can't open themler in latest Joomla version
GT-WebDesign
GT-WebDesign posted this 03 January 2020
Can't open a template in new migrated website and getting the following reply:
{"result":"done","version":"496"}[PHP_ERROR]{"message":"\n\nOS: Linux gtwebdesign.protagonist.nl 3.10.0-1062.4.1.el7.x86_64 #1 SMP Fri Oct 18 17:15:30 UTC 2019 x86_64\nPHP: 7.4.1\nerror handler: Trying to access array offset on value of type null\nArray\n(\n [errorText] => \n [error] => \n)\n Callstack: \n -> shutdownHandler()\n\n\n","type":"E_NOTICE","file":"/var/www/vhosts/degezondekeus.nl/httpdocs/templates/debby01/app/classes/Helper.php","line":185}[PHP_ERROR]
Can you please help with this issue?
Regards Ger Toes
Can't open a template in new migrated website and getting the following reply: {"result":"done","version":"496"}[PHP_ERROR]{"message":"\n\nOS: Linux gtwebdesign.protagonist.nl 3.10.0-1062.4.1.el7.x86_64 #1 SMP Fri Oct 18 17:15:30 UTC 2019 x86_64\nPHP: 7.4.1\nerror handler: Trying to access array offset on value of type null\nArray\n(\n [errorText] => \n [error] => \n)\n Callstack: \n -> shutdownHandler()\n\n\n","type":"E_NOTICE","file":"\/var\/www\/vhosts\/degezondekeus.nl\/httpdocs\/templates\/debby01\/app\/classes\/Helper.php","line":185}[PHP_ERROR] Can you please help with this issue? Regards Ger Toes
GT-WebDesign
I've downgraded php version from 7.4.1 to 7.3.13 and now it works.
Is the latest Themler version not compatible with php7.4.1?
I've downgraded php version from 7.4.1 to 7.3.13 and now it works. Is the latest Themler version not compatible with php7.4.1?
Support Team posted this 04 January 2020
We are working at the issue with Joomla and PHP 7.4, the fix will be available soon.
Hello, We are working at the issue with Joomla and PHP 7.4, the fix will be available soon. Sincerely, Nettie
dani.schneider
dani.schneider posted this 21 January 2020
Hi Nettie
I have the same issue - is a fix already available?
Best regards
Daniel
Hi Nettie I have the same issue - is a fix already available? Best regards Daniel
Support Team posted this 21 January 2020
Daniel,
Please, update to v499.
Daniel, Please, update to v499. Gina Themler Support
