Themler core not appearing in dashboard of wordpress
jansen.marcus
jansen.marcus posted this 13 December 2019
I have this problem:
For a new wordpress project I would like to use Themler to design the theme.
I've installed and activated the themler core plugin (version 0.2.22) but Themler doesn't appear in the wordpress dashboard.
How can I start developing a theme if I can't reach themler from within the dashboard?
I've tried importing a new theme built with Themler-app and exported as zip with Include themler for customizing this theme. I've imported this theme in wordpress but Themler doesn't show up, even after activating themler core distributed with the theme as a zip file.
I'm using wordpress 5.2.5.
Thanks for some advise.
Mark
I have this problem: For a new wordpress project I would like to use Themler to design the theme. I've installed and activated the **themler core plugin (version 0.2.22)** but Themler **doesn't appear in the wordpress dashboard**. How can I start developing a theme if I can't reach themler from within the dashboard? I've tried importing a new **theme built with Themler-app** and exported as zip **with Include themler for customizing this theme**. I've imported this theme in wordpress but Themler doesn't show up, even after activating themler core distributed with the theme as a zip file. I'm using wordpress 5.2.5. Thanks for some advise. Regards, Mark
6 Comments
jansen.marcus
jansen.marcus posted this 14 December 2019
This is a screenshot with 2 dashboards (Wordpress). The left one has Themler in the dashboard, the right one is missing Themler.
Although I've installed the blank themler theme, and activated the theme.
Themler-core plugin is activated also.
I followed the instructions on https://themler.io/Download/WordPress
Any idea?
Mark
This is a screenshot with 2 dashboards (Wordpress). The left one has Themler in the dashboard, the right one is missing Themler. Although I've installed the blank themler theme, and activated the theme. Themler-core plugin is activated also. I followed the instructions on https://themler.io/Download/WordPress Any idea? Thanks, Mark
Support Team posted this 16 December 2019
Hello Mark,
Could you please try the following:
1) disable all 3d party plugins and see if it helps
2) check this article https://answers.themler.io/articles/65515/themler-themes-issues-wordpress-woocommerce
Themler support
Hello Mark, Could you please try the following: 1) disable all 3d party plugins and see if it helps 2) check this article https://answers.themler.io/articles/65515/themler-themes-issues-wordpress-woocommerce Gina Themler support
jansen.marcus
jansen.marcus posted this 16 December 2019
Ok,
I've modified define('DISALLOW_FILE_EDIT', true) to define('DISALLOW_FILE_EDIT', false);
This solved my issue.
Thanks a lot,
Mark
Ok, I've modified **define('DISALLOW_FILE_EDIT', true)** to **define('DISALLOW_FILE_EDIT', false)**; This solved my issue. Thanks a lot, Mark
alexarafatonline
alexarafatonline posted this 02 November 2025
I’ve encountered a similar issue before with Themler not showing up in the WordPress dashboard. It sounds like the plugin might not be fully integrated or there might be a compatibility issue with WordPress 5.2.5. Here are a few things you can try:
Check Plugin Activation: Double-check that Themler Core Plugin is activated under Plugins > Installed Plugins.
Clear Caches: Sometimes caching plugins or browser cache might be causing this issue. Try clearing both and refreshing the page.
Update WordPress and Plugins: If possible, consider updating to a newer version of WordPress (if it's compatible with your setup). This could resolve conflicts.
Reinstall Themler Plugin: You could try deactivating, deleting, and reinstalling Themler Core plugin to ensure a clean installation.
As for the weight loss journey, I’ve recently been using Saxenda Flextouch 6mg/ml Pre-filled Pen. It's helped me reduce cravings and feel fuller, making it easier to stick to healthier choices while working on my website and projects. Just be sure to consult with a doctor, as there are some potential side effects. It’s been a game-changer for my overall health and productivity!
I’ve encountered a similar issue before with Themler not showing up in the WordPress dashboard. It sounds like the plugin might not be fully integrated or there might be a compatibility issue with WordPress 5.2.5. Here are a few things you can try: Check Plugin Activation: Double-check that Themler Core Plugin is activated under Plugins > Installed Plugins. Clear Caches: Sometimes caching plugins or browser cache might be causing this issue. Try clearing both and refreshing the page. Update WordPress and Plugins: If possible, consider updating to a newer version of WordPress (if it's compatible with your setup). This could resolve conflicts. Reinstall Themler Plugin: You could try deactivating, deleting, and reinstalling Themler Core plugin to ensure a clean installation. As for the weight loss journey, I’ve recently been using [Saxenda Flextouch 6mg/ml Pre-filled Pen][1]. It's helped me reduce cravings and feel fuller, making it easier to stick to healthier choices while working on my website and projects. Just be sure to consult with a doctor, as there are some potential side effects. It’s been a game-changer for my overall health and productivity! [1]: https://www.doctoroncall.com/sg/pharmacy/prescription-medicine/saxenda-flextouch-liraglutide-6mg-ml-3-pens
joshbolstad360
joshbolstad360 posted this 10 December 2025
I’ve seen a lot of talk about casino bonuses lately, so I want to ask the community something. When logging in through ufa4k เข้าสู่ระบบ, do you feel the bonuses and promotions actually add value, or are they just the typical offers every platform throws around? I’ve joined a few sites where the bonuses look appealing but end up being impossible to use because of crazy wagering requirements.
With ufa4k เข้าสู่ระบบ, the promotions seem more realistic, but I haven’t tested them deeply enough. Do the wagering conditions feel manageable? Can you actually withdraw winnings from bonus play?
Another thing I’m curious about is loyalty programs. Does ufa4k treat regular players well? Some casinos offer better perks the more you play, while others barely reward loyal users. If you’ve been using ufa4k เข้าสู่ระบบ for months, have you received any exclusive offers or boosts?
I’ve seen a lot of talk about casino bonuses lately, so I want to ask the community something. When logging in through ufa4k เข้าสู่ระบบ, do you feel the bonuses and promotions actually add value, or are they just the typical offers every platform throws around? I’ve joined a few sites where the bonuses look appealing but end up being impossible to use because of crazy wagering requirements. With [ufa4k เข้าสู่ระบบ][1], the promotions seem more realistic, but I haven’t tested them deeply enough. Do the wagering conditions feel manageable? Can you actually withdraw winnings from bonus play? Another thing I’m curious about is loyalty programs. Does ufa4k treat regular players well? Some casinos offer better perks the more you play, while others barely reward loyal users. If you’ve been using ufa4k เข้าสู่ระบบ for months, have you received any exclusive offers or boosts? [1]: https://ufa4k.win
joeytribuani0
joeytribuani0 posted this 20 January 2026
A competitive street basketball game, Basketball Stars 2026 offers participants all over the world quick, skill-based action. The game is appropriate for both casual players and those who appreciate competitive sports because it is made for short matches with intense gameplay.
A competitive street basketball game, [Basketball Stars 2026][1] offers participants all over the world quick, skill-based action. The game is appropriate for both casual players and those who appreciate competitive sports because it is made for short matches with intense gameplay. [1]: https://basketballstars2026.io
