Installation issues
allenazyk
allenazyk posted this 19 March 2020
Press the button "Edit Template" appears
  "Sorry, an error has occurred. Please clear your browser cache."
This question asks how to deal with it!
Press the button "Edit Template" appears   "Sorry, an error has occurred. Please clear your browser cache." This question asks how to deal with it!
9 Comments
Support Team posted this 19 March 2020
Hello Ming,
Go to your site on the server via FTP, go to "templates" folder and copy the folder of your current theme.
Zip it locally and open with Themler Desktop, update to latest version.
You may also check if Edit button works in firefox.
Hello Ming, Go to your site on the server via FTP, go to "templates" folder and copy the folder of your current theme. Zip it locally and open with Themler Desktop, update to latest version. You may also check if Edit button works in firefox. Gina Themler Support
allenazyk
Same problem in firefox.
Then this is related to the theme itself. You can though try these steps as well:
1) navigate to:
chrome://appcache-internals
2) navigate to:
1) close Themler
4) start Themler again
Then this is related to the theme itself. You can though try these steps as well: If you are using Google Chrome, try this: 1) navigate to: chrome://appcache-internals find your website and click on 'Remove Item' 2) navigate to: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. Some users have reported that complete re-install of Google Chrome solved the issue. If you are using the Desktop version, then: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again Gina Themler Support
allenazyk
allenazyk posted this 24 March 2020
I installed Themler for VirtueMart on the server and MacBook laptop, the problem is the same!
This problem has been responding for 4 days! I urgently need to help customers design!
Is there a specific way to actively assist?
Allen Yang
I installed Themler for VirtueMart on the server and MacBook laptop, the problem is the same! This problem has been responding for 4 days! I urgently need to help customers design! Is there a specific way to actively assist? Allen Yang
Support Team posted this 24 March 2020
Hello Allen,
In case it is not default Themler theme that has the issue but some other theme, please attach the theme here for investigation.
Have you please tried the steps suggested above?
Hello Allen, In case it is not default Themler theme that has the issue but some other theme, please attach the theme here for investigation. Have you please tried the steps suggested above? Sincerely, Nettie
allenazyk
I have followed the method you provided, but the problem still exists!
Provide us test videos for your reference!
https://youtu.be/bdELTFQlRsk
Allen Yang
I have followed the method you provided, but the problem still exists! Provide us test videos for your reference! https://youtu.be/bdELTFQlRsk Allen Yang
allenazyk
allenazyk posted this 26 March 2020
I have been responding to this bug for 6 days!
I can't get any help!
I can't use it!
Please earnestly assist with this issue!
Allen Yang
I have been responding to this bug for 6 days! I can't get any help! I can't use it! Please earnestly assist with this issue! Allen Yang
allenazyk
When can I get your reply!
Allen Yang
When can I get your reply! Allen Yang
Support Team posted this 17 April 2020
Please, attach the theme, copied from FTP, here.
Please, attach the theme, copied from FTP, here. Gina Themler Support
