Broken login
miroslav.cihlo
miroslav.cihlo posted this 26 February 2020
Hi all,
I need your immediate help. A have a WP multisite instalation and several Themler themes made. Suddenly by work I have been kicked out from administration and now I cannot enter into administration. After login I get a message Error! Not Allowed to Access this Page. In debug mode I get message on domain which is connected with hosting:
message
This message is on domains parked on my hosting.
enter image description here
I am absolutely confused. I don't know how to solve it. Probably it is connected to themes...
When I switched off all the plugins I could access to administration then I updated Themler in the theme on main domain (karosa.eu) and the problem moved to another domain. On the main domain there is message 2 on the another one message 1.
Pluggable.php, CoreUpdateHelper.php and export.php files are also attached as TXT files.
http://czech-neurosurgery.cz/wp-content/uploads/2020/02/pluggable.txt
http://czech-neurosurgery.cz/wp-content/uploads/2020/02/CoreUpdateHelper.txt
http://czech-neurosurgery.cz/wp-content/uploads/2020/02/export.txt
Hi all, I need your immediate help. A have a WP multisite instalation and several Themler themes made. Suddenly by work I have been kicked out from administration and now I cannot enter into administration. After login I get a message Error! Not Allowed to Access this Page. In debug mode I get message on domain which is connected with hosting: ![message][1] This message is on domains parked on my hosting. ![enter image description here][2] I am absolutely confused. I don't know how to solve it. Probably it is connected to themes... When I switched off all the plugins I could access to administration then I updated Themler in the theme on main domain (karosa.eu) and the problem moved to another domain. On the main domain there is message 2 on the another one message 1. Pluggable.php, CoreUpdateHelper.php and export.php files are also attached as TXT files. http://czech-neurosurgery.cz/wp-content/uploads/2020/02/pluggable.txt http://czech-neurosurgery.cz/wp-content/uploads/2020/02/CoreUpdateHelper.txt http://czech-neurosurgery.cz/wp-content/uploads/2020/02/export.txt [1]: http://czech-neurosurgery.cz/wp-content/uploads/2020/02/problem.jpg [2]: http://czech-neurosurgery.cz/wp-content/uploads/2020/02/problem2.jpg
miroslav.cihlo
Is Solution
Probably conflict between Themler ver 484 and new WP. After update to ver. 499 without any problem
Support Team posted this 27 February 2020
Please try to follow this article:
https://answers.themler.io/questions/193781/themler-v493-beta-compatibility-with-wordpress-5-3
Let us know if the issue is still present.
Hello, Please try to follow this article: https://answers.themler.io/questions/193781/themler-v493-beta-compatibility-with-wordpress-5-3 Let us know if the issue is still present. Sincerely, Nettie
