virtuemart Loading... = /.jpg when no image in product details
philippe.t
philippe.t posted this 13 December 2019
In product Details page, we have a message : Loading... when the product have 'no image'
Why the 'no image' image configured in configuration/templates/Media Files Settings /'no image' image selected
do not appear in this page product details ?
Philippe
Hello, In product Details page, we have a message : Loading... when the product have 'no image' Why the 'no image' image configured in configuration/templates/Media Files Settings /'no image' image selected do not appear in this page product details ? Regards Philippe
Support Team posted this 30 December 2019
Hello Philippe,
We are terribly sorry for delay in response. Is the issue still actual? If so, does it happen with Themler theme only or also with a default Joomla theme?
Hello Philippe, We are terribly sorry for delay in response. Is the issue still actual? If so, does it happen with Themler theme only or also with a default Joomla theme? Sincerely, Nettie
philippe.t
philippe.t posted this 31 December 2019
hello Nettie,
I test with template vmbeez3 , it is ok we have the "no image". with template protostar, same, it is ok
with template beez3, again, it is ok
BUT, with themler it is not ok we have "loading..." message in productdetails page.
And it is strange , i switch many time to different templates and switch now in themler template it work !?
Philippe
hello Nettie, I test with template vmbeez3 , it is ok we have the "no image". with template protostar, same, it is ok with template beez3, again, it is ok BUT, with themler it is not ok we have "loading..." message in productdetails page. And it is strange , i switch many time to different templates and switch now in themler template it work !? Regards Philippe
Support Team posted this 03 January 2020
Philippe,
So it works now?
Are you using Themler v496?
Philippe, So it works now? Are you using Themler v496? Gina Themler Support
philippe.t
philippe.t posted this 03 January 2020
no, do not work. i'm using v496
we have the same issue, message : "loading..." and, the image "noimage.jpg" not appear
What's the problem ?
regards
philippe
Hello, no, do not work. i'm using v496 we have the same issue, message : "loading..." and, the image "noimage.jpg" not appear What's the problem ? regards philippe
philippe.t
hello,
but i am obliged to correct the problem with insert cms code and add virtuemart file default_images.php in /templates/themler/html/com_virtuemart/productdetails/default_images.php
the cms code is:
<div class="vm-product-media-container">
<?php
echo $this->loadTemplate('images');
&lt;/div>
and delete the product image control of themler
and now it is work with this trick.
Can you correct the product image control in the next version of themler, please ?
Philippe
hello, but i am obliged to correct the problem with insert cms code and add virtuemart file default_images.php in /templates/themler/html/com_virtuemart/productdetails/default_images.php the cms code is: &lt;div class="vm-product-media-container"> &lt;?php echo $this->loadTemplate('images'); ?&gt; &lt;/div> and delete the product image control of themler and now it is work with this trick. Can you correct the product image control in the next version of themler, please ? Regards Philippe
