posted this
10 August 2015
According to our logs you're using Themler Desktop with HTML themes.
There are no Themler HTML themes on BillionThemes (except default theme). So, there is nothing to import from BillionThemes. If you want to import theme for another CMS you should load the theme of the appropriate CMS in Themler Desktop and them import a theme from Billionthemes.
Also, note, that currently there are no Artisteer themes for Themler on BillionThemes. You can import only Themler themes. This functionality works ok.
If you have troubles with importing Themler HTML theme back to Themler Desktop please attach the problem theme to this topic.
If you have troubles with importing **Themler** HTML theme back to Themler Desktop please attach the problem theme to this topic.
