Themler theme, woocommerce obsolete files
a.paladini
a.paladini posted this 18 October 2019
After updating woocommerce to the latest version (3.7.1) Wordpress is giving the following message:
"The theme (xxx) contains obsolete copies of some WooCommerce files within the theme installed with themler. These files should be updated to be compatible with the current version of WooCommerce.
below the indicated files:
theme (xxx) /woocommerce/archive-product.php version 3.3.0 is obsolete. The current version is 3.4.0,
theme (xxx) /woocommerce/cart/cart.php version 3.3.0 is obsolete. The current version is 3.7.0,
theme (xxx) /woocommerce/loop/result-count.php version 3.3.0 is obsolete. The current version is 3.7.0,
theme (xxx) /woocommerce/loop/sale-flash.php,
theme (xxx) /woocommerce/notices/error.php version 3.3.0 is obsolete. The current version is 3.5.0,
theme (xxx) /woocommerce/notices/notice.php version 1.6.4 is obsolete. The current version is 3.5.0,
theme (xxx) /woocommerce/notices/success.php version 3.3.0 is obsolete. The current version is 3.5.0,
theme (xxx) /product-searchform.php,
theme (xxx) /woocommerce/single-product.php
if I follow the instructions on how to solve the problem, this message (above) no longer appears, rather it indicates that the files are aligned to the latest version; but in the front of the website the layout of the shop (woocommerce) has changed, losing the designed structure (it is not presentable) and if I go in themler it cannot be edited
how can i solve?
Alessandro
Best Regards
After updating woocommerce to the latest version (3.7.1) Wordpress is giving the following message: "The theme (xxx) contains obsolete copies of some WooCommerce files within the theme installed with themler. These files should be updated to be compatible with the current version of WooCommerce. below the indicated files: theme (xxx) /woocommerce/archive-product.php version 3.3.0 is obsolete. The current version is 3.4.0, theme (xxx) /woocommerce/cart/cart.php version 3.3.0 is obsolete. The current version is 3.7.0, theme (xxx) /woocommerce/loop/result-count.php version 3.3.0 is obsolete. The current version is 3.7.0, theme (xxx) /woocommerce/loop/sale-flash.php, theme (xxx) /woocommerce/notices/error.php version 3.3.0 is obsolete. The current version is 3.5.0, theme (xxx) /woocommerce/notices/notice.php version 1.6.4 is obsolete. The current version is 3.5.0, theme (xxx) /woocommerce/notices/success.php version 3.3.0 is obsolete. The current version is 3.5.0, theme (xxx) /product-searchform.php, theme (xxx) /woocommerce/single-product.php if I follow the instructions on how to solve the problem, this message (above) no longer appears, rather it indicates that the files are aligned to the latest version; but in the front of the website the layout of the shop (woocommerce) has changed, losing the designed structure (it is not presentable) and if I go in themler it cannot be edited how can i solve? Alessandro Best Regards
khankhan225264
khankhan225264 posted this 04 October 2025
Ropartifire APK is a simple and useful app that many users enjoy for its smooth performance. It is easy to download, works well on different devices, and provides a reliable experience. The app is also updated regularly, making it a good option for those who want both stability and ease of use. Discover more about this app here ropartifire.net/
Ropartifire APK is a simple and useful app that many users enjoy for its smooth performance. It is easy to download, works well on different devices, and provides a reliable experience. The app is also updated regularly, making it a good option for those who want both stability and ease of use. Discover more about this app here [ropartifire.net/][1] [1]: https://ropartifire.net
