PHP ERROR
Werbeagentur Schulz-Design
Werbeagentur Schulz-Design posted this 12 September 2019
When I try to start Themler, I get an error message.
I already deleted the cache, but that did not help.
Do you have an idea why this may be?
Thank you for the timely response.
Best regards
Thorsten Schulz
Hello, When I try to start Themler, I get an error message. I already deleted the cache, but that did not help. Do you have an idea why this may be? Thank you for the timely response. Best regards Thorsten Schulz
344 Comments
Support Team posted this 12 September 2019
Hello Thorsten,
Does the issue appear in Themler desktop? If so, please try the following:
try to rename the following folder into joomla-old and try to run Themler once again:
C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla
Then update the theme in question to the latest Themler version.
This should help.
Hello Thorsten, Does the issue appear in Themler desktop? If so, please try the following: try to rename the following folder into **joomla-old** and try to run Themler once again: C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla Then update the theme in question to the latest Themler version. This should help. Sincerely, Nettie
Werbeagentur Schulz-Design posted this 13 September 2019
Hello Nettie,
many thanks for your response.
No, I use the online version of Themler.
The problem still occurs.
Thorsten
Hello Nettie, many thanks for your response. No, I use the online version of Themler. The problem still occurs. Sincerely, Thorsten
Support Team posted this 13 September 2019
Hello Thorsten,
Have you updated Joomla to 3.9 recently?
Please follow these steps to fix the current theme:
https://answers.themler.io/articles/173620/how-to-fix-the-error-after-updating-to-joomla-3-9
After this update the theme to the latest Themler version that supports Joomla 3.9.
Hello Thorsten, Hello, Have you updated Joomla to 3.9 recently? Please follow these steps to fix the current theme: https://answers.themler.io/articles/173620/how-to-fix-the-error-after-updating-to-joomla-3-9 After this update the theme to the latest Themler version that supports Joomla 3.9. Sincerely, Nettie
Hello Nettie,
Thank you. No, I'm using the latest version of Themler. The error message is new.
According to the error message, the marked path in the attached screenshot does not exist.
The autoload.php is located directly in the directory '/var/www/uigmbh.de/htdocs/administrator/components/com_autotweet'
Hello Nettie, Thank you. No, I'm using the latest version of Themler. The error message is new. According to the error message, the marked path in the attached screenshot does not exist. The autoload.php is located directly in the directory '/var/www/uigmbh.de/htdocs/administrator/components/com_autotweet'
Have you possibly updated Virtuemart recently to 3.6? There is a known issue with it and it is under investigation.
Hello, Have you possibly updated Virtuemart recently to 3.6? There is a known issue with it and it is under investigation. Sincerely, Nettie
Werbeagentur Schulz-Design posted this 16 September 2019
Hello Nettie,
Thanks for your answers.
Please deal with the problem and the documentation provided.
The problem with the VirtueMart update is known to us. We have problems with this on another website.
I even wrote a private message, but have not received a reply.
Thorsten
Hello Nettie, Thanks for your answers. Please deal with the problem and the documentation provided. The problem with the VirtueMart update is known to us. We have problems with this on another website. I even wrote a private message, but have not received a reply. Sincerely, Thorsten
Can it possibly be due to the PHP version 7.3?
Support Team posted this 17 September 2019
Thorsten,
Based on the error message from your screenshot, it is related to some autotweet plugin.
Could you please try disabling it?
Thorsten, Based on the error message from your screenshot, it is related to some autotweet plugin. Could you please try disabling it? Gina Themler Support
Werbeagentur Schulz-Design posted this 17 September 2019
Hello Gina,
Yes, that was the problem.
Removing the extension helped.
Thorsten
Hello Gina, many thanks for your response. Yes, that was the problem. Removing the extension helped. Sincerely, Thorsten [Werbeagentur Schulz-Design][1] [1]: https://www.schulzdesign.info/ "Werbeagentur Schulz-Design"
studwork1742
studwork1742 posted this 17 November 2025
Ostatnio miałem wolny wieczór i szukałem czegoś, żeby się trochę rozerwać. Wpisałem w przeglądarkę strony z grami i trafiłem na rolldorado kasyno. Strona wygląda przejrzyście, bez zbędnych ozdobników, a gry działają płynnie. Dostałem bonus powitalny, który pozwolił mi zagrać dłużej. Lubię, że nie trzeba mieć dużego doświadczenia, żeby się dobrze bawić. Teraz często tam zaglądam, gdy chcę odpocząć po pracy i po prostu się odprężyć.
