Cant login and save project
timersir
timersir posted this 11 March 2020
Today I can not login and save temlplate with correct login and password, when I click on the sing in button it make clear the form and go to the top of login page... ?
11 Comments
timersir
Screen in attachments
ddobi
ddobi posted this 11 March 2020
Connection also impossible with themler while the account is valid. Unable to save project. same screenshot. urgent
themler44
themler44 posted this 11 March 2020
the same problem
the same problem :(
HUSAR Uslugi Informatyczne Karol Czerminski
for me the same problem... please help - urgent !!
Support Team posted this 11 March 2020
1) navigate to:
chrome://appcache-internals
2) navigate to:
1) close Themler
4) start Themler again
Themler support
Hello, If you are using Google Chrome, try this: 1) navigate to: chrome://appcache-internals find your website and click on 'Remove Item' 2) navigate to: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. Some users have reported that complete re-install of Google Chrome solved the issue. If you are using the Desktop version, then: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again Gina Themler support
pvivient
pvivient posted this 27 September 2021
impossible to connect a wordpress project into themler .. email address incongnize ???
I already change the themler directory ..
thank for help
impossible to connect a wordpress project into themler .. email address incongnize ??? I already change the themler directory .. thank for help
Support Team posted this 27 September 2021
Did you please try to follow the steps 1-3 from the post above?
Hello, Did you please try to follow the steps 1-3 from the post above? Sincerely, Nettie
pvivient
pvivient posted this 28 September 2021
Hello I done again today ... But no result the system turn ... screen empty nothing is displayed
Support Team posted this 28 September 2021
Do you use Themler for Wordpress on your website? Could you please try to import the theme in Themler desktop, update it to the latest Themler version, then export under a different name andinstall on your website?
Hello, Do you use Themler for Wordpress on your website? Could you please try to import the theme in Themler desktop, update it to the latest Themler version, then export under a different name andinstall on your website? Sincerely, Nettie
pvivient
no I'm tried to use Themler WIndows > wpress ...
Hi no I'm tried to use Themler WIndows > wpress ...
Could you please try to rename the following folder into wordpress-old and try to run Themler once again:
C:\ProgramData\Themler\hd_data\themler_XXXXXXXXXX\wordpress\
This should help.
Hi, Could you please try to rename the following folder into **wordpress-old** and try to run Themler once again: C:\ProgramData\Themler\hd_data\themler_XXXXXXXXXX\wordpress\ This should help. Sincerely, Nettie
