Downloading Billion Themes
erkbiz2
erkbiz2 posted this 17 July 2019
I attempted to import a template using the, "Billion Themes", link in Themler and get an error saying only Joomla templates are allowed or I end up with a blank screen. Can you help resolve this issue? Thanks
8 Comments
Support Team posted this 17 July 2019
Do you mean that you tried to import a theme from the library?
Could you please provide a link to it?
Hello, Do you mean that you tried to import a theme from the library? Could you please provide a link to it? Sincerely, Nettie
erkbiz2
I was not using a URL for the download I was using the link located under the file tab on Themler. Attached is an image of the link, at the bottom of the image is the link, "Import From Billion Themes".
Could you please specify theme name or ID so that we could try to reproduce the issue with it?
Hello, Could you please specify theme name or ID so that we could try to reproduce the issue with it? Sincerely, Nettie
erkbiz2
The following are all zip files. I downloaded these from this site, "http://templates.themler.io/Themes/Index?Search.Page=true&sorter=Newest".
billionthemes-1896702-recipes
billionthemes-2875138-container-in-full-width-section
billionthemes-2877199-three-columns-with-background-image
The ones I attempted to use from the link as shown in the image are named
DC Studio (Static) - Joomla!™ Template -- ID 1884795
Airtrans - Joomla!™ Template -- ID 1883520
The following are all zip files. I downloaded these from this site, "http://templates.themler.io/Themes/Index?Search.Page=true&sorter=Newest". billionthemes-1896702-recipes billionthemes-2875138-container-in-full-width-section billionthemes-2877199-three-columns-with-background-image The ones I attempted to use from the link as shown in the image are named DC Studio (Static) - Joomla!™ Template -- ID 1884795 Airtrans - Joomla!™ Template -- ID 1883520
Support Team posted this 18 July 2019
The .zip files mentioned first are sections. The easiest way to insert them into your theme is from the Insert tab >> Section >> From Library - you may use section ID like 1896702 for quick search.
I have just tested both themes for Joomla and they can be imported without any issues. However, if you have a newer Joomla version, 3.9, it is recommended to download each theme first, then import it in Themler desktop, update to the latest Themler version, then export and install on your website. Here are the links to both themes:
http://templates.themler.io/Themes/Detail/1884795/DC-Studio-Static?statisticsID=146480320&containsInPage=False
http://templates.themler.io/Themes/Detail/1883520/Airtrans?statisticsID=146480347&containsInPage=False
Hello, The .zip files mentioned first are sections. The easiest way to insert them into your theme is from the Insert tab >> Section >> From Library - you may use section ID like 1896702 for quick search. I have just tested both themes for Joomla and they can be imported without any issues. However, if you have a newer Joomla version, 3.9, it is recommended to download each theme first, then import it in Themler desktop, update to the latest Themler version, then export and install on your website. Here are the links to both themes: http://templates.themler.io/Themes/Detail/1884795/DC-Studio-Static?statisticsID=146480320&containsInPage=False http://templates.themler.io/Themes/Detail/1883520/Airtrans?statisticsID=146480347&containsInPage=False Sincerely, Nettie
studwork1742
studwork1742 posted this 24 October 2025
Μου πρότειναν το billionaire spin casino ως μια απλή και αξιόπιστη επιλογή. Η εμπειρία μου ήταν εξαιρετική. Ο σχεδιασμός είναι καθαρός και η πλοήγηση γρήγορη. Πήρα το μπόνους αμέσως και όλα τα παιχνίδια δούλεψαν τέλεια. Είναι μία από τις λίγες σελίδες που θα πρότεινα χωρίς δεύτερη σκέψη.
