PHP 7.3
N..
N.. posted this 03 December 2019
Is themeler for wordpress run with php 7.3 and wp 5.3?!
15 Comments
Support Team posted this 05 December 2019
Yes, it works, but you need to use version 493 Beta.
Hello, Yes, it works, but you need to use version 493 Beta. Gina Themler Support
DaveOzric
DaveOzric posted this 06 December 2019
Hi Gina, will Joomla templates work with PHP 7.3? My hosting is switching early next year and I want to be ready.
Hi Gina, will Joomla templates work with PHP 7.3? My hosting is switching early next year and I want to be ready. Thank you
Bayern
Bayern posted this 08 December 2019
i want to know too
Joomla Templates with PHP 7.3?
i want to know too Joomla Templates with PHP 7.3?
Support Team posted this 10 December 2019
The newest Themler version at the moment - v.493 - supports the latest PHP, Joomla and Wordpress versions. If you would like to be sure, please try Themler themes (previously updated in Themler desktop and exported) on some localhost with PHP 7.3 and the needed CMS version.
Hello, The newest Themler version at the moment - v.493 - supports the latest PHP, Joomla and Wordpress versions. If you would like to be sure, please try Themler themes (previously updated in Themler desktop and exported) on some localhost with PHP 7.3 and the needed CMS version. Sincerely, Nettie
Bayern
Bayern posted this 10 December 2019
Hello Nettie,
Joomla 3.9.13 - PHP 7.3.11-nmm1 and Themler v.493 brings the following error message
" Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /www/htdocs/xxxxx/xxxxx/templates/demo_th/functions.php on line 201 "
Hello Nettie, Joomla 3.9.13 - PHP 7.3.11-nmm1 and Themler v.493 brings the following error message " Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /www/htdocs/xxxxx/xxxxx/templates/demo_th/functions.php on line 201 "
This is a warning, you may consider temporarily disabling or hiding it. The issue is fixed, and the update with this fix should be available in the near future.
Hello, This is a warning, you may consider temporarily disabling or hiding it. The issue is fixed, and the update with this fix should be available in the near future. Sincerely, Nettie
Bayern
can we get a note when this is done?
Thank you, can we get a note when this is done?
Please, update to v496 Beta.
Please, update to v496 Beta. Gina Themler Support
Bayern
DaveOzric
DaveOzric posted this 10 December 2019
I did test and saw no issues. I did not leave it set for long but the site loaded and I saw no issues.
Dave, thanks for your feedback! Let us know in case something is wrong during a longer period.
Dave, thanks for your feedback! Let us know in case something is wrong during a longer period. Sincerely, Nettie
lecoach37
lecoach37 posted this 27 January 2020
Bonjour,
dans le panneau d'administration wordpress de themler pas possible de faire la mise à jour wordpress :
n updated version of WordPress is available.
You cannot update because WordPress 5.3.2 requires PHP version 5.6.20 or higher. You are running version 5.4.42.
While your site is being updated, it will be in maintenance mode. As soon as your updates are complete, your site will return to normal.
Comment résoudre ce problème,
bien à vous
Philippe
Bonjour, dans le panneau d'administration wordpress de themler pas possible de faire la mise à jour wordpress : n updated version of WordPress is available. You cannot update because WordPress 5.3.2 requires PHP version 5.6.20 or higher. You are running version 5.4.42. While your site is being updated, it will be in maintenance mode. As soon as your updates are complete, your site will return to normal. Comment résoudre ce problème, bien à vous Philippe
Support Team posted this 27 January 2020
Are you trying to update Wordpress in the installation of Themler desktop? If so, it is not recommended. Please consider using the latest or another Wordpress version with Themler themes after export, on your website. Alternatively, you may install the theme in Wordpress on some localhost.
Hello, Are you trying to update Wordpress in the installation of Themler desktop? If so, it is not recommended. Please consider using the latest or another Wordpress version with Themler themes after export, on your website. Alternatively, you may install the theme in Wordpress on some localhost. Sincerely, Nettie
Web-Art Creative Design
Web-Art Creative Design posted this 02 September 2022
Support for php7.4 ends on November 28.
Until then, Themler under Wordpress, Joomla will support php8.1 without the bugs currently occurring.
2 months left. You're working on it.
Support for php7.4 ends on November 28. Until then, Themler under Wordpress, Joomla will support php8.1 without the bugs currently occurring. 2 months left. You're working on it.
mariah9xx
mariah9xx posted this 31 January 2024
Ensure that you are using the latest version of Themler. mapquest driving directions
Ensure that you are using the latest version of Themler. [mapquest driving directions][1] [1]: https://mapquestdrivingdirections.app
