First, thanks for a great product. It takes a little time to understand what Themler can do, but it's well worth the effort.
I've created templates for two Joomla! sites using the ecommerce extension HikaShop. HikaShop has a configuration option to 'Use Bootstrap design', which can be toggled on or off. The problem is this: with the option on, a page listing all the products in a given category displays in a single column even when it's set to display in multiple columns; with the option off, the product listing displays correctly but is not properly responsive (items overlap on a small screen). This is one of the sites, currently with 'Use Bootstrap design' turned off: http://www.thelavenderlady.co.uk/index.php/shop
I asked for help on the HikaShop forum, and got the following reply:
"Your template seems to load some Bootstrap 3, but not Bootstrap 2. But HikaShop is, like native Joomla, supporting only Bootstrap 2 (though BS 3 support is under way, I hear). So, turning Bootstrap off in HikaShop is the right thing to do for you. "Missing responsiveness" can then be added with custom CSS and media queries....More similar code may be required for other shop elements or pages, of course."
This reduces the usefulness to me of a Themler template quite considerably, since I often use HikaShop. Is there a simpler fix, at least until Bootstrap 3 is fully supported?
First, thanks for a great product. It takes a little time to understand what Themler can do, but it's well worth the effort. I've created templates for two Joomla! sites using the ecommerce extension HikaShop. HikaShop has a configuration option to 'Use Bootstrap design', which can be toggled on or off. The problem is this: with the option on, a page listing all the products in a given category displays in a single column even when it's set to display in multiple columns; with the option off, the product listing displays correctly but is not properly responsive (items overlap on a small screen). This is one of the sites, currently with 'Use Bootstrap design' turned off: http://www.thelavenderlady.co.uk/index.php/shop I asked for help on the HikaShop forum, and got the following reply: "Your template seems to load some Bootstrap 3, but not Bootstrap 2. But HikaShop is, like native Joomla, supporting only Bootstrap 2 (though BS 3 support is under way, I hear). So, turning Bootstrap off in HikaShop is the right thing to do for you. "Missing responsiveness" can then be added with custom CSS and media queries....More similar code may be required for other shop elements or pages, of course." This reduces the usefulness to me of a Themler template quite considerably, since I often use HikaShop. Is there a simpler fix, at least until Bootstrap 3 is fully supported?