Μου πρότειναν το [billionaire spin casino][1] ως μια απλή και αξιόπιστη επιλογή. Η εμπειρία μου ήταν εξαιρετική. Ο σχεδιασμός είναι καθαρός και η πλοήγηση γρήγορη. Πήρα το μπόνους αμέσως και όλα τα παιχνίδια δούλεψαν τέλεια. Είναι μία από τις λίγες σελίδες που θα πρότεινα χωρίς δεύτερη σκέψη. [1]: https://billionairespin.com.gr
chinahousehold
chinahousehold posted this 19 May 2026
https://bamboochopsticks.storeinfo.jp/posts/58814519
https://chinabamboo.therestaurant.jp/posts/58814530
https://bambooflooring.shopinfo.jp/posts/58814535
https://japanbamboo.storeinfo.jp/posts/58814558
https://bambooplywood.localinfo.jp/posts/58814564
https://bothbest.amebaownd.com/posts/58814576
https://bambooflooring.theblog.me/posts/58814579
https://bamboodecking.themedia.jp/posts/58814583
https://blog.naver.com/chinabamboo/
https://blog.naver.com/chinabamboo/224281917365
https://huggingface.co/spaces/bothbest/china/discussions/1
https://pad.eisfunke.com/s/kxM6seHZ_O
https://pad.interhop.org/s/1gA41YLH2K
https://elearn.ellak.gr/mod/forum/discuss.php?d=58879
https://www.medherb.ir/discussions/21667-floating-vs-glue-down-bamboo-flooring-which-installation-method-is-safer
https://mikseri.net/blogs/view.php?id=30909
https://ptc.org.vn/blogs/11582/Solid-Wood-vs-Bamboo-Plywood-Sheets-Which-is-Better-for
https://ameblo.jp/japanbamboo/entry-12966312597.html
https://www.hssolar.cn/news-53.html
https://blog.ulifestyle.com.hk/article/bothbest/4421706/wide-plank-bamboo-flooring-does-it-warp-faster-than-narrow-strips
https://blog.ulifestyle.com.hk/article/econice/4421708/the-best-underlayment-for-bamboo-flooring
https://official.link/Heavy-Duty-Bamboo-Panels-for-Countertops-Sealing-and-Maintenance-Tips
https://playingwithsuperpower.com/forum/article-discussion/solid-wood-vs-bamboo-plywood-sheets-which-is-better-for-kitchen-cabinets/
https://velog.io/@bothbest/Preventing-Bowing-in-Large-Bamboo-Plywood-Sheets-for-Wardrobe-Doors
https://www.ybookmarking.com/story/bamboo-flooring-china-factory-wholesale
https://doks.komun.org/s/sixBlEUFTU
https://codoc.jp/sites/bothbest/entries/4xV1ShYMUg
https://naya.com.np/post/p17789154145y8zz
https://mypaper.pchome.com.tw/bothbest/post/1384660161
https://www.cssauw.org/forum/thread-41347-1-1
https://forums.liyuans.com/thread/25915
https://www.glbrain.com/index.php?r=content/view&id=50097
https://www.youyooz.com/yooz/fire-ratings-and-solid-bamboo-panels-commercial-building-compliance-basics/
https://open.firstory.me/story/cmp80oi7u010i01toe7lr8ehx
https://www.foriio.com/works/2388451/notes/51524
https://www.24liveblog.com/live/4111102063345409324
https://f-body.com/forum/f-body/f-body-cruise-in-for-general-discussion/265620-bamboo-flooring-acclimation-times-by-climate-zone-a-builder-s-checklist
https://prismo.fedibird.com/posts/75a7eaa5-3296-4d33-97ab-235193a30cce
https://www.guildquality.com/crew/post/80572
https://globbook.com/blogs/74508/Preventing-Mold-and-Mildew-on-Outdoor-Bamboo-Decks-in-High
https://utas.me/bothbest/water-resistant-bamboo-plywood-can-you-use-it-for-bathroom-vanities-q1hci4o2/
https://cal.com/chinabamboo/exterior-bamboo-panels-can-they-survive-rain-and-uv-exposure-as-siding
https://connect.usama.dev/blogs/75496/Formaldehyde-Free-Bamboo-Plywood-Sourcing-Safe-Materials-for-Your-Home
https://comunidad.espoesia.com/bothbest/can-outdoor-bamboo-flooring-survive-freezing-winter-temperatures-and-snow-accumulation/
https://www.nextbizthing.com/articles/are-bamboo-panels-stronger-than-mdf-for-heavy-floating-shelves
https://dominicanmaps.com/forum/topic/can-outdoor-bamboo-flooring-survive-freezing-winter/
https://berbagi.link/bothbest/article/e4f85ff0-5100-11f1-8679-c338dc62b199
https://ssn.so/forums/munpia-contest/topic/237448/
https://bothbest.systeme.io/bamboo/shipping-large-bamboo-panels-and-sheets-how-to-inspect-for-freight-damage
https://2all.co.il/web/Sites20/bothbest/Article1.asp?ArticleRowID=21896
