Template SEO problem
francesco.scaramella
francesco.scaramella posted this 08 July 2019
I have to ask you for clarification about your program for the realization of the templates. I continue to have problems with the seo optimization of the site to improve its rea on search engines. Lately I have also requested external advice to understand what problems I was taking back in order to solve my problems. As in fact I expected to have many problems related to a bad realization of the template for different shortcomings of the various H1, H2, and so on in the different sections of the site, as well as on the home page an almost absolute lack of information for the search engines to perform good indexing. As you can read in the document I attach to you, the images are completely devoid of any index possibilities to return to search engines. How can I improve these deficiencies using themler????
10 Comments
Support Team posted this 09 July 2019
Hello Francesco,
Unfortunately, no file is attached that I can see.
As for the images, please, try adding ALT tag description to them:
Use meta tags that you can fill under Home -> Settings.
As for realization of H1 and H2 tags, you can't change that if we are talking about standard layout of post for CMS like Joomla, Wordpress, etc. Though you can add heading 1 youself to static content:
Hello Francesco, Unfortunately, no file is attached that I can see. As for the images, please, try adding ALT tag description to them: !image-alt.png! Use meta tags that you can fill under Home -> Settings. As for realization of H1 and H2 tags, you can't change that if we are talking about standard layout of post for CMS like Joomla, Wordpress, etc. Though you can add heading 1 youself to static content: !h1.png! Gina Themler Support
francesco.scaramella posted this 09 July 2019
https://answers.themler.io/questions/189307/seo-problem?page=1
you can find the attachment in the private post
https://answers.themler.io/questions/189307/seo-problem?page=1 you can find the attachment in the private post
Support Team posted this 10 July 2019
Thank you.
1) Meta tags, backlinks and SEF URLs are part of the content that user can alter in site admin panel
Also make sure you have correctly filled out fields in settings:
2) Add alt tags to images as described in my previous post
3) As mentioned earlier, you can add H1 title manually, at least to Home page using Insert menu tab
4) Responsiveness of the site can be adjusted in Themler by switching between different responsive modes:
Thank you. 1) Meta tags, backlinks and SEF URLs are part of the content that user can alter in site admin panel Also make sure you have correctly filled out fields in settings: !settings.png! 2) Add alt tags to images as described in my previous post 3) As mentioned earlier, you can add H1 title manually, at least to Home page using Insert menu tab 4) Responsiveness of the site can be adjusted in Themler by switching between different responsive modes: !resp-modes.png! Gina Themler Support
iamdavid.sadler
iamdavid.sadler posted this 12 August 2024
Thanks for your resposes, you can also tackle this using Themler, start by ensuring that each page has a clear H1 tag that reflects its content, along with well-structured H2s to help organize your information. For images, it’s crucial to add descriptive alt text and use relevant file names. These steps will help search engines understand your content better. Additionally, consider enhancing the homepage with more keyword-rich content to boost indexing. It might take some time, but these adjustments should really help improve your site's visibility in search results!
David Sadler,
XtraSaaS Team
Thanks for your resposes, you can also tackle this using Themler, start by ensuring that each page has a clear H1 tag that reflects its content, along with well-structured H2s to help organize your information. For images, it’s crucial to add descriptive alt text and use relevant file names. These steps will help search engines understand your content better. Additionally, consider enhancing the homepage with more keyword-rich content to boost indexing. It might take some time, but these adjustments should really help improve your site's visibility in search results! Sincerely, David Sadler, [XtraSaaS][1] Team [1]: https://xtrasaas.com
Umair Rana
Umair Rana posted this 28 August 2024
To address the SEO optimization issues you’re experiencing with your site’s templates, particularly with regards to H1 and H2 tags and image indexing, here’s how you can use Themeler to improve these deficiencies:
Proper Use of Header Tags (H1, H2, etc.):
Review Template Structure: Ensure that each page template in Themeler is designed with a clear hierarchy of header tags. For example, use one H1 tag per page for the main title, followed by H2 tags for subheadings and H3 tags for further subsections. This structure helps search engines understand the content better.
