Google pagespeed insights
Seppe
Seppe posted this 03 January 2020
Good morning
I am testing my websites, to see what kind of resultes I get since Google wants us do more efforts regarding pagespeed.
All my websites are created in Joomla, with a Themler-theme.
For the desktop-test, almost every site is over 90 (green)
For the mobile-test, it's more or less 80 (orange)
2 options that are always comming back:
* minimize javascript
* remove unused CSS
Any suggestions to fix this?
Greetings
Good morning I am testing my websites, to see what kind of resultes I get since Google wants us do more efforts regarding pagespeed. All my websites are created in Joomla, with a Themler-theme. For the desktop-test, almost every site is over 90 (green) For the mobile-test, it's more or less 80 (orange) 2 options that are always comming back: * minimize javascript * remove unused CSS Any suggestions to fix this? Greetings
49 Comments
distant.marmot.dfkr
distant.marmot.dfkr posted this 06 November 2024
To improve your site speed, consider optimizing images and using caching. You can also minify JavaScript and CSS using tools like Autoptimize. If you need a break from optimization, play Snow Rider 3D for a fun experience! Good luck with your website!
To improve your site speed, consider optimizing images and using caching. You can also minify JavaScript and CSS using tools like Autoptimize. If you need a break from optimization, play [Snow Rider 3D][1] for a fun experience! Good luck with your website! [1]: https://snowrider-3d.io/
s71673856
s71673856 posted this 06 November 2024
The app store also gives you the different types of modes available and shows you each of their success rates with different users based on the votes. Furthermore, it gives you their recommended version of mod apart from the others that are sure to work like a charm.https://happymod.ph/
The app store also gives you the different types of modes available and shows you each of their success rates with different users based on the votes. Furthermore, it gives you their recommended version of mod apart from the others that are sure to work like a charm.[https://happymod.ph/][1] [1]: https://happymod.ph/
pakhostweb
pakhostweb posted this 04 November 2024
Honista apk for mod is a modded client of Instagram, hence not available on the Play Store. But with this APK file, you can easily install it on your phone. Here are the exact steps to guide you through the process.
[Honista apk for mod][1] is a modded client of Instagram, hence not available on the Play Store. But with this APK file, you can easily install it on your phone. Here are the exact steps to guide you through the process. [1]: https://honistaapk.net/
dooflixapps480
dooflixapps480 posted this 08 October 2024
Hi [Recipient's Name],
Thank you for reaching out regarding your website’s performance. It’s great to hear that your desktop scores are consistently high. For improving mobile scores, especially in the areas of JavaScript and CSS, consider the following strategies:
  1. Minimize JavaScript:
    • Defer or Async Loading: Ensure non-essential JavaScript is loaded asynchronously or deferred so it doesn’t block rendering.
    • Code Splitting: Break down large scripts into smaller, manageable pieces that load only when needed.
    • Remove Redundant Code: Audit your scripts to identify and eliminate any unused or redundant code.
  2. Remove Unused CSS:
    • CSS Purging: Use tools like PurifyCSS or UnCSS to analyze your CSS files and remove styles not used on the current pages.
    • Critical CSS: Extract and inline critical CSS needed for above-the-fold content to improve initial page rendering.
    • Modular CSS: Consider adopting modular CSS practices to ensure only relevant styles are applied.
Implementing these optimizations can significantly enhance your mobile performance scores. If you have any further questions or need additional assistance, feel free to ask. and [download optifine][1]
Best regards,
[1]: https://optifines.com/
[2]: https://sportzfytvapk.com.co/
Best regards,
To improve the PageSpeed Insights score for your sites built with Joomla and using the Themler theme, I have a few suggestions:
1. Minify JavaScript: Consider optimizing and minimizing the amount of JavaScript loaded on the page. This can include bundling JS files, removing unused code, and using deferred JavaScript loading.
2. Remove unused CSS: Check and remove unused CSS rules on your pages. This can help reduce the overall size of the CSS file and improve page load times.
3. Use compression and caching: Enable HTTP compression and use cache on your server to reduce the size of transferred files and increase page load speed.
