efekt wejścia na stronę
stryjek-www
stryjek-www posted this 07 December 2019
witam na wielu stronach można zauważyć fajny efekt przejścia na stronę taki jak np tutaj http://raden.pl po wejściu na stronę strona powoli się pojawia czy w themelr można takie coś zrobić?
Support Team posted this 09 December 2019
Same thing can be achieved if you apply Animation effect (fade in) to the elements on your page (header, content, etc.). See example attached.
Hello, Same thing can be achieved if you apply Animation effect (fade in) to the elements on your page (header, content, etc.). See example attached. Gina Themler Support
stryjek-www
stryjek-www posted this 09 December 2019
do poszczególnych elementów wiem ze można uzyskać, ale tutaj cała strona przy wejściu na nią ma efekt wejścia nie tylko pojedyńcze kontenery
Support Team posted this 11 December 2019
Animation effect can be applied to only individual elements.
On the site example you have provided, it is applied to the header (banner), but since this banner takes almost entire screen height, the effect is as if the page in general fades in.
Animation effect can be applied to only individual elements. On the site example you have provided, it is applied to the header (banner), but since this banner takes almost entire screen height, the effect is as if the page in general fades in. Gina Themler Support
stryjek-www
stryjek-www posted this 11 December 2019
na tej stronie nie ma bannera a ten efekt pojawiania też jest. Więc to nie jest efekt dla poszczególnego kontenera https://www.raden.pl/pl/outsourcing.html
Support Team posted this 20 December 2019
Sorry, I wasn't able to open https://www.raden.pl/pl/outsourcing.html
But I opened https://www.raden.pl/outsourcing though it doesn't have fade-in effect.
Sorry, I wasn't able to open https://www.raden.pl/pl/outsourcing.html But I opened https://www.raden.pl/outsourcing though it doesn't have fade-in effect. Gina Themler Support