Edit Header Tags: Use Themeler’s editing tools to adjust the header tags in each template section. Make sure to use relevant keywords in these tags to improve SEO.
Optimizing Content for Search Engines:
Content Fields: Check the content fields in your Themeler templates to ensure they are appropriately filled with relevant keywords and information. This includes adding meta descriptions and alt text for images.
Template Customization: Customize your templates to include SEO-friendly elements like keyword-rich titles, descriptions, and tags. The meter should allow you to modify these settings directly within the template editor.
Image Optimization:
Add Alt Text: Ensure all images within your templates have descriptive alt text. This not only helps with SEO but also improves accessibility. You can typically add or edit alt text in the image settings within Themeler.
Image Sizing and Formats: Optimize image sizes and formats for faster loading times. Use appropriate file types (e.g., JPEG for photos, PNG for graphics) and ensure images are compressed without losing quality.
Internal Linking and Navigation:
Improved Internal Links: Use Themeler to add internal links within your content. This helps search engines crawl your site more effectively and enhances the user experience.
Navigation Structure: Ensure your navigation menus and links are well-structured and easy to follow. Straightforward navigation helps both users and search engines understand the site layout.
Check and Test:
SEO Tools: Use SEO analysis tools to test your site’s performance after making changes. The meter might offer built-in SEO tools, or you can use external tools like Google Search Console, Moz, or Ahrefs for additional insights.
Regular Updates: Review and update your templates to adapt to SEO best practices and algorithm changes.
By applying these strategies, you should be able to address the SEO deficiencies related to header tags, content, and image indexing in your Themeler templates. If you continue encountering issues, consulting with an SEO expert can provide further tailored recommendations for your needs.
Regarding: saas pro marketing
To address the SEO optimization issues you’re experiencing with your site’s templates, particularly with regards to H1 and H2 tags and image indexing, here’s how you can use Themeler to improve these deficiencies: Proper Use of Header Tags (H1, H2, etc.): Review Template Structure: Ensure that each page template in Themeler is designed with a clear hierarchy of header tags. For example, use one H1 tag per page for the main title, followed by H2 tags for subheadings and H3 tags for further subsections. This structure helps search engines understand the content better. Edit Header Tags: Use Themeler’s editing tools to adjust the header tags in each template section. Make sure to use relevant keywords in these tags to improve SEO. Optimizing Content for Search Engines: Content Fields: Check the content fields in your Themeler templates to ensure they are appropriately filled with relevant keywords and information. This includes adding meta descriptions and alt text for images. Template Customization: Customize your templates to include SEO-friendly elements like keyword-rich titles, descriptions, and tags. The meter should allow you to modify these settings directly within the template editor. Image Optimization: Add Alt Text: Ensure all images within your templates have descriptive alt text. This not only helps with SEO but also improves accessibility. You can typically add or edit alt text in the image settings within Themeler. Image Sizing and Formats: Optimize image sizes and formats for faster loading times. Use appropriate file types (e.g., JPEG for photos, PNG for graphics) and ensure images are compressed without losing quality. Internal Linking and Navigation: Improved Internal Links: Use Themeler to add internal links within your content. This helps search engines crawl your site more effectively and enhances the user experience. Navigation Structure: Ensure your navigation menus and links are well-structured and easy to follow. Straightforward navigation helps both users and search engines understand the site layout. Check and Test: SEO Tools: Use SEO analysis tools to test your site’s performance after making changes. The meter might offer built-in SEO tools, or you can use external tools like Google Search Console, Moz, or Ahrefs for additional insights. Regular Updates: Review and update your templates to adapt to SEO best practices and algorithm changes. By applying these strategies, you should be able to address the SEO deficiencies related to header tags, content, and image indexing in your Themeler templates. If you continue encountering issues, consulting with an SEO expert can provide further tailored recommendations for your needs. Regarding: [saas pro marketing][1] [1]: https://saaspromarketing.com/
ijaz170000
ijaz170000 posted this 20 May 2025
Francesco, in addition to fixing H1/H2 structure and image alt tags, one common issue affecting SEO is that backlinks to your site might not be getting indexed by search engines.