4. Image optimization: Test and apply image optimization strategies such as compression, proper image formatting, and using images sized appropriately for the display size.
5. Use a CDN: Consider using a content delivery network (CDN) to serve static files like images, CSS, and JavaScript from servers closer to customers.
6. Take the [rice purity test][1] for relax time.
[1]: https://ricepurity-test.io/
> Hi [Recipient's Name], > > Thank you for reaching out regarding your website’s performance. It’s great to hear that your desktop scores are consistently high. For improving mobile scores, especially in the areas of JavaScript and CSS, consider the following strategies: > > 1. **Minimize JavaScript**: > - **Defer or Async Loading**: Ensure non-essential JavaScript is loaded asynchronously or deferred so it doesn’t block rendering. > - **Code Splitting**: Break down large scripts into smaller, manageable pieces that load only when needed. > - **Remove Redundant Code**: Audit your scripts to identify and eliminate any unused or redundant code. > > 2. **Remove Unused CSS**: > - **CSS Purging**: Use tools like PurifyCSS or UnCSS to analyze your CSS files and remove styles not used on the current pages. > - **Critical CSS**: Extract and inline critical CSS needed for above-the-fold content to improve initial page rendering. > - **Modular CSS**: Consider adopting modular CSS practices to ensure only relevant styles are applied. > > Implementing these optimizations can significantly enhance your mobile performance scores. If you have any further questions or need additional assistance, feel free to ask. and [download optifine][1] > > Best regards, > > > [1]: https://optifines.com/ > [2]: https://sportzfytvapk.com.co/ > Hi [Recipient's Name], > > Thank you for reaching out regarding your website’s performance. It’s great to hear that your desktop scores are consistently high. For improving mobile scores, especially in the areas of JavaScript and CSS, consider the following strategies: > > 1. **Minimize JavaScript**: > - **Defer or Async Loading**: Ensure non-essential JavaScript is loaded asynchronously or deferred so it doesn’t block rendering. > - **Code Splitting**: Break down large scripts into smaller, manageable pieces that load only when needed. > - **Remove Redundant Code**: Audit your scripts to identify and eliminate any unused or redundant code. > > 2. **Remove Unused CSS**: > - **CSS Purging**: Use tools like PurifyCSS or UnCSS to analyze your CSS files and remove styles not used on the current pages. > - **Critical CSS**: Extract and inline critical CSS needed for above-the-fold content to improve initial page rendering. > - **Modular CSS**: Consider adopting modular CSS practices to ensure only relevant styles are applied. > > Implementing these optimizations can significantly enhance your mobile performance scores. If you have any further questions or need additional assistance, feel free to ask. and [download optifine][1] > > Best regards, > > > [1]: https://optifines.com/ > To improve the PageSpeed Insights score for your sites built with Joomla and using the Themler theme, I have a few suggestions: > 1. Minify JavaScript: Consider optimizing and minimizing the amount of JavaScript loaded on the page. This can include bundling JS files, removing unused code, and using deferred JavaScript loading. > 2. Remove unused CSS: Check and remove unused CSS rules on your pages. This can help reduce the overall size of the CSS file and improve page load times. > 3. Use compression and caching: Enable HTTP compression and use cache on your server to reduce the size of transferred files and increase page load speed. > 4. Image optimization: Test and apply image optimization strategies such as compression, proper image formatting, and using images sized appropriately for the display size. > 5. Use a CDN: Consider using a content delivery network (CDN) to serve static files like images, CSS, and JavaScript from servers closer to customers. > 6. Take the [rice purity test][1] for relax time. > > > [1]: https://ricepurity-test.io/
dooflixapps480
dooflixapps480 posted this 25 August 2024
Implementing these optimizations can significantly enhance your mobile performance scores. If you have any further questions or need additional assistance, feel free to ask. and download optifine
Best regards,
1: https://optifines.com/
Snaptube, a quick and easy to operate video downloading platform, can be downloaded and installed from this site with installation guide.
