modelli obsoleti template woocommerce
Luigi Scupola
Luigi Scupola posted this 09 November 2019
Come da screenshot, Woocommerce rileva che i file sono obsoleti. Forse รจ necessario un aggiornamento. Versione Woocommerce 3.8.0
Come da screenshot, Woocommerce rileva che i file sono obsoleti. Forse è necessario un aggiornamento. Versione Woocommerce 3.8.0
Support Team posted this 11 November 2019
Hello Luigi,
If you are using Themler 484 or higher, this message won't be causing any incompatibility. This message means that WooCommerce version mentioned in those files are old. We will fix it in future, meanwhile you can leave it as is or update those files manually by simply changing WooCommerce version mentioned there.
Hello Luigi, If you are using Themler 484 or higher, this message won't be causing any incompatibility. This message means that WooCommerce version mentioned in those files are old. We will fix it in future, meanwhile you can leave it as is or update those files manually by simply changing WooCommerce version mentioned there. Gina Themler Support
