Themler v1.0.59 Desktop Installation Updated and Joomla ARTX Support Added (10-Aug-2015)
Support Team posted this 10 August 2015
Hi everyone,
We've updated Themler Desktop Installation to resolve the following issues:
  • Fixed "Not found" error
  • Fixed issue with using Joomla in FireFox browser
  • You can finally import Joomla Artisteer projects directly into Themler!
Read more about this update here.
See Also
Previous updates
Themler Support Team
Hi everyone, We've updated Themler Desktop Installation to resolve the following issues: - Fixed "Not found" error - Fixed issue with using Joomla in FireFox browser - You can finally import **Joomla Artisteer projects** directly into Themler! Read more about this update [here](page:19107). ### See Also <a href="http://answers.billiondigital.com/categories/3916/">Previous updates</a> Thank you, Themler Support Team
17 Comments
mmp
mmp posted this 11 August 2015
I've created a template in new Artisteer and exported it as Themler / Joomla
I then opened Themler offline version and went to import from zip. I then got this error:
I then opened the Joomla administrator (CMS Admin Panel) Went to Install new template and tried to install the zip file into the templates. Got this error:
Clearly something is wrong. I used the default template of Artisteer without ANY editing just to test. So there was no customisation.
I have the newest Artisteer and uploaded the Themler version (Themler.1.0.59.39d2b) which is according to me the newest version. I can't verify this as I don't see a place in Themler where I can check the version.
I've created a template in new Artisteer and exported it as Themler / Joomla I then opened Themler offline version and went to import from zip. I then got this error: !failed.JPG! I then opened the Joomla administrator (CMS Admin Panel) Went to Install new template and tried to install the zip file into the templates. Got this error: !failed2.JPG! Clearly something is wrong. I used the default template of Artisteer without ANY editing just to test. So there was no customisation. I have the newest Artisteer and uploaded the Themler version (Themler.1.0.59.39d2b) which is according to me the newest version. I can't verify this as I don't see a place in Themler where I can check the version.
Support Team posted this 12 August 2015
Hi Stephan,
I've already responded to your in your previous ticket.
Let's continue our communication there.
Ivan
Hi Stephan, I've already responded to your in your previous ticket. Let's continue our communication there. Thanks, Ivan
Pixel
Pixel posted this 12 August 2015
Hi, I have the same problem as described by mmp.
Support Team posted this 13 August 2015
Hi Peter,
Could you please create the separate topic and provide your .artx and the exported .zip file.
Make sure that you are using the latest Artisteer version provided in the link from the initial topic.
Hi Peter, Could you please create the separate topic and provide your .artx and the exported .zip file. Make sure that you are using the latest Artisteer version provided in the link from the initial topic. Sincerely, Hella BillionDigital Team
For everyone having the same issue, please try to export the template using the Include Content option in Artisteer. Seems that the issue exists only with the templates that were exported without the content.
Our developers will look into this issue.
Hi, For everyone having the same issue, please try to export the template using the Include Content option in Artisteer. Seems that the issue exists only with the templates that were exported without the content. Our developers will look into this issue. Sincerely, Hella BillionDigital Team
DaveOzric
DaveOzric posted this 13 August 2015
Can you give even clearer instructions on how to open the Joomla project in the desktop version of themler?
Or is this not possible?
Can you give even clearer instructions on how to open the Joomla project in the desktop version of themler? Or is this not possible?
DaveOzric
Not sure what's going on. I realized I needed to install it in my local Joomla site as a zip. Then it was in my Themeler Desktop version list of themes.
When I opened it though it looked pretty much like the default untitled version so really not sure what happened there.
Do I need to import it from zip or something. Very confusing.
Not sure what's going on. I realized I needed to install it in my local Joomla site as a zip. Then it was in my Themeler Desktop version list of themes. When I opened it though it looked pretty much like the default untitled version so really not sure what happened there. Do I need to import it from zip or something. Very confusing.
Hi Dave,
  1. Export theme:
  2. Import theme:
You may see the default theme while opening Artisteer joomla theme. But you will see the proper theme after Themler finishes.
Hi Dave, 1. Export theme: !joomla-export2.png! 2. Import theme: !joomla-import.png! You may see the default theme while opening Artisteer joomla theme. But you will see the proper theme after Themler finishes. Thank you, Olivia
Dan Escoda
Dan Escoda posted this 13 August 2015
Dear Olivia
I have tried import from zip and I get: Sorry, error occurred. Your project will be restored. and the themler restarts again then I get the message again and restarts again and so never ends again and again but never finishes the process.
