Changing of layout generates warning message
cynthia4
cynthia4 posted this 17 September 2019
Whenever I change something in the template in Joomla I get the following message:
"Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /customers/7/a/b/princestockholm.se/httpd.www/Joomla/templates/princesthlm2019/functions.php on line 201"
That means I have to go into the functions.php every time to add "2" in order to make the line disappear????
Whenever I change something in the template in Joomla I get the following message: "Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /customers/7/a/b/princestockholm.se/httpd.www/Joomla/templates/princesthlm2019/functions.php on line 201" That means I have to go into the functions.php every time to add "2" in order to make the line disappear????
Support Team posted this 18 September 2019
Hello Cynthia,
This issue is reported to the developers. Meanwhile, you can manually add 2, as you mentioned. Or you can disable warnings in Joomla, since it doesn't affect any functionality.
Hello Cynthia, This issue is reported to the developers. Meanwhile, you can manually add 2, as you mentioned. Or you can [disable warnings in Joomla][1], since it doesn't affect any functionality. Gina Themler Support [1]: https://www.joomlashack.com/blog/joomla/warnings/
cynthia4
cynthia4 posted this 18 September 2019
Ok, thanks.
Ok, thanks.
