Drupal Theme not Saving, keeps blinking the sign in overlay box
nmcfadden
nmcfadden posted this 18 March 2020
I am attempting to save my Themler after making some changes. When I click "SAVE" the overlay login box appears and then disappears over and over (see attached image). It looks like it is having trouble seeing that I am logged in already or something. Not sure what is happening. It won't let me save or export. Please help!
29 Comments
Support Team posted this 19 March 2020
Sorry for the inconvenience. We have found the problem. It's related to a security update in Google Chrome v80.
1) navigate to:
chrome://appcache-internals
2) navigate to:
1) close Themler
4) start Themler again
Hello, Sorry for the inconvenience. We have found the problem. It's related to a security update in Google Chrome v80. If you are using Google Chrome, try this: 1) navigate to: chrome://appcache-internals find your website and click on 'Remove Item' 2) navigate to: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. Some users have reported that complete re-install of Google Chrome solved the issue. If you are using the Desktop version, then: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again Gina Themler Support
nmcfadden
nmcfadden posted this 19 March 2020
Happy to report that the second set of instructions under "Desktop version" worked. I tried the first set of instructions, but couldn't get passed step 1. Also, I reinstalled Chrome, but it still did not work.
It took a while for Themler to reopen after I renamed the directory, but it worked. Thank you.
Happy to report that the second set of instructions under "Desktop version" worked. I tried the first set of instructions, but couldn't get passed step 1. Also, I reinstalled Chrome, but it still did not work. It took a while for Themler to reopen after I renamed the directory, but it worked. Thank you.
Rune
Rune posted this 19 March 2020
It works... Untill login is required again.
Doesn't it work with log out and then log in again in Themler desktop or online?
Hello, Doesn't it work with log out and then log in again in Themler desktop or online? Sincerely, Nettie
Rune
Rune posted this 20 March 2020
Sure. But next time login session are expired, the problem occurs again
Support Team posted this 20 March 2020
Does it behave same in firefox?
Does it behave same in firefox? Gina Themler Support
me321
me321 posted this 21 March 2020
I can confirm too that this happens each time the login session expires.
Support Team posted this 22 March 2020
Please, test firefox and incognoto mode in Chrome.
Please, test firefox and incognoto mode in Chrome. Gina Themler Support
me321
me321 posted this 23 March 2020
Hi Gina,
The problem is that when I close Themler, I am logged out each time. So I can never export or save a theme this way.
I only use Desktop (can't run it online, it doesn't work due to server permission issues) so I can't test other browsers than Chrome.
Also, as soon as I hit the Export button, it logs me out. The instruction above worked once but now it doesn't anymore.
Please advise on how to regain use of Themler again... Thanks.
Hi Gina, The problem is that when I close Themler, I am logged out each time. So I can never export or save a theme this way. I only use Desktop (can't run it online, it doesn't work due to server permission issues) so I can't test other browsers than Chrome. Also, as soon as I hit the Export button, it logs me out. The instruction above worked once but now it doesn't anymore. Please advise on how to regain use of Themler again... Thanks.
me321
me321 posted this 24 March 2020
For anyone looking for a (temporary) solution: I decided to undo the latest Chrome update so I can regain use of Themler. It may not be recommended but if Themler is of strategic value to you, it will restore functionality if you're using Themler Desktop on Windows 10.
Here is a working instruction: https://www.reddit.com/r/chrome/comments/9hhdbr/can_i_downgrade_my_chrome_version/
Please note that the Chrome version from before this update, is now this one for 64bit: https://www.slimjet.com/chrome/download-chrome.php?file=files%2F79.0.3945.88%2FChromeStandaloneSetup64.exe and this one for 32bit: https://www.slimjet.com/chrome/download-chrome.php?file=files%2F79.0.3945.88%2FChromeStandaloneSetup.exe
After downgrading Themler will work again.
For anyone looking for a (temporary) solution: I decided to undo the latest Chrome update so I can regain use of Themler. It may not be recommended but if Themler is of strategic value to you, it will restore functionality if you're using Themler Desktop on Windows 10. Here is a working instruction: https://www.reddit.com/r/chrome/comments/9hhdbr/can_i_downgrade_my_chrome_version/ Please note that the Chrome version from before this update, is now this one for 64bit: https://www.slimjet.com/chrome/download-chrome.php?file=files%2F79.0.3945.88%2FChromeStandaloneSetup64.exe and this one for 32bit: https://www.slimjet.com/chrome/download-chrome.php?file=files%2F79.0.3945.88%2FChromeStandaloneSetup.exe After downgrading Themler will work again.
Support Team posted this 26 March 2020
I can confirm that the issue is related to new security policy in Chrome v80 or above.
We have released one more fix to our server two days ago, you can test it if you clear the cache as suggested in my original reply once again.
I can confirm that the issue is related to new security policy in Chrome v80 or above. We have released one more fix to our server two days ago, you can test it if you clear the cache as suggested in my original reply once again. Gina Themler Support
me321
me321 posted this 27 March 2020
This issue is still persisting. The login overlay keeps popping up, preventing the saving of themes.
I completely removed and re-installed Themler, I did the original steps again, to no avail.
I'm using Themler desktop.
Hi, This issue is still persisting. The login overlay keeps popping up, preventing the saving of themes. I completely removed and re-installed Themler, I did the original steps again, to no avail. I'm using Themler desktop.
me321
I've now removed Chrome from my system, after reading a useful comment by peter80 here: https://answers.themler.io/questions/198358/themler-blinking-by-save-importet-wordpress-theme-not-save-possible.
This triggers Firefox (developer edition, in my case) to load Themler and then Themler works.
