Have given up trying to create a linked image on the default/homepage
erkbiz2
erkbiz2 posted this 14 July 2019
I have come to the conclusion it is not possible to create a linked image from a site's homepage. I have tried many different things to do this and none of them work. I originally thought it had to do with the page that Themler defines as, "home", but this has nothing to do with it when I set a, "post", page as the homepage, (setting this from the menu tab in joomla), the link does not work. I have tried to create a linked image as a Joomla article, I have tried to create a linked image inside of Themler, nothing works. I then thought it was a Joomla problem but when I load a Joomla template, (e.g. beez3 or protostar), the link works fine. Also, the link works fine on any and all pages not defined as the homepage.
When I hover over the image, using the Chrome Browser, the URL of the page I want to navigate to is clearly visible in the lower left corner of the window but the clicking of the mouse is ignored but if I use a text link the link works fine from the home/default page.
I have disabled the lightbox feature that is associated with the default/homepage using this CSS string, ".bd-lightbox { display: none !important; }", perhaps this has something to do with it, however, if I do leave the lightbox turned on all I get is the lightbox affect still no link.
Is this a bug with Themler or it is intended that no image on the default/homepage be allowed to act as a link?
I don't like giving up but I am at a loss.
Has anyone had success at doing what I am attempting to do?
UPDATE TO THE ABOVE
IT WAS USING CSS TO DISABLE THE LIGHTBOX FUNCTION THAT PREVENTED THE MOUSE CLICK FROM BEING RECOGNIZED. BY GOING INTO THE .JS FILE AND COMMENTING OUT THE LIGHTBOX FUNCTION THE PROBLEM WAS SOLVED THE MOUSE CLICK DOES NOT CALL THE LIGHTBOX FUNCTION BUT IT DOES RECOGNIZE THE IMAGE/LINK
I have come to the conclusion it is not possible to create a linked image from a site's homepage. I have tried many different things to do this and none of them work. I originally thought it had to do with the page that Themler defines as, "home", but this has nothing to do with it when I set a, "post", page as the homepage, (setting this from the menu tab in joomla), the link does not work. I have tried to create a linked image as a Joomla article, I have tried to create a linked image inside of Themler, nothing works. I then thought it was a Joomla problem but when I load a Joomla template, (e.g. beez3 or protostar), the link works fine. Also, the link works fine on any and all pages not defined as the homepage. When I hover over the image, using the Chrome Browser, the URL of the page I want to navigate to is clearly visible in the lower left corner of the window but the clicking of the mouse is ignored but if I use a text link the link works fine from the home/default page. I have disabled the lightbox feature that is associated with the default/homepage using this CSS string, ".bd-lightbox { display: none !important; }", perhaps this has something to do with it, however, if I do leave the lightbox turned on all I get is the lightbox affect still no link. Is this a bug with Themler or it is intended that no image on the default/homepage be allowed to act as a link? I don't like giving up but I am at a loss. Has anyone had success at doing what I am attempting to do? UPDATE TO THE ABOVE IT WAS USING CSS TO DISABLE THE LIGHTBOX FUNCTION THAT PREVENTED THE MOUSE CLICK FROM BEING RECOGNIZED. BY GOING INTO THE .JS FILE AND COMMENTING OUT THE LIGHTBOX FUNCTION THE PROBLEM WAS SOLVED THE MOUSE CLICK DOES NOT CALL THE LIGHTBOX FUNCTION BUT IT DOES RECOGNIZE THE IMAGE/LINK
9 Comments
Support Team posted this 15 July 2019
You should be possible to disable the lightbox in Themler -> select the section with posts (in Outline) -> go to Posts menu -> Post Content -> toggle Image Lightbox.
Hello, You should be possible to disable the lightbox in Themler -> select the section with posts (in Outline) -> go to Posts menu -> Post Content -> toggle Image Lightbox. Gina Themler Support
gionni.jalil
gionni.jalil posted this 11 April 2025
To start the Developer Tools, right-click the picture and choose "Inspect". See whether any JavaScript or CSS styles could stop the click event papa's pizzeria. Should JavaScript be present on the website, it may be interfering with the click occurrence. Look for any event attendees that could be stopping the default action.
