Every time I want to login, it loops in a new login. Very annoying!
Every time I want to login, it loops in a new login. Very annoying!Hello Tim,
1) navigate to:
chrome://appcache-internals
2) navigate to:
1) close Themler
4) start Themler again
Am facing this. I have tried all of the above. Non works.
Am facing this. I have tried all of the above. Non works.Hello,
Do you use Themler for Mac?
Looks like the issue appeared after the security updates included into the latest Mac system updates. The issue with Themler for Mac is forwarded to our developers. Meanwhile please try to install the theme on some localhost or hosted website.
you may copy the theme manually from the folder with themes. Please click Go >> Go to Folder >> type ~/Library and ENTER >> Themler >> hd_data >> cms >> choose CMS and access the themes folder, copy the theme, zip it and install on your hosted website or localhost.
Additionally, could you please try the following:
1. Disable the option "Prevent cross-data tracking" in Safari browser:
