Thanks for you responses.
Ok I've been through all the suggestions and everything appears ok.
Asking about the Version number has given me a clue to what is happening though what I have now discovered is that if I create a brand new template all seems ok and I can save and use them without problem and all are showing as v496.
However if I try and use a template that I was working on from 7 days ago, I get a version number of V367 and I can no longer save. Interestingly any new template I try to create after that also becomes a V367 and doesn't work.
I can't create a working blank template again until I open a v496 first,
Hope this is making sense to you !
Anything that shows as v367 content doesn't offer up an upgrade option, so I can't do anything with it.
I have kept all my templates updated as they become available so no idea why they seem so massively out of date.
Any more thoughts?
Any more thoughts?