> Hi [Recipient's Name], > > Thank you for reaching out regarding your website’s performance. It’s great to hear that your desktop scores are consistently high. For improving mobile scores, especially in the areas of JavaScript and CSS, consider the following strategies: > > 1. **Minimize JavaScript**: > - **Defer or Async Loading**: Ensure non-essential JavaScript is loaded asynchronously or deferred so it doesn’t block rendering. > - **Code Splitting**: Break down large scripts into smaller, manageable pieces that load only when needed. > - **Remove Redundant Code**: Audit your scripts to identify and eliminate any unused or redundant code. > > 2. **Remove Unused CSS**: > - **CSS Purging**: Use tools like PurifyCSS or UnCSS to analyze your CSS files and remove styles not used on the current pages. > - **Critical CSS**: Extract and inline critical CSS needed for above-the-fold content to improve initial page rendering. > - **Modular CSS**: Consider adopting modular CSS practices to ensure only relevant styles are applied. > > Implementing these optimizations can significantly enhance your mobile performance scores. If you have any further questions or need additional assistance, feel free to ask. and [download optifine][1] > > Best regards, > > > [1]: https://optifines.com/ [Snaptube][1], a quick and easy to operate video downloading platform, can be downloaded and installed from this site with installation guide. [1]: https://snaptubehd.net/
optifinesmail
optifinesmail posted this 12 August 2024
Best regards,
Hi [Recipient's Name], Thank you for reaching out regarding your website’s performance. It’s great to hear that your desktop scores are consistently high. For improving mobile scores, especially in the areas of JavaScript and CSS, consider the following strategies: 1. **Minimize JavaScript**: - **Defer or Async Loading**: Ensure non-essential JavaScript is loaded asynchronously or deferred so it doesn’t block rendering. - **Code Splitting**: Break down large scripts into smaller, manageable pieces that load only when needed. - **Remove Redundant Code**: Audit your scripts to identify and eliminate any unused or redundant code. 2. **Remove Unused CSS**: - **CSS Purging**: Use tools like PurifyCSS or UnCSS to analyze your CSS files and remove styles not used on the current pages. - **Critical CSS**: Extract and inline critical CSS needed for above-the-fold content to improve initial page rendering. - **Modular CSS**: Consider adopting modular CSS practices to ensure only relevant styles are applied. Implementing these optimizations can significantly enhance your mobile performance scores. If you have any further questions or need additional assistance, feel free to ask. and [download optifine][1] Best regards, [1]: https://optifines.com/
felixandreaim
felixandreaim posted this 09 May 2024
6. Take the rice purity test for relax time.
To improve the PageSpeed Insights score for your sites built with Joomla and using the Themler theme, I have a few suggestions: 1. Minify JavaScript: Consider optimizing and minimizing the amount of JavaScript loaded on the page. This can include bundling JS files, removing unused code, and using deferred JavaScript loading. 2. Remove unused CSS: Check and remove unused CSS rules on your pages. This can help reduce the overall size of the CSS file and improve page load times. 3. Use compression and caching: Enable HTTP compression and use cache on your server to reduce the size of transferred files and increase page load speed. 4. Image optimization: Test and apply image optimization strategies such as compression, proper image formatting, and using images sized appropriately for the display size. 5. Use a CDN: Consider using a content delivery network (CDN) to serve static files like images, CSS, and JavaScript from servers closer to customers. 6. Take the [rice purity test][1] for relax time. [1]: https://ricepurity-test.io/
Support Team posted this 05 January 2020
1) 3rd party plugins (like suggested above) may help.
2) as for Themler itself, the less animation, transition or custom settings that are different for mobile view than those for desktop view you have, the less CSS is generated as the result.
We don't recommend editing JS or CSS files manually after the template is exported.
Hello, 1) 3rd party plugins (like suggested above) may help. 2) as for Themler itself, the less animation, transition or custom settings that are different for mobile view than those for desktop view you have, the less CSS is generated as the result. We don't recommend editing JS or CSS files manually after the template is exported. Gina Themler Support
Vitaliy WD
Vitaliy WD posted this 03 January 2020
Hi.
If you are working with Joomla you can try to use JCH Optimize + Jot Cache to optimize code and minimize javascript.
Hi. If you are working with Joomla you can try to use JCH Optimize + Jot Cache to optimize code and minimize javascript.