Ostatnio miałem wolny wieczór i szukałem czegoś, żeby się trochę rozerwać. Wpisałem w przeglądarkę strony z grami i trafiłem na [rolldorado kasyno][1]. Strona wygląda przejrzyście, bez zbędnych ozdobników, a gry działają płynnie. Dostałem bonus powitalny, który pozwolił mi zagrać dłużej. Lubię, że nie trzeba mieć dużego doświadczenia, żeby się dobrze bawić. Teraz często tam zaglądam, gdy chcę odpocząć po pracy i po prostu się odprężyć. [1]: https://roll-dorado.pl
support233
support233 posted this 17 November 2025
hmm, sounds frustrating! Honestly, dealing with "autoload.php" issues in '/var/www/uigmbh.de...' gives me shivers. It reminds me of debugging after work - Plants vs Brainrots online sounds way more appealing, you know? Wonder if Thorsten needed a coffee break too.
hmm, sounds frustrating! Honestly, dealing with "autoload.php" issues in '/var/www/uigmbh.de...' gives me shivers. It reminds me of debugging after work - [Plants vs Brainrots online][1] sounds way more appealing, you know? Wonder if Thorsten needed a coffee break too. [1]: https://plants-vs-brainrots.io
xcargo
xcargo posted this 02 June 2026
The best blinds combine functionality and style, offering privacy, light control, and lasting value for your home. Browse the best blinds available in a variety of colors, textures, and designs to complement any interior décor. Transform your space with the best blinds, designed to provide comfort, elegance, and effortless light management.
The best blinds combine functionality and style, offering privacy, light control, and lasting value for your home. Browse the best blinds available in a variety of colors, textures, and designs to complement any interior décor. Transform your space with the [best blinds][1], designed to provide comfort, elegance, and effortless light management. [1]: https://winmaxblinds.ca
Werbeagentur Schulz-Design posted this 03 June 2026
If there is only spamming here and no one is interested, I will now also do a bit of advertising for our web design services:
Webdesign-Leistungen:
Webdesign Hannover
Joomla Webdesign
SSD Webhosting
Joomla Migration
Administration und Pflege
CMS Templatedesign
Suchmaschinenoptimierung SEO
If there is only spamming here and no one is interested, I will now also do a bit of advertising for our web design services: **[Webdesign-Leistungen][1]:** [Webdesign Hannover][2] [Joomla Webdesign][3] [SSD Webhosting][4] [Joomla Migration][5] [Administration und Pflege][6] [CMS Templatedesign][7] [Suchmaschinenoptimierung SEO][8] [1]: https://webdesign-hannover-laatzen.de/ [2]: https://webdesign-hannover-laatzen.de/webdesign [3]: https://webdesign-hannover-laatzen.de/joomla-webdesign [4]: https://webdesign-hannover-laatzen.de/webhosting [5]: https://webdesign-hannover-laatzen.de/joomla-migration [6]: https://webdesign-hannover-laatzen.de/administration-pflege [7]: https://webdesign-hannover-laatzen.de/cms-templatedesign [8]: https://webdesign-hannover-laatzen.de/suchmaschinenoptimierung-seo
harukitanaka1295
harukitanaka1295 posted this 05 June 2026
Remember that the internal local engine inside the desktop application runs on an older, fixed PHP environment. If you try to paste modern PHP code blocks or functions that require PHP 8 into a custom HTML control block inside the desktop editor, it will instantly throw an internal server error.
