posted this
15 August 2019
You can try, use Insert HTML control in Themler. As for the code itself, I can only suggest searching for it in the internet, for example: https://css-tricks.com/snippets/css/typewriter-effect/
Additional CSS can be added in Themler -> Home -> Settings-> additional CSS. If any JS should be added as well, you can add it to Additional Head HTML.
