posted this
17 February 2020
If you are using a CMS (Wordpress, Joomla, etc), then you can insert your php code to Home -> settings -> CMS Code.
You can also try using shortcodes by adding them in Themler via HTML control (via Insert -> HTML) but I can't tell if it will definitely render correctly after the export. You may need to add it after the export via CMS admin panel.