aviator demo game
Remember that the internal local engine inside the desktop application runs on an older, fixed PHP environment. If you try to paste modern PHP code blocks or functions that require PHP 8 into a custom HTML control block inside the desktop editor, it will instantly throw an internal server error. [aviator demo game][1] [1]: https://allnewyonorummyapk.com/aviator/winexch-aviator-app/
JulianReed
JulianReed posted this 05 June 2026
https://www.linkcentre.com/profile/JulianReed/
https://www.startupfa.st/startup/gemini-omni-ai-video-generator-craft-cinematic-videos
https://homebusinessmag.com/author/geminiomniai/
[https://www.linkcentre.com/profile/JulianReed/][1] [https://www.startupfa.st/startup/gemini-omni-ai-video-generator-craft-cinematic-videos][2] [https://homebusinessmag.com/author/geminiomniai/][3] [1]: https://www.linkcentre.com/profile/JulianReed/ [2]: https://www.startupfa.st/startup/gemini-omni-ai-video-generator-craft-cinematic-videos [3]: https://homebusinessmag.com/author/geminiomniai/
chinahousehold
chinahousehold posted this 13 June 2026
http://idb.uwu.ac.lk/discussion/detail/564191
http://idb.uwu.ac.lk/discussion/detail/564193
http://idb.uwu.ac.lk/discussion/detail/564195
https://24live.co/live/4130648520738197849
https://bothbest.nicepage.io/blog/factory-process-behind-the-perfect-electric-standing-desk-bamboo-desktop.html
https://www.sooplive.com/station/bothbest/post/198450869
https://2all.co.il/web/Sites20/bothbest/Article1.asp?ArticleRowID=21999
https://bambooflooring.alboompro.com/post/constant-motion-of-an-electric-standing-desk
https://bambooflooring.theblog.me/posts/58924299
https://japanbamboo.storeinfo.jp/posts/58924307
https://bamboochopsticks.storeinfo.jp/posts/58924267
https://cal.com/chinabamboo/why-a-bothbest-bamboo-table-top-reduces-wrist-fatigue
https://hssolar.base44.app/blog/6a2b7f1a22c6b707a17e35ab
https://hssolar.base44.app/blog/6a2b7f07244b94d30852d345
https://hssolar.base44.app/blog/6a2b7f2ed344929fb09f824d
https://beta.cent.co/bothbest/+2rvwkk
https://bothbest.ccwu.cc/
https://bothbest.cc.cd/
https://friendchat.fun/blogs/26581/Why-a-Bothbest-Bamboo-Table-Top-Reduces-Wrist-Fatigue
https://chinabamboo.readme.io/reference/builders-choose-bothbest-over-traditional-green
https://bothbest.shotblogs.com/traditional-green-building-supply-outlets-55858029
https://bothbest.ampedpages.com/choose-bothbest-over-traditional-green-building-68736702
https://www.anibookmark.com/site/bamboo-flooring-company-ab2305643.html
https://bothbest.blogminds.com/why-savvy-builders-choose-bothbest-over-traditional-38583036
https://bothbest.mybjjblog.com/choose-bothbest-over-traditional-green-building-supply-outlets-53896072
https://bothbest.isblog.net/guide-to-bamboo-flooring-why-bothbest-strand-59070261
https://telegra.ph/Why-Bothbest-Strand-Woven-Defeats-Scratches-06-10
https://www.webtoons.com/p/community/en/u/_pixmf9
https://fundraising.stjude.org/site/TR?px=9208628&fr_id=162729&pg=personal
https://colibris-wiki.org/gotransition/?hssolar
https://xtend.metrotvnews.com/Security/Profile/Public/2923
https://devnet.kentico.com/users/553360/richard-markson
https://socialytime.com/blogs/136022/The-Pet-Owner-s-Guide-to-Bamboo-Flooring
https://o4ezhzklmi55thxs.umso.co/blog/why-bothbest-strand-woven-defeats-scratches
https://www.patreon.com/cw/bothbest
https://www.patreon.com/posts/pet-owners-guide-160576032
