Does not save the template, only the image blinks
withamyn
withamyn posted this 16 March 2020
Hi!
For some reason, I can't save my changes to the templates. Instead of saving, the login window will flash:
https://drive.google.com/open?id=16-fVseZexnnP68IB3Njmp6XPJ_pQE6r2
Withamyn
Hi! For some reason, I can't save my changes to the templates. Instead of saving, the login window will flash: https://drive.google.com/open?id=16-fVseZexnnP68IB3Njmp6XPJ_pQE6r2 Withamyn
6 Comments
Support Team posted this 16 March 2020
Hello Withamyn,
We apologize for the inconveniences caused by this issue, we are working on it right now.
Please, use Firefox for the time being.
Hello Withamyn, We apologize for the inconveniences caused by this issue, we are working on it right now. Please, use Firefox for the time being. Gina Themler Support
withamyn
Thank!
Thank!
Support Team posted this 17 March 2020
The fix is available. It is recommended, to perform the following steps so that it is applied correctly.
For Themler on the hosted website please follow these steps:
1) Open this URL in Chrome:
chrome://appcache-internals
2) Open this URL in Chrome:
For Themler Desktop please try the following:
1) close Themler
4) start Themler again
Hello, The fix is available. It is recommended, to perform the following steps so that it is applied correctly. For Themler on the hosted website please follow these steps: 1) Open this URL in Chrome: chrome://appcache-internals find your website and click on 'Remove Item' 2) Open this URL in Chrome: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. For Themler Desktop please try the following: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again Sincerely, Nettie
colombimarco7
colombimarco7 posted this 18 March 2020
from themler desktop it doesn't work
thanks
Hi, from themler desktop it doesn't work thanks
Support Team posted this 18 March 2020
Does it work if you open this link http://127.0.0.1:12080/themler_2384416811/startup/ directly in Chrome? If not, please try Firefox and let us know the result.
Hello, Does it work if you open this link http://127.0.0.1:12080/themler_2384416811/startup/ directly in Chrome? If not, please try Firefox and let us know the result. Sincerely, Nettie
colombimarco7
colombimarco7 posted this 19 March 2020
Hi, now it works!
thanks
Hi, now it works! thanks
