - remove Backward Links - save
and only than update
transitional solution create a new project - remove Backward Links - save and only than update
If you have updated to the current beta version, then the Backward links can not be deleted as the control, but you can switch them off under the Home >> Settings >> Description.
Hi, If you have updated to the current beta version, then the Backward links can not be deleted as the control, but you can switch them off under the Home >> Settings >> Description. Sincerely, Hella
stephen17
I have the latest version of Themeler. I can't find a Home >> Settings >> Description option/control, where should it be or what should be selected to show that option (I do have Home >> Settings)? I also tried clicking off the display icons for the backward links section, but still no effect.
Please direct me to the setting you mention above.
I have the latest version of Themeler. I can't find a Home >> Settings >> Description option/control, where should it be or what should be selected to show that option (I do have Home >> Settings)? I also tried clicking off the display icons for the backward links section, but still no effect. Please direct me to the setting you mention above. Thank you
Support Team posted this 22 June 2016
This option is available in the latest beta, please make sure that beta updates are activated for your account:
http://answers.themler.com/questions/53794/beta-testing
enter image description here
Hi, This option is available in the latest beta, please make sure that beta updates are activated for your account: http://answers.themler.com/questions/53794/beta-testing ![enter image description here][1] Sincerely, Hella [1]: http://attachments.answers.billiondigital.com/26/16026/backlinks.png
rgfuller
rgfuller posted this 24 July 2016
Where is the Del button? There is no X near the control title like other controls, and I don't see a Del button on any tool bar or context menu. Please tell me where the Del button is to delete the backward link control. The Delete key doesn't do it either. Thanks.
Support Team posted this 24 July 2016
The backlink control options were moved in the Home >> Settings tab. Please refer to my posts above.
Hi, The backlink control options were moved in the Home >> Settings tab. Please refer to my posts above. Sincerely, Hella
JohnR
JohnR posted this 25 July 2016
year after year, and you STILL cannot remove this annoying "feature"? Why are you circumventing such a SIMPLE task? Confidence in this software deteriorates day by day!
year after year, and you STILL cannot remove this annoying "feature"? Why are you circumventing such a SIMPLE task? Confidence in this software **deteriorates** day by day!