Francesco, in addition to fixing H1/H2 structure and image alt tags, one common issue affecting SEO is that [backlinks][1] to your site might not be getting [indexed][2] by search engines. [1]: https://docs.google.com/spreadsheets/d/e/2PACX-1vT-c5QhXB-Nu3DzoCHYMrwj6RaUiDWjzBYhAOgwrmodf5TIM_t26EfIJt2t9iDtR8-X8g_ip4PXCR6a/pubhtml [2]: https://docs.google.com/spreadsheets/d/e/2PACX-1vQeuKqcLqReiswtOABuqOIqJsjnTKVAcdSuuiDxuM14IXMoCTH4FlwC1K4cMr1D2R0-LKwV3K7Uv23k/pubhtml
ijaz170000
ijaz170000 posted this 16 June 2025
Francesco, in addition to fixing H1/H2 structure and image alt tags, one common issue affecting SEO is that backlinks to your site might not be getting indexed by search engines. This is where seo services link building becomes essential. High-quality backlinks from trusted sources not only boost authority but also help search engines discover and rank your content faster. Make sure to track which backlinks are actually indexed to see the real impact!
Francesco, in addition to fixing H1/H2 structure and image alt tags, one common issue affecting SEO is that backlinks to your site might not be getting indexed by search engines. This is where [seo services link building][1] becomes essential. High-quality backlinks from trusted sources not only boost authority but also help search engines discover and rank your content faster. Make sure to track which backlinks are actually indexed to see the real impact! [1]: https://eliteseotool.com/
ijaz170000
ijaz170000 posted this 05 July 2025
Template structure plays a critical role in SEO. Missing H1s, poor heading hierarchy, and non-indexable images are major red flags we often see during technical audits. At Giant Leap Digital, we offer luxury Digital Marketing in London, UK, with a strong focus on fixing these exact issues — from semantic markup to image alt optimization — so sites can rank properly and convert better. Themler themes can work well, but they often need manual SEO adjustments to perform.
https://giantleapdigital.co.uk/
Template structure plays a critical role in SEO. Missing H1s, poor heading hierarchy, and non-indexable images are major red flags we often see during technical audits. At Giant Leap Digital, we offer luxury Digital Marketing in London, UK, with a strong focus on fixing these exact issues — from semantic markup to image alt optimization — so sites can rank properly and convert better. Themler themes can work well, but they often need manual SEO adjustments to perform. [https://giantleapdigital.co.uk/][1] [1]: https://giantleapdigital.co.uk/
jackmitchel
jackmitchel posted this 17 August 2025
I understand your concerns. Themler does allow you to fix these SEO issues, but you’ll need to adjust the templates carefully. Start by ensuring each page has a single H1 with proper H2/H3 tags for structure. Add descriptive meta titles, descriptions, and alt text for all images to help with indexing. You should also customize the homepage content with keyword-rich information so search engines have enough data to crawl. With these changes, your site’s SEO performance will improve step by step.
I understand your concerns. Themler does allow you to fix these SEO issues, but you’ll need to adjust the templates carefully. Start by ensuring each page has a single H1 with proper H2/H3 tags for structure. Add descriptive meta titles, descriptions, and alt text for all images to help with indexing. You should also customize the [homepage][1] content with keyword-rich information so search engines have enough data to crawl. With these changes, your site’s SEO performance will improve step by step. [1]: https://aimgrip.com/
jedafeb382
jedafeb382 posted this 3 weeks ago
Enhance your preparation for the HPE Sales Certified – Aruba Products and Solutions (HPE2-W12) exam with DumpsTool’s HPE2-W12 Practice Questions. These expertly prepared resources help you understand networking, wireless, and mobility solutions. Practice real exam-style questions to boost your confidence and achieve certification excellence with verified HPE2-W12 content.
Enhance your preparation for the HPE Sales Certified – Aruba Products and Solutions (HPE2-W12) exam with DumpsTool’s [HPE2-W12 Practice Questions][1]. These expertly prepared resources help you understand networking, wireless, and mobility solutions. Practice real exam-style questions to boost your confidence and achieve certification excellence with verified HPE2-W12 content. [1]: https://www.dumpstool.com/HPE2-W12-exam.html