To start the Developer Tools, right-click the picture and choose "Inspect". See whether any JavaScript or CSS styles could stop the click event [papa's pizzeria][1]. Should JavaScript be present on the website, it may be interfering with the click occurrence. Look for any event attendees that could be stopping the default action. [1]: https://papaspizzeria.io/
Abbas Khan
Abbas Khan posted this 21 April 2025
If you're looking to enhance your knowledge and understanding of the Quran, Quran Lessons offer an exceptional opportunity to learn from experienced instructors. Whether you're a beginner or seeking to advance your knowledge, these online lessons are tailored to suit various learning needs. Explore interactive lessons and connect with fellow learners in a supportive environment. Start your Quranic journey today with flexible online learning options. Don't miss out on this amazing educational opportunity.
If you're looking to enhance your knowledge and understanding of the Quran, **[Quran Lessons][1]** offer an exceptional opportunity to learn from experienced instructors. Whether you're a beginner or seeking to advance your knowledge, these online lessons are tailored to suit various learning needs. Explore interactive lessons and connect with fellow learners in a supportive environment. Start your Quranic journey today with flexible online learning options. Don't miss out on this amazing educational opportunity. [1]: https://learnqurancentre.co.uk/
kerolina846bala
kerolina846bala posted this 22 April 2025
You've done a great job of debugging this — Themler can be a bit opaque with its auto-generated code and event handlers. Costco business center locations
You've done a great job of debugging this — Themler can be a bit opaque with its auto-generated code and event handlers. [Costco business center locations][1] [1]: https://www.costcobusinesscenters.com
trevorashley152
trevorashley152 posted this 23 April 2025
Disabling the lightbox function in the .JS file made a huge difference. For anyone else facing a similar issue, it's worth checking if any JavaScript or CSS features, like the lightbox, are interfering with the click functionality. Sometimes, these functions can override other behaviors without being obvious. If you're still experimenting with image links, it could also be helpful to test with different Joomla templates or review custom scripts that might be conflicting. Thanks for the update, and glad to hear it’s working now! geometry dash lite
Disabling the lightbox function in the .JS file made a huge difference. For anyone else facing a similar issue, it's worth checking if any JavaScript or CSS features, like the lightbox, are interfering with the click functionality. Sometimes, these functions can override other behaviors without being obvious. If you're still experimenting with image links, it could also be helpful to test with different Joomla templates or review custom scripts that might be conflicting. Thanks for the update, and glad to hear it’s working now! [geometry dash lite](https://geometrydash-lite.org/)
informationofworld2
informationofworld2 posted this 23 April 2025
The Reaver Karambit knife is a tactical, curved blade known for its unique design and excellent handling. Its distinct appearance and sharp edge make it popular among collectors and those seeking a reliable tool for self-defense or combat scenarios.
The [Reaver Karambit knife][1] is a tactical, curved blade known for its unique design and excellent handling. Its distinct appearance and sharp edge make it popular among collectors and those seeking a reliable tool for self-defense or combat scenarios. [1]: https://bootitems.com/reaver-karambit/
hifen55436
hifen55436 posted this 24 April 2025
Casino Regina is one of the best places to play in Canada, offering a wide range of games. It runs various promotions for its users, which gives them a chance to not only get additional bonuses, but also to increase their chances of winning big. Players can test their skills and win big. Thus, it offers not only an exciting game, but also a real chance to win.
[Casino Regina][1] is one of the best places to play in Canada, offering a wide range of games. It runs various promotions for its users, which gives them a chance to not only get additional bonuses, but also to increase their chances of winning big. Players can test their skills and win big. Thus, it offers not only an exciting game, but also a real chance to win. [1]: https://casino-regina-canada.com
informationofworld2
informationofworld2 posted this 07 May 2025
The Free car parking simulator APK makes the game more exciting and fun to play. It comes with unlocked cars, all levels already open, and free shopping, so you don’t have to wait or spend money to enjoy everything. With these extra features, you can enjoy the full game experience without any limits.
The [Free car parking simulator APK][1] makes the game more exciting and fun to play. It comes with unlocked cars, all levels already open, and free shopping, so you don’t have to wait or spend money to enjoy everything. With these extra features, you can enjoy the full game experience without any limits. [1]: https://carparkinggamez.com/
informationofworld2
informationofworld2 posted this 10 May 2025
Impara con onlineanalisilogica è una risorsa educativa online per esercitarsi con l'analisi logica in modo semplice e interattivo.
Offre spiegazioni chiare, esercizi interattivi e strumenti utili per studenti e insegnanti di grammatica italiana.
[Impara con onlineanalisilogica][1] è una risorsa educativa online per esercitarsi con l'analisi logica in modo semplice e interattivo. Offre spiegazioni chiare, esercizi interattivi e strumenti utili per studenti e insegnanti di grammatica italiana. [1]: https://onlineanalisilogica.it/