My artisteer license its ok for the themler export (just paid) and im using joomla in a localhost and also tried in a online version as well as in the windows themler app
please help, I have hundreds of artisteer themes to import!!
Danny
Dear Olivia I have tried import from zip and I get: **Sorry, error occurred. Your project will be restored.** and the themler restarts again then I get the message again and restarts again and so never ends again and again but never finishes the process. My artisteer license its ok for the themler export (just paid) and im using joomla in a localhost and also tried in a online version as well as in the windows themler app please help, I have hundreds of artisteer themes to import!! Thanks Danny
Hi Danny,
Could you please create a new Private topic and attach one of the converted joomla themes?
Hi Danny, Could you please create a new Private topic and attach one of the converted joomla themes? Thank you, Olivia
nobody
nobody posted this 30 August 2015
Same problem here, same error message, also tested localhost, online with thre of my servers and so on.
Can evernbody tell my the topic for fix this problem? Don't find the topic for this
Falls wer deutsch versteht: ich brauche ebenfalls eine Lösung für dieses Problem, hab es mehrfach auf verschiedenen Servern und local versucht. Aktuelle Versionen sowohl von Artisteer und Themler heute nochmal neu heruntergeladen, installiert, mit blanekm Standardtemple von Artisteer verscuht und mit eigenen exact immer dier gleiche Fehler wie schon oben beschrieben ... :-(((
Same problem here, same error message, also tested localhost, online with thre of my servers and so on. Can evernbody tell my the topic for fix this problem? Don't find the topic for this Falls wer deutsch versteht: ich brauche ebenfalls eine Lösung für dieses Problem, hab es mehrfach auf verschiedenen Servern und local versucht. Aktuelle Versionen sowohl von Artisteer und Themler heute nochmal neu heruntergeladen, installiert, mit blanekm Standardtemple von Artisteer verscuht und mit eigenen exact immer dier gleiche Fehler wie schon oben beschrieben ... :-(((
Support Team posted this 01 September 2015
Hello Reinhard,
I confirm that there's a problem on our end with Joomla templates. Now they should be exported with content from Artisteer. The fix for this issue will be included into the next Themler update.
If you exported Artisteer template with content and the error persists please create a new private topic http://answers.billiondigital.com/Topic/Create?private=1 and attach the .artx file and zipped exported theme.
Hello Reinhard, > For everyone having the same issue, please try to export the template > using the Include Content option in Artisteer. Seems that the issue > exists only with the templates that were exported without the content. I confirm that there's a problem on our end with Joomla templates. Now they should be *exported with content* from Artisteer. The fix for this issue will be included into the next Themler update. If you exported Artisteer template with content and the error persists please create a new private topic http://answers.billiondigital.com/Topic/Create?private=1 and attach the .artx file and zipped exported theme. Regards, Aileen
Damy
Damy posted this 09 October 2015
Hello Themler Support,
I cannt see "Themler" in the export section ? how to export my Wordpress theme into Themler ?
Thanks!
Hello Themler Support, I cannt see "Themler" in the export section ? how to export my Wordpress theme into Themler ? Thanks!
Support Team posted this 10 October 2015
Please make sure that your have downloaded the proper Artisteer version:
http://files4.artisteer.com/Artisteer.4.3.0.60858.exe
Hi, Please make sure that your have downloaded the proper Artisteer version: http://files4.artisteer.com/Artisteer.4.3.0.60858.exe Sincerely, Hella
contato69
contato69 posted this 23 October 2016
This import only works for pro version or works for every one?
I had a standart version and in ARTISTEER(4.3.0.60858) show up export for themler in themler(v349) not show up how to import the theme.
This import only works for pro version or works for every one? I had a standart version and in ARTISTEER(4.3.0.60858) show up export for themler in themler(v349) not show up how to import the theme.
Support Team posted this 24 October 2016
To import the theme exported from Artisteer use the File >> Import from .zip option in Themler.
You will be able to import themes that are available in your subscription. So if you have Personal subscription, you can import HTML and WP themes.
Hi, To import the theme exported from Artisteer use the File >> Import from .zip option in Themler. You will be able to import themes that are available in your subscription. So if you have Personal subscription, you can import HTML and WP themes. Sincerely, Hella
edwardterrya7725
edwardterrya7725 posted this 10 September 2024
I experimented by using Artisteer's default template without making any changes. Thus, there was no personalization.
driveway resurfacing contractors
I experimented by using Artisteer's default template without making any changes. Thus, there was no personalization. . . [driveway resurfacing contractors][1] [1]: https://hamiltonconcretedriveway.co.nz/
