You would need to add two containers first. On on the left and other on the right. Then put 4 cells to the left container and two one cell to the right (or just keep it empty). Then you would need to adjust the margins and padding so they all look as a single structure.
Hello Gina,
Thanks a lot for the reply. Diving deep into this, I would like to understand the usage, tips and tricks recommended for the container.
I have been using the columns layout in several of my sections on this template, but without containers. Is that a good or bad practice?
It´s is important ot use containers all the time? are scenarios where containers are recommended?
Do you have a page explaing the concept and usage of containers in Themler?
Best,
> Hello,
> Gina
> Themler Support
Hello Gina,
Best,