I've now removed Chrome from my system, after reading a useful comment by peter80 here: https://answers.themler.io/questions/198358/themler-blinking-by-save-importet-wordpress-theme-not-save-possible. This triggers Firefox (developer edition, in my case) to load Themler and then Themler works.
nmcfadden
nmcfadden posted this 27 March 2020
I signed out three days ago and today I signed back in and had no issues. Following these steps worked for me:
1) close Themler
I signed out three days ago and today I signed back in and had no issues. Following these steps worked for me: If you are using the Desktop version, then: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again
alrajib940
alrajib940 posted this 28 April 2025
Thanks for sharing those steps — sometimes a simple reset like renaming a directory can really fix stubborn issues with apps. It reminds me of how accessing modified apps can enhance the user experience by offering easier and more stable versions. For example, if you're interested in streaming content easily, you might want to baixar freecine, which offers a Mod APK version for a smoother entertainment experience.
Thanks for sharing those steps — sometimes a simple reset like renaming a directory can really fix stubborn issues with apps. It reminds me of how accessing modified apps can enhance the user experience by offering easier and more stable versions. For example, if you're interested in streaming content easily, you might want to [baixar freecine][1], which offers a Mod APK version for a smoother entertainment experience. [1]: https://freecineapp.com.br/
chawais6
chawais6 posted this 23 July 2025
It sounds like a session/authentication issue with Themler not recognizing your login—I've experienced something similar while customizing Drupal themes for Baixar Freecine. Try clearing your browser cache or switching browsers. Also, make sure cookies are enabled. If that doesn't work, check for any browser extensions that might be interfering with the login overlay.
It sounds like a session/authentication issue with Themler not recognizing your login—I've experienced something similar while customizing Drupal themes for [Baixar Freecine][1]. Try clearing your browser cache or switching browsers. Also, make sure cookies are enabled. If that doesn't work, check for any browser extensions that might be interfering with the login overlay. [1]: https://freecinemodapk.com.br/
jabeenzahra793
jabeenzahra793 posted this 01 August 2025
للاطلاع على التفاصيل الكاملة حول الخطوط، المحطات، مواعيد التشغيل والأسعار، يمكنكم زيارة الموقع الرسمي من خلال الرابط التالي:
مترو الرياض
للاطلاع على التفاصيل الكاملة حول الخطوط، المحطات، مواعيد التشغيل والأسعار، يمكنكم زيارة الموقع الرسمي من خلال الرابط التالي: [مترو الرياض][1] [1]: https://riyadhmetro.net/
alrajib940
alrajib940 posted this 13 September 2025
Thanks for clarifying, Gina. The Chrome v80+ policy changes have caused issues for many, so it’s good to know your team released a server-side fix. Clearing the cache and retesting should help most users resolve the problem. And just like staying updated with browser security policies is important, protecting your intellectual property is equally crucial — for that, you can reach out to a trusted Trademark attorney for professional guidance.
Thanks for clarifying, Gina. The Chrome v80+ policy changes have caused issues for many, so it’s good to know your team released a server-side fix. Clearing the cache and retesting should help most users resolve the problem. And just like staying updated with browser security policies is important, protecting your intellectual property is equally crucial — for that, you can reach out to a trusted **[Trademark attorney](https://sherinianlaw.net/)** for professional guidance.
alrajib940
alrajib940 posted this 04 October 2025
Try these quick fixes — one should stop the login overlay loop:
  1. Clear browser cache & cookies for Themler site (or use Incognito).
  2. Disable extensions (especially ad-blockers / privacy tools) and retry.
  3. Confirm you’re actually logged in on the same domain (check cookies/storage).
  4. Try a different browser or device to isolate if it’s browser-specific.
  5. Open DevTools → Console and Network while hitting SAVE; look for errors (401, 403, CORS).
  6. If the site uses Chrome v80+ features, update Chrome and allow site cookies/sameSite settings.
  7. If nothing works, take the screenshot + console/network logs and contact Themler support.
For related tools, check: google play store unlimited money mod apk no root.
Try these quick fixes — one should stop the login overlay loop: 1. Clear browser cache & cookies for Themler site (or use Incognito). 2. Disable extensions (especially ad-blockers / privacy tools) and retry. 3. Confirm you’re actually logged in on the same domain (check cookies/storage). 4. Try a different browser or device to isolate if it’s browser-specific. 5. Open DevTools → Console and Network while hitting SAVE; look for errors (401, 403, CORS). 6. If the site uses Chrome v80+ features, update Chrome and allow site cookies/sameSite settings. 7. If nothing works, take the screenshot + console/network logs and contact Themler support. For related tools, check: **[google play store unlimited money mod apk no root](https://www.5play.app/google-play-store-mod-apk/)**.
islamicideology1m
islamicideology1m posted this 08 October 2025
This happens when Themler loses your login session. Clear your browser cache, re-login to Drupal, and try saving again. If it keeps looping, open Themler in incognito mode or another browser. Also, make sure you’re on the latest version.
For smoother performance, download FreeCine atulalizado versao and enjoy a faster experience.
> I am attempting to save my Themler after making some changes. When I click "SAVE" the overlay login box appears and then disappears over and over (see attached image). It looks like it is having trouble seeing that I am logged in already or something. Not sure what is happening. It won't let me save or export. Please help! This happens when Themler loses your login session. Clear your browser cache, re-login to Drupal, and try saving again. If it keeps looping, open Themler in incognito mode or another browser. Also, make sure you’re on the latest version. For smoother performance, download [FreeCine atulalizado versao][1] and enjoy a faster experience. [1]: https://freecineapp.live/
