How to display product price with discount in product details and products page?
webmaster@exnet.gr
webmaster@exnet.gr posted this 03 December 2019
I have the page shown here https://kosmovitrina.com/index.php/en/ designed by another developer and i have the problem to show discount price in the individual product page and in all products page as well.
A little help please
I have the page shown here https://kosmovitrina.com/index.php/en/ designed by another developer and i have the problem to show discount price in the individual product page and in all products page as well. A little help please
Support Team posted this 04 December 2019
Please try adding CMS Code control and then adding a code for price with discount, please refer to this article:
https://answers.themler.io/articles/67028/tips-and-tricks#t_price
Hello, Please try adding CMS Code control and then adding a code for price with discount, please refer to this article: https://answers.themler.io/articles/67028/tips-and-tricks#t_price Sincerely, Nettie
webmaster@exnet.gr
webmaster@exnet.gr posted this 04 December 2019
Thanks man but i have another question.
1) The sode could be implemented in the actual code as well or only in the editor code??
> Hello, > > Please try adding CMS Code control and then adding a code for price with discount, please refer to this article: > https://answers.themler.io/articles/67028/tips-and-tricks#t_price > > Sincerely, > Nettie Thanks man but i have another question. 1) The sode could be implemented in the actual code as well or only in the editor code??
webmaster@exnet.gr
It has a weird behaviour though and it happened before. When i try to add anything new, the hmenu duplicates itself. Can i give you the backend to see what is going on?
> Hello, > > Please try adding CMS Code control and then adding a code for price with discount, please refer to this article: > https://answers.themler.io/articles/67028/tips-and-tricks#t_price > > Sincerely, > Nettie It has a weird behaviour though and it happened before. When i try to add anything new, the hmenu duplicates itself. Can i give you the backend to see what is going on?
There is a special control in the Insert tab called CMS Code. It should be added to the Product Details template. Then open CMS Code tab, click Edit Code and insert the code wrapped in <?php ... ?>.
As for the other issue - please try to clear browser cache and AppCache:
https://answers.themler.io/articles/14063/how-to-clear-appcache
Hello, There is a special control in the Insert tab called CMS Code. It should be added to the Product Details template. Then open CMS Code tab, click Edit Code and insert the code wrapped in `<?php ... ?>`. As for the other issue - please try to clear browser cache and AppCache: https://answers.themler.io/articles/14063/how-to-clear-appcache Sincerely, Nettie
webmaster@exnet.gr
There is a special control in the Insert tab called CMS Code. It should be added to the Product Details template. Then open CMS Code tab, click Edit Code and insert the code wrapped in &lt;?php ...?&gt;.
The same happened again, i did what you suggested but the menu appears twice again and i have to recover a backup.
The row has 2 columns, i add a new column, i import the cms code block, when i click to the column to import the code tool the page reloads and the menu appears twice.
Pleaae help
> Hello, > > There is a special control in the Insert tab called CMS Code. It should be added to the Product Details template. Then open CMS Code tab, click Edit Code and insert the code wrapped in `&lt;?php ...?&gt;`. > > As for the other issue - please try to clear browser cache and AppCache: > https://answers.themler.io/articles/14063/how-to-clear-appcache > > Sincerely, > Nettie The same happened again, i did what you suggested but the menu appears twice again and i have to recover a backup. The row has 2 columns, i add a new column, i import the cms code block, when i click to the column to import the code tool the page reloads and the menu appears twice. Pleaae help
