unable the option post
arawolf
arawolf posted this 23 October 2019
How can i unable the option : when you click on a image in a blog article the surfs to a postpage.
Support Team posted this 24 October 2019
Hello Kris,
Please, remind if your are using WP or Joomla.
Hello Kris, Please, remind if your are using WP or Joomla. Gina Themler Support
arawolf
arawolf posted this 24 October 2019
sorry joomla
sorry joomla
Support Team posted this 28 October 2019
Sorry for the delay.
Themler doesn't have a setting for this.
I have found a solution in the internet but it would require removing Read-more as well.
If that doesn't work for you, we will need your theme attached. I will search for the php files where you can remove this link manually. But you will need to apply this workaround every time you publish the theme from Themler.
Sorry for the delay. Themler doesn't have a setting for this. I have found a [solution][1] in the internet but it would require removing Read-more as well. If that doesn't work for you, we will need your theme attached. I will search for the php files where you can remove this link manually. But you will need to apply this workaround every time you publish the theme from Themler. Gina Themler Support [1]: https://www.templatemonster.com/help/joomla-3-x-remove-links-articles-articles-images.html
