I created a form with RSForms!Pro v2.2.6 (Joomla!-Version 3.9.11) with a Drop-Down-Field. On loading the form I got following error:
Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /home/httpd/vhosts/suistore.ch/multimediacreation.ch/templates/untitled/functions.php on line 201
I did change continue in continue 2 in functions.php and the form displays perfectly, except that the Drop-Down doesn't work on Safari (Firefox OK).
The site simply reloads due to an error (try yourself): https://mmc-schneider.com/index.php?option=com_rsform&view=rsform&formId=7
How do I fix this error?
On the standard Joomla-templates it works perfectly.
Daniel
I created a form with RSForms!Pro v2.2.6 (Joomla!-Version 3.9.11) with a Drop-Down-Field. On loading the form I got following error: Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /home/httpd/vhosts/suistore.ch/multimediacreation.ch/templates/untitled/functions.php on line 201 I did change continue in continue 2 in functions.php and the form displays perfectly, except that the Drop-Down doesn't work on Safari (Firefox OK). The site simply reloads due to an error (try yourself): https://mmc-schneider.com/index.php?option=com_rsform&view=rsform&formId=7 How do I fix this error? On the standard Joomla-templates it works perfectly. DanielLast edited 24 August 2019 by dani.schneider
