i am refering to this post : http://answers.themler.io/articles/21538/bullet-list-layout
If i dot that for my bullet list alignement, it dosent work the same in Fierfox and Chrome for example.
So what is the good solution ?
I have find a real solution.
I have searched in the template.css and modified :
list-style-position: inside; => list-style-position: outside;
And commented out :
.bd-tagstyles:not(.bd-custom-bulletlist):not(.shape-only) ul:not([class*="menu"]),
.bd-bulletlist {
/padding-left: 10px;/
Now the text is correctly aligned for the second line in Firefox and Chrome.
And thanks to manu93fr in the french Joomla forum : https://forum.joomla.fr/forum/joomla-3-x/extensions-tierces/223337-alignement-du-texte-dans-les-listes-%C3%A3%C2%A0-puces-avec-jce
I have find a real solution. I have searched in the template.css and modified : list-style-position: inside; => list-style-position: outside; And commented out : .bd-tagstyles:not(.bd-custom-bulletlist):not(.shape-only) ul:not([class*="menu"]), .bd-bulletlist { /*padding-left: 10px;*/ } Now the text is correctly aligned for the second line in Firefox and Chrome. And thanks to manu93fr in the french Joomla forum : https://forum.joomla.fr/forum/joomla-3-x/extensions-tierces/223337-alignement-du-texte-dans-les-listes-%C3%A3%C2%A0-puces-avec-jceLast edited 01 February 2020 by frederic11
Hello Frederic,
Sorry for the delay in reply and thank you for updating this case.
You can try adding same custom CSS to Home -> Settings -> Additional CSS with !important to avoid editing files after the export, for example:
.bd-bulletlist {
padding-left: 0!important;