https://www.patreon.com/posts/bringing-dark-to-136510252
https://bothbest.netlify.app/toxic-glue-or-safe-resin
https://bothbest.netlify.app/how-to-protect-your-solar-system
https://divekeeper.com/forums/discussion/general-discussion/bothbest-over-traditional-green-building-supply-outlets
https://eurodistl.com.ng/distributors/home/topic/the-safe-home-guide-why-bothbest-non-toxic-bamboo-flooring-company-leads-in-air-quality/
http://idb.uwu.ac.lk/discussion/detail/564191 http://idb.uwu.ac.lk/discussion/detail/564193 http://idb.uwu.ac.lk/discussion/detail/564195 https://24live.co/live/4130648520738197849 https://bothbest.nicepage.io/blog/factory-process-behind-the-perfect-electric-standing-desk-bamboo-desktop.html https://www.sooplive.com/station/bothbest/post/198450869 https://2all.co.il/web/Sites20/bothbest/Article1.asp?ArticleRowID=21999 https://bambooflooring.alboompro.com/post/constant-motion-of-an-electric-standing-desk https://bambooflooring.theblog.me/posts/58924299 https://japanbamboo.storeinfo.jp/posts/58924307 https://bamboochopsticks.storeinfo.jp/posts/58924267 https://cal.com/chinabamboo/why-a-bothbest-bamboo-table-top-reduces-wrist-fatigue https://hssolar.base44.app/blog/6a2b7f1a22c6b707a17e35ab https://hssolar.base44.app/blog/6a2b7f07244b94d30852d345 https://hssolar.base44.app/blog/6a2b7f2ed344929fb09f824d https://beta.cent.co/bothbest/+2rvwkk https://bothbest.ccwu.cc/ https://bothbest.cc.cd/ https://friendchat.fun/blogs/26581/Why-a-Bothbest-Bamboo-Table-Top-Reduces-Wrist-Fatigue https://chinabamboo.readme.io/reference/builders-choose-bothbest-over-traditional-green https://bothbest.shotblogs.com/traditional-green-building-supply-outlets-55858029 https://bothbest.ampedpages.com/choose-bothbest-over-traditional-green-building-68736702 https://www.anibookmark.com/site/bamboo-flooring-company-ab2305643.html https://bothbest.blogminds.com/why-savvy-builders-choose-bothbest-over-traditional-38583036 https://bothbest.mybjjblog.com/choose-bothbest-over-traditional-green-building-supply-outlets-53896072 https://bothbest.isblog.net/guide-to-bamboo-flooring-why-bothbest-strand-59070261 https://telegra.ph/Why-Bothbest-Strand-Woven-Defeats-Scratches-06-10 https://www.webtoons.com/p/community/en/u/_pixmf9 https://fundraising.stjude.org/site/TR?px=9208628&fr_id=162729&pg=personal https://colibris-wiki.org/gotransition/?hssolar https://xtend.metrotvnews.com/Security/Profile/Public/2923 https://devnet.kentico.com/users/553360/richard-markson https://socialytime.com/blogs/136022/The-Pet-Owner-s-Guide-to-Bamboo-Flooring https://o4ezhzklmi55thxs.umso.co/blog/why-bothbest-strand-woven-defeats-scratches https://www.patreon.com/cw/bothbest https://www.patreon.com/posts/pet-owners-guide-160576032 https://www.patreon.com/posts/bringing-dark-to-136510252 https://bothbest.netlify.app/toxic-glue-or-safe-resin https://bothbest.netlify.app/how-to-protect-your-solar-system https://divekeeper.com/forums/discussion/general-discussion/bothbest-over-traditional-green-building-supply-outlets https://eurodistl.com.ng/distributors/home/topic/the-safe-home-guide-why-bothbest-non-toxic-bamboo-flooring-company-leads-in-air-quality/
JulianReed
JulianReed posted this 14 June 2026
https://pubmag.ru/ru/domain/geminiomni-co/
https://aitoolscorner.com/gemini-omni-ai-video-generator-1960
https://www.rankanything.online/reviews/gemini-omni-ai-video-generator-RrDdzMMTTe
[https://pubmag.ru/ru/domain/geminiomni-co/][1] [https://aitoolscorner.com/gemini-omni-ai-video-generator-1960][2] [https://www.rankanything.online/reviews/gemini-omni-ai-video-generator-RrDdzMMTTe][3] [1]: https://pubmag.ru/ru/domain/geminiomni-co/ [2]: https://aitoolscorner.com/gemini-omni-ai-video-generator-1960 [3]: https://www.rankanything.online/reviews/gemini-omni-ai-video-generator-RrDdzMMTTe
caris040
caris040 posted this 30 June 2026
https://elearn.ellak.gr/mod/forum/discuss.php?d=62587
https://elearn.ellak.gr/mod/forum/discuss.php?d=62588
https://scope.bccampus.ca/mod/forum/discuss.php?d=87229
https://dumpscafe.cohota.com/courses/5158/pages/celebrate-usa-independence-day-with-70-percent-off-agentforce-specialist-exam-dumps-at-dumpscafe
https://matters.town/a/4gie0mi6emh0
https://matters.town/a/iwkdk5xywd67
https://www.linkedin.com/pulse/celebrate-usa-independence-day-70-off-nrcma-exam-prep-certsout-pikqf/
https://www.linkedin.com/pulse/celebrate-usa-independence-day-70-off-xsiam-engineer-exam-gpi5f/
https://my.talladega.edu/ICS/portletview/Academics/BUS/BUS__368/2015_SP-BUS__368-FT/Blog_243.jnz?portlet=Blog_243&screen=View+Post&screenType=next&&Id=0f08a761-428d-4d59-82c6-16830390fd81
https://github.com/Sophiejohny/practice-tests/issues/37
https://6a435dc4bba4d.site123.me/
https://200-301dumpscafe.alboompro.com/post/celebrate-usa-independence-day-with-70-off-200-301-exam-dumps-at-dumpscafe
https://www.tripadvisor.co/Profile/agentforce-specialis
https://www.reddit.com/user/Lilyscot/
https://studylib.net/doc/28664303/dumps-cafe-paloalto-networks-xsiam-engineer
https://www.coursehero.com/file/255621674/Dumps-Cafe-Nutanix-NCP-MCI-610pdf/
https://www.coursehero.com/file/255621672/DumpsCafe-Salesforce-Agentforce-Specialistpdf/
https://www.coursehero.com/file/255621671/Dumps-Cafe-CompTIA-220-1201pdf/
https://www.coursehero.com/file/255621652/DumpsCafe-The-Open-Group-OGEA-101pdf/
https://elearn.ellak.gr/mod/forum/discuss.php?d=62587 https://elearn.ellak.gr/mod/forum/discuss.php?d=62588 https://scope.bccampus.ca/mod/forum/discuss.php?d=87229 https://dumpscafe.cohota.com/courses/5158/pages/celebrate-usa-independence-day-with-70-percent-off-agentforce-specialist-exam-dumps-at-dumpscafe https://matters.town/a/4gie0mi6emh0 https://matters.town/a/iwkdk5xywd67 https://www.linkedin.com/pulse/celebrate-usa-independence-day-70-off-nrcma-exam-prep-certsout-pikqf/ https://www.linkedin.com/pulse/celebrate-usa-independence-day-70-off-xsiam-engineer-exam-gpi5f/ https://my.talladega.edu/ICS/_portletview_/Academics/BUS/BUS__368/2015_SP-BUS__368-FT/Blog_243.jnz?portlet=Blog_243&screen=View+Post&screenType=next&&Id=0f08a761-428d-4d59-82c6-16830390fd81 https://github.com/Sophiejohny/practice-tests/issues/37 https://6a435dc4bba4d.site123.me/ https://200-301dumpscafe.alboompro.com/post/celebrate-usa-independence-day-with-70-off-200-301-exam-dumps-at-dumpscafe https://www.tripadvisor.co/Profile/agentforce-specialis https://www.reddit.com/user/Lilyscot/ https://studylib.net/doc/28664303/dumps-cafe-paloalto-networks-xsiam-engineer https://www.coursehero.com/file/255621674/Dumps-Cafe-Nutanix-NCP-MCI-610pdf/ https://www.coursehero.com/file/255621672/DumpsCafe-Salesforce-Agentforce-Specialistpdf/ https://www.coursehero.com/file/255621671/Dumps-Cafe-CompTIA-220-1201pdf/ https://www.coursehero.com/file/255621652/DumpsCafe-The-Open-Group-OGEA-101pdf/
JulianReed
JulianReed posted this 11 July 2026
Good list of AI https://linktr.ee/JulianReed99988
