Hello.
One of the recommendation from Google PageSpeed Insights is: "Ensure text remains visible during webfont load".
How can I do this with Themler? How to set font-display: swap to temporarily show a system font during page load?
Hello.
Im using wordpress, and Ive seen this also on pagespeed.
Please advice,
Hello.
Can you implement this in next minor update?
Also will be great to load font from local storage.
And replace Billion Fonts with Font Awesome 5.
This request will be added to the wish list of future possible implementations.
Meanwhile, it is possible to add font-display: swap; line to all @font-face lines in the css file. This would work for the fonts and browsers that support font-display.
You can try adding this line to Home -> Settings -> Additional CSS (though there is no guarantee it would definitely work):
body {
font-display: swap!important;}
@font-face {
font-display: swap;
To address Google PageSpeed Insights’ “Ensure text remains visible during webfont load” recommendation in Themler, use the CSS font-display: swap property in your @font-face declaration so a fallback system font is displayed while the webfont loads, then replaced automatically once the custom font is ready. If Themler does not provide a direct setting, add the CSS through the theme’s custom CSS area or stylesheet, for example @font-face { font-family: 'CustomFont'; src: url('font.woff2') format('woff2'); font-display: swap; }. This improves perceived loading performance and helps prevent invisible text during font loading. For testing text rendering, you can also use cursed text generator examples such as H̷e̷l̷l̷o̷ or C̴u̴r̴s̴e̴d̴ ̴T̴e̴x̴t̴ to check how unusual Unicode characters behave with your selected fonts.
Great tip on using font-display: swap to keep text visible while fonts load—really helps with PageSpeed. By the way, if you’re planning ahead, you can check what date it’ll be 20 weeks from now using that free weeks calculator.
Great tip on using font-display: swap to keep text visible while fonts load—really helps with PageSpeed. By the way, if you’re planning ahead, you can check what date it’ll be [20 weeks from now][1] using that free weeks calculator. [1]: https://weeksfromnow.org/To address Google PageSpeed Insights’ “Ensure text remains visible during webfont load” recommendation in Themler, use the CSS font-display: swap property in your @font-face declaration so a fallback system font is displayed while the webfont loads, then replaced automatically once the custom font is ready. If Themler does not provide a direct setting, add the CSS through the theme’s custom CSS area or stylesheet, Try different activities and pay attention to what your individual dog enjoys most. A varied routine can help keep your learn more about Mini Aussies physically active, mentally engaged, and happy.
To address Google PageSpeed Insights’ “Ensure text remains visible during webfont load” recommendation in Themler, use the CSS font-display: swap property in your @font-face declaration so a fallback system font is displayed while the webfont loads, then replaced automatically once the custom font is ready. If Themler does not provide a direct setting, add the CSS through the theme’s custom CSS area or stylesheet, Try different activities and pay attention to what your individual dog enjoys most. A varied routine can help keep your [learn more about Mini Aussies][1] physically active, mentally engaged, and happy. [1]: https://miniaussieshepherd.com/
