Page Duplication does not work - Themler for HTML
aldo21
aldo21 posted this 20 March 2020
Hello world,
in Themler for HTML the page duplication does not work. Neither creating a new page.
Please, does anyone have a solution?
Thamnks for your help.
Greetz, ALDO
Hello world, in Themler for HTML the page duplication does not work. Neither creating a new page. Please, does anyone have a solution? Thamnks for your help. Greetz, ALDO
llovins
llovins posted this 21 March 2020
I am experiencing the same issue. It seems to be in a loop trying to access the web although I'm working on a local file set. Please help!
llovins
I was able to "fix" my issue. I had to export my HTML theme, include the files for edit. Uninstall themler completely, including my themes. Restarted, reinstalled, and imported the theme I previously exported.
Support Team posted this 24 March 2020
Hello Aldo,
Duplicating should be working fine.
As suggested above, try re-installing:
7. Download latest version of Themler for Windows from themler.io, install it and try to start with Themler
Hello Aldo, Duplicating should be working fine. As suggested above, try re-installing: 1. Backup all theme folders somewhere on your computer if there are any. The path is shown in the Theme Management screen after selecting some CMS, for example, C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress. 2. Uninstall Themler completely and also check the box for "Remove all CMS content". 3. Check if the following folders are still present: C:\Program Files (x86)\Themler C:\ProgramData\Themler 4. If they exist, remove them. 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. 6. Temporarily disable antivirus and firewall. 7. Download latest version of Themler for Windows from themler.io, install it and try to start with Themler Gina Themler Support