Muse Video and the New AI Video Stack: From Prompt Experiments to Production Workflows
Good AI List
Muse Video AI
Muse Video
https://passport-us.bignox.com/sso/logout?service=https://musevideo.art
https://pt.tapatalk.com/redirect.php?app_id=4&fid=8678&url=https://musevideo.art
https://store.law.com/linkredirector/default.asp?lrcat=BLOGNetwork&lrurl=https%3A%2F%2Fmusevideo.art%2Fenter link description here
https://smart.link/5ced9b72faea9?cp_1=https%3A%2F%2Fmusevideo.art%2F&cp_2=vw1009&cp_3&creative_id=vw1009&site_id=Soc_NBCU_Symphony
https://es.catholic.net/ligas/ligasframe.phtml?liga=https://musevideo.art
https://moshtix.com.au/v2/marketing/email-click?broadcastId=13698&customerProfileIdEncrypted=0&eventOrganiserId=4406&redirectUrl=https://musevideo.art
https://trylaunch.ai/launch/gemini-omni-ai-video-generator-co
https://makerlist.io/tool/28773-gemini-omni-ai-video-generator
Good list of AI [https://linktr.ee/JulianReed99988][1] [Muse Video and the New AI Video Stack: From Prompt Experiments to Production Workflows][2] [Good AI List][3] [Muse Video AI][4] [Muse Video][5] [https://passport-us.bignox.com/sso/logout?service=https://musevideo.art][6] [https://pt.tapatalk.com/redirect.php?app_id=4&fid=8678&url=https://musevideo.art][7] https://store.law.com/linkredirector/default.asp?lrcat=BLOGNetwork&lrurl=https%3A%2F%2Fmusevideo.art%2F[enter link description here][8] [https://smart.link/5ced9b72faea9?cp_1=https%3A%2F%2Fmusevideo.art%2F&cp_2=vw1009&cp_3&creative_id=vw1009&site_id=Soc_NBCU_Symphony][9] [https://es.catholic.net/ligas/ligasframe.phtml?liga=https://musevideo.art][10] [https://moshtix.com.au/v2/marketing/email-click?broadcastId=13698&customerProfileIdEncrypted=0&eventOrganiserId=4406&redirectUrl=https://musevideo.art][11] [https://trylaunch.ai/launch/gemini-omni-ai-video-generator-co][12] [https://makerlist.io/tool/28773-gemini-omni-ai-video-generator][13] [1]: https://linktr.ee/JulianReed99988 [2]: https://dev.to/stellan/muse-video-and-the-new-ai-video-stack-from-prompt-experiments-to-production-workflows-eed [3]: https://julian-reed-2.jimdosite.com/ [4]: https://cas.mon-ent-occitanie.fr/login?gateway=true&service=https://musevideo.art/ [5]: https://live.warthunder.com/away/?to=https://musevideo.art/ [6]: https://passport-us.bignox.com/sso/logout?service=https://musevideo.art [7]: https://pt.tapatalk.com/redirect.php?app_id=4&fid=8678&url=https://musevideo.art [8]: https://store.law.com/linkredirector/default.asp?lrcat=BLOGNetwork&lrurl=https://musevideo.art/ [9]: https://smart.link/5ced9b72faea9?cp_1=https://musevideo.art/&cp_2=vw1009&cp_3&creative_id=vw1009&site_id=Soc_NBCU_Symphony [10]: https://es.catholic.net/ligas/ligasframe.phtml?liga=https://musevideo.art [11]: https://moshtix.com.au/v2/marketing/email-click?broadcastId=13698&customerProfileIdEncrypted=0&eventOrganiserId=4406&redirectUrl=https://musevideo.art [12]: https://trylaunch.ai/launch/gemini-omni-ai-video-generator-co [13]: https://makerlist.io/tool/28773-gemini-omni-ai-video-generator
posis73412
posis73412 posted this 16 August 2026
This is very educational content and written well for a change. It's nice to see that some people still understand how to write a quality post.! Starzbet
This is very educational content and written well for a change. It's nice to see that some people still understand how to write a quality post.! [Starzbet](https://starzbetturkiye.com/)
