PHP version
Rune
Rune posted this 12 June 2019
An updated version of WordPress is available.
You cannot update because WordPress 5.2.1 requires PHP version 5.6.20 or higher. You are running version 5.4.42.
While your site is being updated, it will be in maintenance mode. As soon as your updates are complete, your site will return to normal.
> An updated version of WordPress is available. You cannot update because WordPress 5.2.1 requires PHP version 5.6.20 or higher. You are running version 5.4.42. While your site is being updated, it will be in maintenance mode. As soon as your updates are complete, your site will return to normal.
21 Comments
Support Team posted this 12 June 2019
Could you please specify your issue. Does it happen on your website? Is it related to Themler theme?
Hello, Could you please specify your issue. Does it happen on your website? Is it related to Themler theme? Sincerely, Nettie
Rune
It is in your localhost system (http://127.0.0.1:12080/themler_486313935/woocommerce/wp-admin/). It it not able to update the Wordpress version anymore because of the php version in your setup.
We will forward the request to update PHP version in Themler desktop to our developers. In the meanwhile it is recommended to use CMS and PHP versions that are included with Themler desktop installation. If you would like to test a theme on another CMS and PHP versions, please consider installing Themler in Wordpress on some localhost or hosted website.
Hello, We will forward the request to update PHP version in Themler desktop to our developers. In the meanwhile it is recommended to use CMS and PHP versions that are included with Themler desktop installation. If you would like to test a theme on another CMS and PHP versions, please consider installing Themler in Wordpress on some localhost or hosted website. Sincerely, Nettie
Support Team posted this 13 June 2019
Unfortunately, we don't have any timeline set yet.
Themler support
Unfortunately, we don't have any timeline set yet. Gina Themler support
Rune
Rune posted this 01 October 2019
Are you updating php or do you abandon themlers for the future?
Support Team posted this 01 October 2019
PHP in Themler desktop is not updated yet. However it is supported, please feel free to install updated Themler themes in your CMS on the website or localhost with the newest PHP versions.
Hello, PHP in Themler desktop is not updated yet. However it is supported, please feel free to install updated Themler themes in your CMS on the website or localhost with the newest PHP versions. Sincerely, Nettie
Vitaliy WD
Vitaliy WD posted this 02 October 2019
Hi.
Is the PHP 7.3 fully supported in last Stable Themler version?
Hi. Is the PHP 7.3 fully supported in last Stable Themler version?
Support Team posted this 02 October 2019
Yes, it is. Please let us know in case you have any issues with PHP 7.3 after the update.
Hello, Yes, it is. Please let us know in case you have any issues with PHP 7.3 after the update. Sincerely, Nettie
HummerCatering
HummerCatering posted this 25 May 2020
its so sad. woocomerce and php all versionen old . i cane not go to the new worldpress version. pleas update!!!! Rune write you now 6 month ago.
Support Team posted this 26 May 2020
Themler supports the latest PHP and Woocommerce versions. We know about notifications in Woocommerce and have forwarded this to our developers, however they do not affect functionality. Support for the latest Wordpress version will be added in the near future.
Hello, Themler supports the latest PHP and Woocommerce versions. We know about notifications in Woocommerce and have forwarded this to our developers, however they do not affect functionality. Support for the latest Wordpress version will be added in the near future. Sincerely, Nettie
wolski.lukasz
wolski.lukasz posted this 15 December 2020
Please update your local server php as soon as possible. After exporting the template on my client's server, I get an outdated woocommerce version message. Locally impossible to update because Themler has an outdated version of php. You can write that this does not reduce the functionality of the template, but my clients do not want such messages and are asking me to fix the problem. So, as your client, I am asking you to fix the problem, because the topic is quite old and there is no solution.
Support Team posted this 15 December 2020
It is not recommended, to update PHP, CMS version or anything else in local Themler CMS installation. After export, you may use the theme with the latest PHP and CMS on your server or localhost.
The messages shouldn't be displayed with the latest Themler version, after you export the theme. Let us know if they do.
Hello, It is not recommended, to update PHP, CMS version or anything else in local Themler CMS installation. After export, you may use the theme with the latest PHP and CMS on your server or localhost. The messages shouldn't be displayed with the latest Themler version, after you export the theme. Let us know if they do. Sincerely, Nettie
aleks-karvelis
aleks-karvelis posted this 17 December 2020
Пожалуйста, обновите php на локальном сервере как можно скорее.
Support Team posted this 15 January 2021
Здравствуйте,
Пожелание передано разработчиком. Тем временем рекомендуем установить любую версию PHP и вашей CMS на локалхосте, например, xampp, и там работать над темами Themler. Дополнительным бонусом будет то, что можно создать отдельный контент для разных сайтов, а затем экспортировать его вместе с темой, чтобы уже использовать на живом сайте.
Здравствуйте, Пожелание передано разработчиком. Тем временем рекомендуем установить любую версию PHP и вашей CMS на локалхосте, например, xampp, и там работать над темами Themler. Дополнительным бонусом будет то, что можно создать отдельный контент для разных сайтов, а затем экспортировать его вместе с темой, чтобы уже использовать на живом сайте. Sincerely, Nettie
aleks-karvelis
aleks-karvelis posted this 20 June 2021
Когда обновите php ?
Support Team posted this 21 June 2021
К сожалению, в скором времени обновление PHP в локальных установках CMS не ожидается.
Themler support
К сожалению, в скором времени обновление PHP в локальных установках CMS не ожидается. Gina Themler support
bekeanloinse
bekeanloinse posted this 25 March 2024
After updating the PHP version, visit your website to ensure that everything is working as expected. Check various subway surfers pages, functionalities, and plugins to confirm compatibility.
After updating the PHP version, visit your website to ensure that everything is working as expected. Check various [subway surfers][1] pages, functionalities, and plugins to confirm compatibility. [1]: https://subwaysurfersgame.io
foodlenyt88
foodlenyt88 posted this 16 August 2024
There are different ways to pick records at random from a database table in fnaf, and each has pros and cons. Different methods might work better in some situations, based on the needs of the application.
There are different ways to pick records at random from a database table in [fnaf][1], and each has pros and cons. Different methods might work better in some situations, based on the needs of the application. [1]: https://fivenightsatfreddys3.com
michaelarringtony
michaelarringtony posted this 19 March 2025
I’d say this is a nudge to update that PHP pronto; 5.4’s pretty Sprunki Pyramixed ancient by now, and the security perks of jumping to 5.6 or even higher are worth it.
I’d say this is a nudge to update that PHP pronto; 5.4’s pretty [Sprunki Pyramixed][1] ancient by now, and the security perks of jumping to 5.6 or even higher are worth it. [1]: https://pyramixed.io/
California Business Journal
California Business Journal posted this 21 May 2025
Discover how z-library offers over 115 million books for free, including rare and hard-to-find titles, making it a go-to resource for students, researchers, and book lovers.
Discover how [z-library][1] offers over 115 million books for free, including rare and hard-to-find titles, making it a go-to resource for students, researchers, and book lovers. [1]: https://calbizjournal.com/unleashing-the-secrets-of-z-library-how-to-discover-rare-books-with-ease/
