I edit my template in Joomla, so far so good, but when i try to save i get a blinking screen and nothing happens. Even if I try to log out from Themler and login again I cannot save.
Help!
Schermafbeelding-2020-03-14-om-12.28.43.png!
Help!
The same problem during save wordpress template :(
The same problem during save wordpress template :(I am having the same issue trying to save my wordpress template
I am having the same issue trying to save my wordpress templateSame, made a great page, put a lot of time into it and cant save....
Same, made a great page, put a lot of time into it and cant save....Found a solution for my problem. Normally I am using Chrome as browser, when i changed to Safari I was able to save my template!
Found a solution for my problem. Normally I am using Chrome as browser, when i changed to Safari I was able to save my template!Please Themler support reply something, we have working stopped for this error, the program does not allow to do anything
https://www.loom.com/share/f316009bf2eb4dbbb92509d64c65b56d
Same issue here as well. My Themler was out of date so I paid to update it presuming it was in need of it to connect to the system but still getting the blinking login screen...
Same issue here as well. My Themler was out of date so I paid to update it presuming it was in need of it to connect to the system but still getting the blinking login screen...I edit my template in Joomla, so far so good, but when i try to save i get a blinking screen and nothing happens. Even if I try to log out from Themler and login again I cannot save.
Help!
Schermafbeelding-2020-03-14-om-12.28.43.png!Found a solution for my problem. Normally I am using Chrome as browser, when i changed to Safari I was able to save my template!
Unfortunately in Safari I am getting very often a spinning wheel and cannot do anything else than close the browser and loose all my work! How are you going to solve these problems?
> I edit my template in Joomla, so far so good, but when i try to save i get a blinking screen and nothing happens. Even if I try to log out from Themler and login again I cannot save. > Help! > Schermafbeelding-2020-03-14-om-12.28.43.png! > Found a solution for my problem. Normally I am using Chrome as browser, when i changed to Safari I was able to save my template! Unfortunately in Safari I am getting very often a spinning wheel and cannot do anything else than close the browser and loose all my work! How are you going to solve these problems?Hallo Team,
Ich kann weder Speichern noch Änderungen Veröffentlichen.
es erscheint immer ein Login Loop!
Ich fordere schnelles Bugfix!
Exactly Same issues guys for 2 days now. I have done a lot of checks but it is not solving. Need URGENT help.
> Please Themler support reply something, we have working stopped for this error, the program does not allow to do anything > https://www.loom.com/share/f316009bf2eb4dbbb92509d64c65b56d Exactly Same issues guys for 2 days now. I have done a lot of checks but it is not solving. Need URGENT help.Please Themler support reply something, we have working stopped for this error, the program does not allow to do anything
https://www.loom.com/share/f316009bf2eb4dbbb92509d64c65b56dExactly Same issues guys for 2 days now. I have done a lot of checks but it is not solving. Need URGENT help.
While everything works in the latest version of Firefox !! But to solve the problem is still necessary !!!
> > Please Themler support reply something, we have working stopped for this error, the program does not allow to do anything > > https://www.loom.com/share/f316009bf2eb4dbbb92509d64c65b56d > > Exactly Same issues guys for 2 days now. I have done a lot of checks but it is not solving. Need URGENT help. While everything works in the latest version of Firefox !! But to solve the problem is still necessary !!!It hasn't worked for me since today. Really a disaster.
It hasn't worked for me since today. Really a disaster.Hello,
We are sorry for the issue and will try to fix it at the nearest time. It's related to a security update in Google Chrome v80 and higher. Meanwhile, please, try using a different browser (e.g. Firefox)
Ich habe es so gemacht:
(Gilt für Windows 8 - 10 Benutzer:)
1.) aktuelle Chrome Version komplett deinstallieren
2.) letzte Version 79.0.3945.88 (32 oder 64 bit) installieren
download chrome Version 79.0.3945.88
( https://www.slimjet.com/chrome/google-chrome-old-version.php )
3.) Auto-Update von google Chrome deaktivieren:
Anleitung Autoupdate Chrome deaktivieren
( https://www.technobezz.de/disable-google-chrome-auto-update-in-windows-10/ )
Hoffe geholfen zu haben, ..... bis eine akzeptable Lösung seitens Themler realisiert wurde.
Ich habe es so gemacht: (Gilt für Windows 8 - 10 Benutzer:) 1.) aktuelle Chrome Version komplett deinstallieren 2.) letzte Version 79.0.3945.88 (32 oder 64 bit) installieren [download chrome Version 79.0.3945.88][1] ( https://www.slimjet.com/chrome/google-chrome-old-version.php ) 3.) Auto-Update von google Chrome deaktivieren: [Anleitung Autoupdate Chrome deaktivieren][2] ( https://www.technobezz.de/disable-google-chrome-auto-update-in-windows-10/ ) [1]: https://www.slimjet.com/chrome/google-chrome-old-version.php [2]: https://www.technobezz.de/disable-google-chrome-auto-update-in-windows-10/ Hoffe geholfen zu haben, ..... bis eine akzeptable Lösung seitens Themler realisiert wurde.Hello,
The fix is out.
You need to perform standard steps to clear the cache:
1) navigate to:
chrome://appcache-internals
2) navigate to:
1) close Themler
4) start Themler again
It did work. Thanks Themler team! you guys are as Awesome as always!
For everyone out here in community, I would like to ask that is it the permanent solution or are you still working on it?
Thanks again
It did work. Thanks Themler team! you guys are as Awesome as always! For everyone out here in community, I would like to ask that is it the permanent solution or are you still working on it? Thanks againIt did work. Thanks Themler team! you guys are as Awesome as always!
Thanks again
For the desktop version I tried, in case anyone is wanting to know!
> It did work. Thanks Themler team! you guys are as Awesome as always! > > For everyone out here in community, I would like to ask that is it the permanent solution or are you still working on it? > > Thanks again For the desktop version I tried, in case anyone is wanting to know!