https://bamboochopsticks.storeinfo.jp/posts/58814519 https://chinabamboo.therestaurant.jp/posts/58814530 https://bambooflooring.shopinfo.jp/posts/58814535 https://japanbamboo.storeinfo.jp/posts/58814558 https://bambooplywood.localinfo.jp/posts/58814564 https://bothbest.amebaownd.com/posts/58814576 https://bambooflooring.theblog.me/posts/58814579 https://bamboodecking.themedia.jp/posts/58814583 https://blog.naver.com/chinabamboo/ https://blog.naver.com/chinabamboo/224281917365 https://huggingface.co/spaces/bothbest/china/discussions/1 https://pad.eisfunke.com/s/kxM6seHZ_O https://pad.interhop.org/s/1gA41YLH2K https://elearn.ellak.gr/mod/forum/discuss.php?d=58879 https://www.medherb.ir/discussions/21667-floating-vs-glue-down-bamboo-flooring-which-installation-method-is-safer https://mikseri.net/blogs/view.php?id=30909 https://ptc.org.vn/blogs/11582/Solid-Wood-vs-Bamboo-Plywood-Sheets-Which-is-Better-for https://ameblo.jp/japanbamboo/entry-12966312597.html https://www.hssolar.cn/news-53.html https://blog.ulifestyle.com.hk/article/bothbest/4421706/wide-plank-bamboo-flooring-does-it-warp-faster-than-narrow-strips https://blog.ulifestyle.com.hk/article/econice/4421708/the-best-underlayment-for-bamboo-flooring https://official.link/Heavy-Duty-Bamboo-Panels-for-Countertops-Sealing-and-Maintenance-Tips https://playingwithsuperpower.com/forum/article-discussion/solid-wood-vs-bamboo-plywood-sheets-which-is-better-for-kitchen-cabinets/ https://velog.io/@bothbest/Preventing-Bowing-in-Large-Bamboo-Plywood-Sheets-for-Wardrobe-Doors https://www.ybookmarking.com/story/bamboo-flooring-china-factory-wholesale https://doks.komun.org/s/sixBlEUFTU https://codoc.jp/sites/bothbest/entries/4xV1ShYMUg https://naya.com.np/post/p17789154145y8zz https://mypaper.pchome.com.tw/bothbest/post/1384660161 https://www.cssauw.org/forum/thread-41347-1-1 https://forums.liyuans.com/thread/25915 https://www.glbrain.com/index.php?r=content/view&id=50097 https://www.youyooz.com/yooz/fire-ratings-and-solid-bamboo-panels-commercial-building-compliance-basics/ https://open.firstory.me/story/cmp80oi7u010i01toe7lr8ehx https://www.foriio.com/works/2388451/notes/51524 https://www.24liveblog.com/live/4111102063345409324 https://f-body.com/forum/f-body/f-body-cruise-in-for-general-discussion/265620-bamboo-flooring-acclimation-times-by-climate-zone-a-builder-s-checklist https://prismo.fedibird.com/posts/75a7eaa5-3296-4d33-97ab-235193a30cce https://www.guildquality.com/crew/post/80572 https://globbook.com/blogs/74508/Preventing-Mold-and-Mildew-on-Outdoor-Bamboo-Decks-in-High https://utas.me/bothbest/water-resistant-bamboo-plywood-can-you-use-it-for-bathroom-vanities-q1hci4o2/ https://cal.com/chinabamboo/exterior-bamboo-panels-can-they-survive-rain-and-uv-exposure-as-siding https://connect.usama.dev/blogs/75496/Formaldehyde-Free-Bamboo-Plywood-Sourcing-Safe-Materials-for-Your-Home https://comunidad.espoesia.com/bothbest/can-outdoor-bamboo-flooring-survive-freezing-winter-temperatures-and-snow-accumulation/ https://www.nextbizthing.com/articles/are-bamboo-panels-stronger-than-mdf-for-heavy-floating-shelves https://dominicanmaps.com/forum/topic/can-outdoor-bamboo-flooring-survive-freezing-winter/ https://berbagi.link/bothbest/article/e4f85ff0-5100-11f1-8679-c338dc62b199 https://ssn.so/forums/munpia-contest/topic/237448/ https://bothbest.systeme.io/bamboo/shipping-large-bamboo-panels-and-sheets-how-to-inspect-for-freight-damage https://2all.co.il/web/Sites20/bothbest/Article1.asp?ArticleRowID=21896
brockbar59
brockbar59 posted this 08 June 2026
This page is useful for anyone checking orthopaedic near me clinic appointment details. It lists Dr KMZ’s clinic locations, booking options, and available services for sports injuries, shoulder problems, knee ligament concerns, fractures, osteoarthritis, and other joint-related conditions as well.
This page is useful for anyone checking [orthopaedic near me clinic appointment details][1]. It lists Dr KMZ’s clinic locations, booking options, and available services for sports injuries, shoulder problems, knee ligament concerns, fractures, osteoarthritis, and other joint-related conditions as well. [1]: https://kmzorthoman.com/
