Cant log into Themler anymore i get a themler.io redirected you too many times. error.
Cant save work anymore
Cant log into Themler anymore i get a themler.io redirected you too many times. error. Cant save work anymoreCant log into Themler anymore i get a themler.io redirected you too many times. error.
Cant log into Themler anymore i get a themler.io redirected you too many times. error. Cant save work anymoreCant login and login keeps flashing blank. then says themler.io redirected you too many times. error.
Cant login and login keeps flashing blank. then says themler.io redirected you too many times. error.Seems like authenticating into your site may have issues. Had trouble just logging into edit the post here. had to use another browser edge.
Update: tried to uninstall and left themes, tried again same problem...
Seems like authenticating into your site may have issues. Had trouble just logging into edit the post here. had to use another browser edge. Update: tried to uninstall and left themes, tried again same problem...Hello Phill,
Sorry for the inconvenience. We have found the problem. It's related to a security update in Google Chrome v80.
1) navigate to:
chrome://appcache-internals
2) navigate to:
1) close Themler
4) start Themler again
Go to your browser settings, clear the cache, and temple run 2 cookies. This can often resolve redirect issues.
Go to your browser settings, clear the cache, and [temple run 2][1] cookies. This can often resolve redirect issues. [1]: https://templerun-2.io/
